LED Tail light swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheBigGuy, Jan 16, 2020.
  1. Jan 16, 2020 at 12:16 PM
    TheBigGuy
    TheBigGuy [OP] Active Member
    2013 Toyota Tacoma PreRunner
    Hey guys so, i have a 2013 Toyota Tacoma and it came with these basic Tacoma tail lights. Found some of the newer factory LED one’s with the chrome in it for sale on facebook marketplace. But they didn’t come with the harness with all the sockets for the bulbs... tried to re use the sockets that were on the basic tail light but they don’t fit. They’re made a little differently. So does anyone have the harness that comes with the factory LED tail lights ? Im sure those would fit just right, thank you guys
  2. Jan 16, 2020 at 4:14 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    I'm pretty sure my swap to the LEDs used my stock tail lights everythings.
  3. Jan 16, 2020 at 9:27 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Looks like the plug that’s in the new led tail light would plug into the lamp socket for your park/brake light.. then twist the socket into the housing just like the reverse and turn sockets.:notsure: Worth a try atleast
    BassAckwards and 3JOH22A like this.
  4. Jan 16, 2020 at 9:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    +1
    Some aftermarket tail lights have LED turn signals as well. They plug in the same way.
    Note the polarity. Filament bulbs don't care. LEDs work only one way. If the brake light doesn't turn on, unplug and flip the connector 180.
    RJ_MacReady likes this.
  5. Jan 16, 2020 at 9:41 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    That grey plug you have is the same as what a light bulb would be. So that grey plug snaps into the socket on your truck, then the socket twists into the housing like normal. It works, i promise
    BassAckwards likes this.
  6. Jan 17, 2020 at 10:58 AM
    TheBigGuy
    Yes i know that plugs in just fine. I was referring more to the top turn signal bulb socket.. sorry. Like the grooves on it is different. So it doesnt twist and turn and stay tight.
  7. Jan 17, 2020 at 10:58 AM
    TheBigGuy
    I would have to take a picture later and better explain it
  8. Jan 17, 2020 at 10:59 AM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    My stock harness on my 07 works for the 2015 OEM tail lights I got... Maybe you just aren't pushing them together quite right? And you have to look at the grooves, there's one big groove for each hole, you have to line it up, then twist. They will fit.
    ProForce likes this.
  9. Apr 18, 2020 at 3:46 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Didn't want to start a new thread for a related question - Will swapping TO the non LED housings require any other changes as far as connectors go? I want to get some non LED style housings because I can't stand the clear lens and round LED style.
  10. Apr 18, 2020 at 4:35 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Nope, the bulbs just plug into the harness you have for your factory LED lights.
  11. Apr 18, 2020 at 4:43 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    awesome. Thanks for the quick reply!
    Ccrames2018[QUOTED] likes this.
  12. Apr 18, 2020 at 5:12 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    They are the exact same. I used the stock harness on my 07 for my 2015 lights and they lock in perfectly and seal fine. They'll work. Worst case you can get new harnesses if you're worried about it, but you won't have any issues. Tons of people have done that same swap before
  13. Apr 29, 2020 at 5:40 PM
    TheBigGuy
    where can you buy those harnesses? i cant find any for LED tail lights
  14. Apr 29, 2020 at 6:33 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Assuming the lights you're buying have all their sockets...it's completely plug-and-play. The 1st thing I did before I even left the dealership was swap out the LEDs for my base rig's incandescent lights. I simply can not stand the Ebay looking OE LEDs...although I've seen tinted ones that don't look bad.
    My '15 TRD Sport...
    Here's what I've discovered. There are 2 different runs of the base tails. From '05-'08 all Tacos had the incandescents. Then from '09-'11 they all had LEDs. Then '12-'15 the base models went back to incandescents.
    IMO these 2nd run lights look a little better....a little more red and less prone to fading.
    These tails are 7.5 years old. Every 2-3 months I hit with some McGuire'a PlastX.
  15. Apr 29, 2020 at 7:07 PM
    Ccrames2018
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    Your truck has them already.
  16. Apr 29, 2020 at 7:09 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    Those look good for 7 years. Do you use that on black plastic trim, too? I have used Rejex on plastic in the past but it doesn't work well on anything but smooth, shiny plastic.
  17. Apr 29, 2020 at 7:13 PM
    Plain Jane Taco
    USA
    I discovered that the PlastX works well on just about any smooth, non-porous plastic surface. But I would not use it on a porous surface at all....certainly not the trim.
  18. Apr 29, 2020 at 7:15 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    So it works well on trim like the black bumper cover in your picture? It doesn't leave a white haze that requires heavy buffing or a brush to get out?
  19. Apr 29, 2020 at 7:20 PM
    Plain Jane Taco
    USA
    No..I would definitely not use it on the black bumper cover. It's textured. It's basically a wax for smooth plastic.
    GrundleJuice[QUOTED] likes this.
  20. Apr 29, 2020 at 10:47 PM
    TacoTuesday1
    FL
    Plastx is an abrasive not a wax
