Leer 100XR Side Window Removal/Leak - Input?
Discussion in 'Tonneau Covers, Caps and Shells' started by steveo27, May 8, 2018.
  1. May 8, 2018 at 9:43 PM
    steveo27
    steveo27 [OP] Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I noticed during the last rain that my new to me Leer 100XR leaks around the side window on the driver side. The rain comes in and puddles along the bottom edge right below the side window.
    Ive already added seals underneath the plastic bed rail caps, so Im pretty confident its not coming in from there.
    The water puddles on the inside ledge of the shell then runs down into the bed, so its definitely some part of the shell leaking, most likely around the window.
    Ive spent a ton of time searching on how to remove the side windows and reseal them with zero luck. Everything I find shows people adding a bead of silicon along the outside edge of the window on the exterior which is SUPER ghetto and not the right way to fix this.
    Id like to fix mine the right way and reseal the window without just adding a bead of silicon around the outside.
    Are the side windows glued in? Or do the inside trim ring with the 30 some screws on each side hold the windows to the shell (or is this just a decorative cover)?
    This is the closest similar thing I could find in the interwebs for a different brand shell.
    https://youtu.be/oIvN7BwNM_8
    Any help or input would be greatly appreciated before I dive into this blind.
  2. May 9, 2018 at 3:42 PM
    cascadetaco
    cascadetaco Toyota Addict
    central oregon
    2017 SR 4cyl 4x4 5speed
    Pretty sure you can get them out. They may be held in with some seal tape. They had one of mine out fixing leaks.
  3. May 9, 2018 at 7:12 PM
    steveo27
    Pittsburgh
    Welp.
    They come right out once you remove the 30 some screw that go around the inside frame piece. Just like shown in the video
    I pulled both side windows out, cleaned the sealing surfaces, cleaned the gaskets, reinstalled them, and torqued down all the hardware.
    Gonna hit it with the hose tomorrow and see what happens
  4. Aug 9, 2018 at 8:02 PM
    Flyin200ln
    Flyin200ln Member
    2012 DCLB
    So did that fix it or were new seals required? Same issue here.
  5. Aug 9, 2018 at 8:14 PM
    smikski
    smikski Well-Known Member
    2016 4x4 2.7 - 3 pedals
    skid plates , leer cap , thule roof rack , tires 1 size up
    Torque setting for the side windows srews ? ty, i also got new windows still leaks a lkttle thanks again
  6. Nov 14, 2018 at 7:36 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    What seal tape stuff did you use for the window frames & did it stop the leaks?
  7. Dec 17, 2018 at 3:36 AM
    mattylmbr
    mattylmbr Well-Known Member
    2018 Tacoma TRD Sport
    Any success on thus??
  8. Dec 17, 2018 at 3:43 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  9. Mar 23, 2019 at 7:18 PM
    Kinggargantuan
    Kinggargantuan Well-Known Member
    Nick
    2014 grey dcsb trd or 4x4
    Stock
    was there a rubber gasket covering the bolts on the inside? Mine has a rubber gasket and I'm not sure I want to try and pull it off if it's not supposed to come off that way.
    Still searching youtube for side-window removal vids but not having any luck with my type of topper (jeraco)
  10. Mar 25, 2019 at 9:26 PM
    steveo27
    Pittsburgh
    Not sure how I missed all those questions.
    I used rubber weatherstripping from the hardware store. It fixed the leak.
    No rubber covering the inside on my Leer.
    Kinggargantuan likes this.
