LED lights under truck
Discussion in 'Lighting' started by STEVESTRUCK, Mar 10, 2013.
  1. Mar 10, 2013 at 9:43 AM
    STEVESTRUCK
    STEVESTRUCK [OP] Member
    Alexandria, AL
    2011 Prerunner
    Remote start, nerf bars, Retrax tonneau cover, interior LED's
    I bought some waterproof led lights I would like to put under my truck on both sides to come on when my dome light comes on, such as when I start it, or when I exit the truck, to light up the step rails. Can anyone tell me the best place to connect them?
  2. Mar 10, 2013 at 11:09 AM
    acdronin
    acdronin Well-Known Member
    Interesting idea, haven't seen this before so i went out to the truck and checked it out. Ok, first thing to do is to see what the amperage of those LEDs are in total, this will determine if you can do this. I have an 07 but this stuff should be the same. One the packaging there should be a spec saying what the amp draw is, 3-4 amps, whatever it is. If there is no amp spec but there is a wattage spec you can use that, if it's say 25 watts total then divide by 12 volts of your system and that gives you the amps (25 divided by 12 = 2.08 amps).
    This next part I'm not totally sure on so you'll have to play it by ear unless someone else here knows this number.
    You'll have to figure out the wattage of the dome light, I found replacement bulbs online that say 5 watts which comes out to .41 amps.
    Next, I don't believe there is anything else and no other lights on that circuit if there is you will have to figure out what their amp draw is too.
    So lets say your lights draw 3 amps and your dome light bulb draws .41 amps, so that's 3.41 amps total.
    next, pop the hood and pull the cover off the fuse block which is the black box thingy right behind your battery : [​IMG] On the block in the lower left and corner you will see these fuses, if you look on the inside of the cover there is a diagram which tells you which one is the Dome light, in my case it's the brown middle fuse with the 7.5 upside down, that's yer dome light fuse.
    next get something like this , it's called an add-a-circuit or fuse tap :
    https://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2
    Look at the pics and you see where the tap fits into the slot on your block and it has a wire coming off of it for a new circuit. Disconnect your battery before you start any electrical work on your truck! You install your old 7.5 fuse into it and wire the hot lead to your rock lights.
    I would do this part before I put the lights on the truck to make sure it's going to work first. If you did your math right hopefully there is enough extra amperage capacity on that circuit to run the rock lights.
    If not, you may be able to do the same thing on one of the ignition circuits but I'm not sure which one would work. NEVER put a higher amp fuse into a block, you're begging for an electrical fire.
    There is not a whole lotta space on that part of the fuse block so you'll have to figure out which design will work for you and you'll have to cut a teeny tiny slot in the plastic edge of the block to get the wire out with out the cover pinching it.
    Other than that, hang the lights, use lots of zip ties for the wires underneath, keep the wires away from hot pipes are engine components and it should work fine.
    Good Luck
    snakeeyezinc likes this.
  3. Mar 10, 2013 at 11:22 AM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    Thanks for the info. I have already changed the dome light to an LED bulb, and with the LED flexible strip, I should be okay on the amp draw. The main thing I'm trying to do is tie it in so it is switched with the dome light.
  4. Mar 10, 2013 at 11:24 AM
    acdronin
    I forgot to mention that, yeah that's a great way to get some more capacity
  5. Mar 10, 2013 at 11:26 AM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    I saw this once on a Tundra, and it looked great at night. Whenever the truck cranked, doors unlocked, or doors opened and the dome light lit, the LED's under the truck lit up and lit up the nerf bars. When you closed the door and the dome light went off, so did the LED's.
  6. Mar 10, 2013 at 11:28 AM
    acdronin
    Post some pics when you finish:)
  7. Mar 10, 2013 at 11:29 AM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    I'm just trying to figure out where to connect them to achieve this without adding a switch. The guy with the Tundra said he connected his to the dome light connector, wherever that is.....
  8. Mar 10, 2013 at 11:30 AM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    I will, if I can figure where to connect it up.
  9. Mar 10, 2013 at 11:31 AM
    acdronin
    I gotta think that's in the cab somewhere probably behind the dash
  10. Mar 10, 2013 at 11:32 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
  11. Mar 10, 2013 at 11:32 AM
    acdronin
    Since you need to get power to it and you're not putting a switch in the cab, off the fuse block makes the most sense to me
  12. Mar 10, 2013 at 11:46 AM
    AnTiFuBaR
    AnTiFuBaR Well-Known Member
    Grand Junction, CO
    '13 TRD OR 4x4 DCSB
    BHLM
  13. Mar 10, 2013 at 11:53 AM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    Thanks, mynewtoy. I checked it out and it helped some. The only thing I'll have to figure out is WHICH blue wire to tap into
  14. Mar 10, 2013 at 12:04 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    Sub'd for this ...hopefully you find an EASY way to get them powered up...;)
    My question is ,are these LED's from Fulkerson Fabrication ??? 4WD Toyota Owner Mag installed a few of these on their '96 Tacoma and really praised them up....
