LED Lighting Conversion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chan2565, Jun 14, 2016.
  1. Jun 2, 2018 at 12:24 PM
    #2901
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    :thumbsup:
    I only needed to loosen the set screw about 2-3 turns, not remove it. The mounting tabs are the same as the collar and that's what rotates about the shaft and main assembly. Just remember that once adjusted and inserted into the socket properly, the holes on the main assembly should be at 12 o'clock once the adjustment is done.
    So like this
    ToyoDrew and styner1989[QUOTED] like this.
  2. Jun 2, 2018 at 5:38 PM
    #2902
    banzaikid1
    banzaikid1 Well-Known Member
    Hey great review
    I was gonna order but do I need the CANbus?
    Thanks
    RobP62[QUOTED] likes this.
  3. Jun 2, 2018 at 5:45 PM
    #2903
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thanks. :thumbsup:
    No CANbus required. These are plug-n-play.
    banzaikid1[QUOTED] likes this.
  4. Jun 3, 2018 at 5:52 AM
    #2904
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    :cheers::bowdown:
  5. Jun 3, 2018 at 6:39 AM
    #2905
    cruiserhead
    cruiserhead Well-Known Member
    Curtice
    2018 TRDOR Cement DCSB. 1980 FJ40. 1978 FJ40
    for clarity, is the H11 kit used for both high and low beams? The "Tacoma page" on the Xenon website (http://www.xenondepot.com/toyota-tacoma-forward-lighting-s/104.htm) states H11 kit for low beam and H9 for high beam. But in the review above, it sounds like the H11 was used for both? I thought I read somewhere (maybe earlier in this thread) that they could be interchangeable, but I want to make sure :hattip:
    Thanks!
    Biwwip and RobP62 like this.
  6. Jun 3, 2018 at 7:36 AM
    #2906
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yes, H11 works in both. Some manufacturers list them as H8, H9 and H11 because all three are the same fitment.
    Biwwip and cruiserhead[QUOTED] like this.
  7. Jun 3, 2018 at 7:57 AM
    #2907
    cruiserhead
    Curtice
    Thanks!
  8. Jun 3, 2018 at 8:21 AM
    #2908
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    We all use H11 LED bulbs in both high and low with no problems
    Biwwip, RobP62 and cruiserhead like this.
  9. Jun 3, 2018 at 12:25 PM
    #2909
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    OG did some one say OG??
    ToyoDrew and RobP62[QUOTED] like this.
  10. Jun 3, 2018 at 6:41 PM
    #2910
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Ah, that makes sense! I'm used to seeing "free shipping in the contiguous 48" coming from US based companies, so I didn't think to look at where your business was located. Thanks for the clarification. :thumbsup:
  11. Jun 3, 2018 at 6:51 PM
    #2911
    ToyoDrew
    Texas
    Rob, great review!! Thanks for the numerous pics and great observations!!!! :cheers:
    I think this may be a first time that we've seen an LED bulb give us those light bars above the cutoff line (like the halogen bulbs gave us). Goes to show & confirm what @crashnburn80 mentioned earlier about how a millimeter change in the filament/light source can change the characteristics of the light output in any headlight. It's a total guess, but I bet that it might be because the Xenon Depot is slightly skinnier than the other LEDs.
    Now I really want!!! :drool: lol
  12. Jun 3, 2018 at 7:01 PM
    #2912
    ToyoDrew
    Texas
    Xenon Depot replied a few pages ago and confirmed that their H9 & H11 Xtreme LED Pro's are the same.
    The base for H8, H9, H11, & H16 are all the same...they just have different power ratings (when talking about halogen bulbs). Since LED bulbs have such different power requirements, many LED bulb manufacturers will usually use the same LED bulb (meaning, it's the exact same LED and base for each listing).
  13. Jun 3, 2018 at 8:41 PM
    #2913
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Thanks Drew, appreciate it.
    Yea, take a look at the pic below (I posted this in my last review) and if you look closely you can just about see the diodes on both sides of the shaft simultaneously. The thinner design of this bulb makes that possible. And I think as you say, that is what is producing those boxes.
    Oh, I did a preliminary temp test today but it was only 65 degrees and rainy so the heat sink temps after a 40 minute drive were a joke. My body temp was more.
    ToyoDrew[QUOTED] likes this.
  14. Jun 3, 2018 at 8:44 PM
    #2914
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Oh, and actually, I have seen those boxes before with another brand of LEDs but those cost $200 a set, and are not adjustable.
  15. Jun 4, 2018 at 7:49 PM
    #2915
    PNW Yankee
    PNW Yankee Active Member
    SR
    PNW
    2018 TRD OR DCSB Cement
    Alright @RobP62, you sold me on these over the Hikaris. Two sets of X11s for highs and lows ordered and definitely worth it with the discount currently. Hoping they are a good match with the TRD Pro fogs.
  16. Jun 4, 2018 at 10:01 PM
    #2916
    ToyoDrew
    Texas
    So the last LED conversion I need is to upgrade HBs (something that I rarely use, so it has been a low priority). But now that I'm moving to the corn fields surrounding my new base, I have been tempted to finally upgrade.
    After Rob's review, a really good discount, and then some great customer service with Steve at Xenon Depot, I have gone ahead and ordered a set of the H11 Xtreme LED Pro's as well!!
    :annoyed:
    I'll work on adding to Rob's review by doing providing some comparison pics with the Hikari's...so stand by in suspense! :D
    After that, I'll have to figure out which set is going to go into the HB's and the LB's.
    Lucifer1 and RobP62 like this.
  17. Jun 5, 2018 at 3:42 AM
    #2917
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    @PNW Yankee ,
    Excellent choice :thumbsup:, and don't hesitate to contact me, or Steve or Danny at @XenonDepot directly with any questions.
    One thing I failed to mention in my review is that all those photos are without my fog lights on.
    Rob
    Lucifer1 and ToyoDrew like this.
  18. Jun 5, 2018 at 3:55 AM
    #2918
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Drew,
    Very cool man! It's definitely a tough choice as there are benefits to having them in either position. My honest opinion though is that I would swap and run the Hikari's in the HBs and put the Extreme Pros in the LBs. Having that fanless design and those light boxes due to the adjustability in the LBs which are on more than not would be my rationale for the choice.
    Can't wait to hear what you think about these. Again, you've been here since the beginning and your opinions are highly regarded by me. :bowdown:
    Lucifer1 and ToyoDrew[QUOTED] like this.
  19. Jun 5, 2018 at 11:02 AM
    #2919
    ToyoDrew
    Texas
    Thanks Bud!
    I'm looking forward to testing these out. Like you said, there are benifits for these in either location, so it'll be a matter of what works best for my situation. Luckily for me, I am not adverse to doing a little drilling to make the Hikari's work in the HBs if need be. :)
  20. Jun 5, 2018 at 11:09 AM
    #2920
    XenonDepot
    XenonDepot Well-Known Member Vendor
    Guys,
    Thank you so much for trusting us with your vehicle's lighting.
    @RobP62 - Wow, what a review!! Thank you:thumbsup::thumbsup::thumbsup:
    @ToyoDrew - It was really nice speaking with you. Your H11 LED kit shipped out yesterday, so you should have it in the next day or so. Super excited to get your thoughts as well!
    RobP62 and ToyoDrew like this.
