Leer Dome LED not working properly…
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joncure, Jan 29, 2024.
  1. Jan 29, 2024 at 2:29 PM
    joncure
    joncure [OP] Well-Known Member
    VA
    2021 TRD Sport Access Cab manual
    So my dome LED light has worked perfectly since cap was installed in 2021 until yesterday. Now when I push the button, the LEDs illuminate but so faintly that the light doesn’t really emit any useful light.
    Brake light works fine. The dome wire is wired directly to the battery. All related fuses are good. I checked the wiring at the junction box at the back of the cap and that all seems ok.
    Anyone have any ideas/suggestions? Anyone have a similar issue?
  2. Jan 29, 2024 at 2:33 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you've got 12 volts going into the led light and the ground circuit is good then it sounds the light just went bad. Time for a new one
    BigCountry762x39, Chew and HondaGM like this.
  3. Jan 29, 2024 at 2:35 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    good ground?
  4. Jan 29, 2024 at 2:39 PM
    joncure
    VA
    Haven’t checked the ground yet, probably because it’s hard to find. I’ll have to trace the wire under the truck to find it.
  5. Jan 29, 2024 at 2:51 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When I wired my brake light and dome light I screwed an eyelet into the sheet metal behind the left tail lamp. It's been a while but I'm pretty sure there's some good metal back there. You might check and see if the canopy guys put a ground there
  6. Jan 29, 2024 at 3:53 PM
    joncure
    VA
    Thanks, I’ll check there for sure.
  7. Jan 29, 2024 at 3:56 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    check your power lead mine got really bad and would flicker... the crimp on the fuse wire was bad, replaced that and was just fine.
  8. Jan 29, 2024 at 3:57 PM
    joncure
    VA
    I’ll check that too, thanks!
  9. Jan 29, 2024 at 4:36 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    You might also check the contacts on the bulb and its receptacle for corrosion. A bit of steel wool or emery cloth could clean those up.
  10. Jan 29, 2024 at 4:50 PM
    TacoZmtn
    TacoZmtn Well-Known Member
    2022 TRD Off Road LB
    OTT-6112’s~5160’s rxt's~ShmellFab Sliders
    I still have to hook mine up...
  11. Feb 5, 2024 at 4:01 PM
    joncure
    VA
    Troubleshooting continues. All associated fuses are good. I traced the wire that connects to battery and could not find any issues there.
    I checked volts coming from battery to fuse, 12.3v
    I checked volts at that junction box in topper and had only 2.3v coming out from box to LED dome light. Should be 12v. The brake light works fine.
    Any ideas/suggestions out there?
    Also, I think there is a wire harness under bed that was added into all that trailer harness wiring that serves the 3rd brake light and dome light. It also seemed ok, nothing obvious.
    It all worked flawlessly for 3 years, then dome LED suddenly went dim. It’s not getting enough juice from battery somehow.
  12. Feb 9, 2024 at 9:40 AM
    joncure
    VA
    Now for in-line fuse related question;
    -checked voltage at battery: 12.5v
    -Checked voltage where power lead for dome light connects to battery:12.5v
    -Took out fuse and put probes in where fuse goes and got 11.3v
    -kept positive probe in fuse socket and grounded negative probe back to battery and got 12.5v
    Could the in-line fuse connector be bad?
  13. Feb 9, 2024 at 10:04 AM
    HeyB
    HeyB Well-Known Member
    2022 TRD OR DCLB
    If you haven't checked yet, I'd pull that tail light and check for ground in that location. Believe that's Leer's recommended spot. My installer did that and I found corrosion happening after only 1 winter. That area actually gets road spray, and if you're in a salt state the cheap screw/connector goes fast.
    Good luck!
    B
    Chew likes this.
  14. Feb 9, 2024 at 10:29 AM
    joncure
    VA
    I did pull the tail light and no ground. That lead wire from the battery goes all the way to the rear and into an aftermarket wire harness that Leer installer put in. That harness connects to trailer light harness, then red/black/white wires come out and go straight up into the fuse junction box mounted at back of truck bed beside the hatch. Couldn’t find a ground anywhere in the back. The battery is grounded of course.
    So if a ground is needed, I’m not sure where to tap/connect a ground back there?
  15. Feb 9, 2024 at 11:20 AM
    HeyB
    2022 TRD OR DCLB
    Got it. The good news is that should be a cleaner install than the crappy t-tap and half rusted sheet metal screw my installers used!
    They are pulling pos/ground/brake off the trailer harness. Assuming trailer lights are working fine, try checking ground between fuse box and trailer connector.
    I included the fuse box wiring diagram below. It's probably the black wire, but will definitely be whatever color goes to the ground position in the diagram.
    And, I am definitely no 12v guru. Just passing along some of the help much more capable forum members passed to me when I cleaned up my installers mess.
    Hope that helps!
    B
  16. Feb 9, 2024 at 12:39 PM
    joncure
    VA
    Thanks for the tips B.
    So far I can’t find a ground between trailer lights and fuse box. All associated fuses are good though.
    All taillights/brake lights work fine, even the 3rd brake light on the topper works and the wiring for that is associated with the LED dome light wiring.
    All I really know is that adequate power (for LED) is not getting back to fuse junction box in the bed anymore even though adequate power for 3rd brake light IS.
    Also, there is no ground between the trailer harnesses and the fuse junction box (where wiring comes into then out to 3rd brake & dome light). How could this setup have worked perfectly for 3 years without that ground?
  17. Feb 9, 2024 at 12:42 PM
    joncure
    VA
    Pics of said fuse junction box & wiring…
  18. Feb 12, 2024 at 7:00 AM
    joncure
    VA
    If I wanted to add a ground from here, would I need to tap into the black wire?