    Always looking for another "view" point on "New products" :cool:
  15. Mar 10, 2013 at 12:07 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Just splice them into the dome light wire and add a higher amp fuse to the box.
    Don't make it anymore difficult then it should be.
  16. Mar 10, 2013 at 1:27 PM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    I don't have a black connector. All of mine are white. I found the connector that controls the dome light, but none of the blue wires seem to be the one for the dome light. I can take a meter and check voltage on the wires, but the voltage stays, even when I close the door and the light fades off.
  17. Mar 10, 2013 at 7:43 PM
    untuckedtaco
    untuckedtaco Well-Known Member
    Kyle
    Chesapeake 23323
    DCSB 08 SAS'ed/REBUILDING
    Surprises
    once tapped into the dome light, can a circuit be added to come on with the reverse lights as well?
  18. Mar 10, 2013 at 7:46 PM
    noSKills858
    Alex
    Poway, CA
    Yuup I quoted myself because my exterior and interior lights are connected on the same circuit as my dome light. AND since my dome light was originally a halogen, I had swapped to LED which pulls much less amperage then a halogen where I kept the same amp fuse because I know it is more then enough to handle it.
    Just remember to disconnect the positive battery terminal when working on it so you don't blow the fuses.
  19. Mar 11, 2013 at 2:38 PM
    STEVESTRUCK
    Alexandria, AL
    2011 Prerunner
    Thanks for the info. For snoope, no, they came from E-bay. They are 5050 SMD LED Waterproof self-adhesive flexible strips...12V 300 LED's 5 Meter roll (about 16 Ft.)
  20. Mar 11, 2013 at 10:28 PM
    Kulahaga
    Kulahaga Tacomaized
    Roger
    Florida Panhandle
    2010 * Regular Cab * 2.7 * Manual
    Curt Receiver Hitch * Firestone RideRite Air Springs * OEM Chrome Grill * OEM Intermittent Wipers * OEM Cruise Control * UltraGauge * * Anytime Fog Lights * Cargo Bar & Cargo Net * Pop & Lock and Bully Tailgate Security * TonnoPro Tri-Fold Tonneau Cover * Backup Camera * * LED Interior, Under Door, Under Hood & Cargo Lighting * Pin Stripes * Wet Okole Seat Cover * ImMrYo Mirror Mod * DVR207 Dash Camera *
    Hey Steve,
    The info provided in both the responses from "mynewtoy" and "caribe makaira" are accurate with regard to the "blue" dome light fading "ground" wire.
    Keep in mind that the "blue" wire is actually a GROUND circuit when activated by the dimming feature (it is not a + 12 Volt DC circuit). You won't read a voltage on it when the door is opened. Rather, connect an "ohm" meter (not a volt meter) with one lead to the blue wire and the other lead to ground. You will see no resistance reading to ground until you open the door (releasing the door open sensor switch). Conversely, you will see the resistance reading (ohms) fade and disappear as you close the door (depressing the door open sensor switch).
    You may use an "add-a-circuit" with only a 5 Amp fuse. That will be more than adequate for a 5 meter strip of 5050 LEDs, since they draw =< than 500 MA per meter (2.5 amps for the entire 5 meters). Keep in mind that when you utilize an add-a-circuit it becomes a separate, independent circuit from the existing fuse slot that you plug it into with its own separate fuse. EDIT: Most of the under-dash fuses have no power (+ 12 VDC voltage) flowing to them unless the ignition key is in the accessory or on position. If you want your LEDs to go on when opening the door, you must find a fuse that has power to it when the ignition key is off. The only one I could find in the under-dash fuse box is the "Power Door Lock" fuse. As an alternative, you can run a power wire (+ 12 VDC) by placing an add-a-circuit fuse to the Dome Light fuse in the under-hood fuse box and run that wire to feed the positive side of your LEDs.
    I added a 5 meter strip of 5050 LEDs to the cargo bed of my 2010 regular cab using this method. They go on with the dome light when the door is opened and fade out when the door is closed. I not only have my cargo bed LEDs, but also another 1 meter strip of LEDs for my under the hood lighting and a replacement LED in the dome light as well as footwell LEDs, all on the same circuit and everything works just fine (total amperage drawn is less than 4 amps).
    I prefer this method of utilizing the dome light ground specifically (instead of an isolated circuit and switch) so that the cargo lights would not be left on accidentally resulting in a dead battery, since I have a tonneau cover that would hide the lighting being on when the tonneau is closed or during daylight hours. Even if I were to forget to close the door, the lights shut off automatically after about 25 minutes.
    Also, keep in mind that the dome light itself has an independent switch to turn it on separately that uses a different ground wire. So, if you turn on the dome light manually or turn it off using the dome light switch, it will have no affect upon the LED strip. The LED strip will only light up and fade out when you open and close the doors.
    I hope this clarifies things for you. Let us know how your mod works out!
