Leer/ARE Thule Yakima Track install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JCD1985, Feb 16, 2021.
  1. Feb 16, 2021 at 11:32 AM
    JCD1985
    JCD1985 [OP] Member
    Chase
    2008 Toyota Tacoma 4x4
    N/A
    Has anyone installed either the Thule or Yakima tracks on a leer or ARE topper? Specifically asking since I want to put a Prinsu rack on my topper.
  2. Feb 16, 2021 at 12:08 PM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
  3. Feb 16, 2021 at 12:23 PM
    JCD1985
    JCD1985 [OP] Member
    Chase
    N/A
    Thanks! I looked but couldn’t find it.
  4. Feb 16, 2021 at 1:34 PM
    NoVa TRD Sport
    NoVa TRD Sport Well-Known Member
    Alexander
    Northern Virginia
    2021 Army Green TRD Sport
    Leer cap
    I got the Thule tracks on my Leer topper as an option from the factory, and I installed the Prinsu rack on them.
    There's no reason why you can't install the tracks yourself. The thing to keep in mind, if you're going to put on a Prinsu rack, is that the tracks should be 42" apart, center to center. The slanted side should be on the bottom, so that the top is flat. (The mounting bolts should thus be outboard of the thicker "honeycomb" section of the shell.) Use lots of silicone sealant around the mounting bolts.
    You might want to leave the rear end caps off the tracks until after you install the rack. Otherwise you'll have to take them off to put the captive nuts in the tracks.
    JCD1985[QUOTED][OP] likes this.
  5. Feb 16, 2021 at 1:47 PM
    JCD1985
    JCD1985 [OP] Member
    Chase
    N/A
    Thanks for the info, exactly what I was looking for! Do you know the length of the Thule tracks?
  6. Feb 16, 2021 at 2:30 PM
    NoVa TRD Sport
    Alexander
    Northern Virginia
    Leer cap
    For a long bed (6') shell, the tracks are 61" long (including the end caps). The Prinsu long-bed rack actually slightly overhangs the tracks. It has 6 support feet (3 on each side) and 7 crossbars. You attach the feet to the middle crossbar and the next-to-the-ends crossbars. Since the tracks follow the contour of the topper, they are slightly arched, front to back. That means that you have to use 1/4" spacers (stacked fender washers work well) when attaching the end support feet to the tracks.
    The tracks are proportionately shorter for a short (5') shell. The Prinsu short-bed topper rack only has 6 crossbars and 4 support feet, so you don't need the spacers.
  7. Feb 17, 2021 at 7:47 AM
    JCD1985
    JCD1985 [OP] Member
    Chase
    N/A
    Thanks for all the information, since I’ve got the 5’ bed I’m guessing I’ll need the 54” tracks.
