Led turn signal load resistor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dsage17, Apr 8, 2018.
  1. Apr 8, 2018 at 11:21 AM
    dsage17
    dsage17 [OP] Active Member
    Drew
    2005 Double Cab Prerunner
    2" level with KO2s
    So I recently bought led turn signals for my 05 with dtrl and it came with two led load resistors but im not really sure where to wire them in or where to secure them. Any help?
  2. Apr 8, 2018 at 11:57 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Behind the in can fuse panel
  3. Apr 8, 2018 at 12:21 PM
    dsage17
    Drew
    2" level with KO2s
    Where is that?
  4. Apr 8, 2018 at 12:27 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
  5. Apr 8, 2018 at 12:34 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
  6. Apr 8, 2018 at 3:59 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Behind rear tail light
    IA_Tacoma and blksandpearl2010 like this.
  7. Apr 8, 2018 at 4:06 PM
    toyotaman29
    toyotaman29 Well-Known Member
    Darrell
    North Carolina
    2021 SR Prerunner Silver
    LED upgrades, Husky weatherbeaters, Black 16’’ wheels
    I just replaced the plug in flasher for the turn signals under the dash, didn't use the resistors...
  8. Apr 9, 2018 at 9:55 AM
    fritzthecat
    fritzthecat Well-Known Member
    Virginia Beach
    07 PreRunner Auto AccCab Indigo
    1- Do NOT put the resistors anywhere inside. They get hot enough to melt plastic.
    2- Connect the resistors to the BACK turn signals (since the front bulbs will always be lit by the DTRL).
    3- Mount the resistors to a metal surface (see post #6) so they can dissipate the heat.
    Fritz
    FastEddy59 likes this.
  9. Apr 9, 2018 at 9:59 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    If you don't use the correct watt resistor, they will get hot.
    Don't preach what you don't know.
  10. Apr 9, 2018 at 10:10 AM
    fritzthecat
    Virginia Beach
    There is a reason the resistors have a big ass heatsink on them.
    If the resistor wattage is too small they will burn up. If the wattage is correct, they will get hot.
    Feel free to activate the turnsignals for 5 minutes and then touch the resistor. Have some burn salve ready.
    The resistors are usually 6 ohm 50 watt. A resistor like the one shown in post #6 will hit over 300 deg F after 5 minutes of turn signal use. See video below.
    https://www.youtube.com/watch?v=I6SAhMHbrEA
    That's why I recommended mounting to a metal surface to spread out the heat.
    Fritz
    Oldasmud and Jimmyh like this.
  11. Apr 9, 2018 at 10:16 AM
    knottyrope
    Knotty
    Bahstun
    a properly sized resistor wont heat up to 300 degrees
  12. Apr 9, 2018 at 11:16 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    Hey @dsage17 what size resistors did you get with your led lights? Don’t trust the vendor to give you the right ones. They may get hot so find out before just mounting them anywhere. Burning down your truck for cool led lights will suck.
  13. Apr 24, 2018 at 6:45 AM
    IA_Tacoma
    IA_Tacoma New Member
    I’d like to beat this dead horse one more time just to be clear. My 08 has DRLs that I will be replacing with LEDs. As jbrnigan and fritzthecat have mentioned, adding the resistors to the rear turn signals will correct hyper flash after adding the LED front signal/DRL. So.. if I add the correct resistor to each of the rear signals, the resistors will NOT be ‘on’ constantly as they would be if I were to place the resistors in the front with the DRLs? I do not have LED rears.
  14. Apr 24, 2018 at 6:50 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
  15. Apr 24, 2018 at 7:10 AM
    knottyrope
    Knotty
    Bahstun
  16. Apr 24, 2018 at 7:11 AM
    IA_Tacoma
    Tacomas with DRL require 12pin flashers. 8 pin flashers (such as this one) work great for non DRL equipped. At this time no one makes a 12pin LED flasher for these vehicles thus requiring resistors. It’s too bad....
    blu92in99 likes this.
  17. Apr 24, 2018 at 7:52 AM
    Muddinfun
    Muddinfun Well-Known Member
    I'm happy with my grey plastic jumper cap, LEDs, Smart Tap flasher, no resistors, no DRLs.
    whatstcp likes this.
  18. Apr 24, 2018 at 1:01 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Are you saying, add resistors to rear regular bulb for hyperflash from a front DRL/LED turn bulb?
  19. May 23, 2018 at 7:00 AM
    MBtoyota15
    MBtoyota15 New Member
    2015 TacomaTRD PRO
    Has anyone found a flasher that will work with a 2nd gen? If so can you provide a link to purchase one. Also what brand of LED’s did you use for the front DRL/Turn signals and back turn signal?
  20. Apr 3, 2019 at 2:45 PM
    mr.t-h76
    mr.t-h76 Member
    Joseph
    Vermont
    2018 Inferno red TRD Off road
    Do front AND back turn signal bulbs need load resistors? I installed them on my tail lights and they work fine until I turn my headlights on (which are also LED). Suggestions?
