Leer brake light question
Discussion in 'Tonneau Covers, Caps and Shells' started by FL_TRDOR, May 5, 2021.
  1. May 5, 2021 at 9:07 AM
    FL_TRDOR
    FL_TRDOR [OP] Well-Known Member
    South Florida
    Trying to figure out if this box is for the interior lighting or if this is for the brake light? Any help is much appreciated.
  2. May 5, 2021 at 5:43 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    Both, and more.
    That fuse box comes standard on recent Leer shells. I have it on mine. The box contains 3 fuses -- 1 amp for the brake light, 5 amp for the dome light, and 10 amp for the auxiliary circuit.
    In your picture, the right-side top plug (with the wires coming out of it) is for the brake light and the dome light. The other top plug is for the 12 volt auxiliary outlet and the remote back window lock. The bottom plug is for the wires coming from the truck.
    More specifically, the bottom plug accommodates up to 6 wires, as follows:
    Pin 1 - Brake light (red/while wire)
    Pin 2 - Window lock (green wire)
    Pin 3 - Dome light (red wire)
    Pin 4 - Ground (black or white wire, depending on the harness)
    Pin 5 - Window unlock (blue wire)
    Pin 6 - 12 volt auxiliary (red/black wire)
    Top right plug:
    Pin 1 - Dome light (red wire)
    Pin 2 - Brake light (red/white wire)
    Pin 3 - Ground (black wire)
    Pin 4 - Ground (black wire)
    (In your picture, these are pre-wired.)
    Top left plug:
    Pin 1 - Window lock (green wire)
    Pin 2 - 12 volt auxiliary (red/black wire)
    Pin 3 - Window unlock (blue wire)
    The wire colors are from the appropriate Leer wiring harnesses.
    bromide, SH10151, Mitja and 4 others like this.
  3. May 5, 2021 at 7:05 PM
    FL_TRDOR
    South Florida
    Would you happen to have a direct link to a wiring harness that would work for this? Thank you for the help!
  4. May 6, 2021 at 6:21 AM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    There are two different choices for the truck-side harness. The elegant (but expensive) one uses a pass-through connector for your 7-pin trailer outlet. That way, you don't have to tap into the truck wiring.
    https://www.ezwheeler.com/collectio...ight-7-way-interface-plug-in-t-harness-300200
    Or, you can use the cheap alternative, but you have to tap into the truck's brake light circuit. (You still have to run a wire direct to the battery for the dome light.)
    https://truckoutfittersplus.com/Topper-Fuse-Box-Wire-Harness-only.html
    SH10151 and FL_TRDOR[QUOTED][OP] like this.
  5. Jul 11, 2021 at 9:18 PM
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
  6. Jul 11, 2021 at 9:25 PM
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    I guess this box was hidden ( I doubt it because I've traced the wires) on my Leer I purchased less than 2 years ago? Maybe it has something to do with power locks and suck which I don't have. I do have the 3-way 12 volt offered with small black fuses installed.
    Pictures tomorrow
    Edit- such not suck
  7. Jul 11, 2021 at 10:36 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Look under your back seat driver side kick panel to see if you have one of these. \/ \/ \/
    This /\ /\ /\ is the flasher for the OE High Center Break Light. It has Bullet connectors that you can simply unplug. You can disable the High Center Break light by unplugging it. And simply run a new wire from here to the Topper Third Break Light. You topper light will flash just like the OE light did.
    mrCanoehead likes this.
  8. Jul 12, 2021 at 5:33 AM
    Fast1
    Minneapolis, MN
    Where did you exit the cab from that wire to get to the topper?
  9. Jul 12, 2021 at 12:14 PM
    PhenixFord
    Randy
    Arkansas
    There are several different rubber plugs under the seats. Just poke a hole in one with a small screwdriver. If you look at one of the videos for installing the Pop-N-Lock devices, they use the same access point.
    Fast1[QUOTED] likes this.
  10. Jul 12, 2021 at 1:52 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
  11. Jul 12, 2021 at 7:49 PM
    Fast1
    Minneapolis, MN
    I purchased it when I ordered a new Leer 180 from Radco Truck Accessories and that was the additional cost for it. It was a genuine Leer branded product.
  12. Dec 3, 2024 at 3:31 PM
    Mitja
    Mitja New Member
    I got the same fuse box and set up, could I use these wires and splice them into my tacoma 2017 break light? Or do I need to get other cables to make them work?
    Thanks
