led light bar on headache rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gordi, May 9, 2014.
  1. May 9, 2014 at 1:14 PM
    gordi
    gordi [OP] Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I am looking for pictures or opinions of single and double row LED light bars to put on my head ache rack to face forward on my truck.
  2. May 9, 2014 at 1:17 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    leb bar on the front bumper, spot hids or halogen above the cab.
    the led bar will perform much better on the front bumper. and if you need more light after that, thats when you need spot lights on the headach rack.
    IMO
  3. May 9, 2014 at 1:20 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    u think a single row or maybe a double on that rack will be to far back or the top of the cab blocks to much?
  4. May 9, 2014 at 1:23 PM
    4runnercaged
    cody
    arizona
    LOL
    well people usually put them in the back of the cab to avoid the windshield glare, and the lights in the back of the cab are normally used for distance. if you try and point it torwards the ground it will reflect off your roof and you will lose tons of light.
    led bars arent really meant for distance so the best location for a led bar is on your front bumper, and spots up high cause you use those for distance.
    either way will work though and youll be happy.
  5. May 9, 2014 at 1:30 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    does a single bar put out enough light or should i do a dbl?
  6. May 9, 2014 at 3:00 PM
    4runnercaged
    cody
    arizona
    LOL
    it really depends on what you consider "enough light" is.
    if you plan on doing 60 through the desert at night get a double
    if you plan on doing 10 mph through anything else get a single
    in my opinion
