LED Headlights.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Montanafreak, Jan 22, 2022.
  1. Jan 22, 2022 at 2:17 PM
    Montanafreak
    Montanafreak [OP] Member
    Derby
    Havre MT
    2017 Tacoma TRD Off Road DBL Cab
    Diamondback HD cover Diamondback Headache rack Diamondback ATV extension bars Wet Okele Neoprene seat covers 10 ply Hankook tires Fox 2.5 suspension 2021 TRD pro skid plate Rough Country MOLLE rack Full Bed
    I’ll keep this simple as there are a ton of posts but after an hour of reading I’m no closer to determining what to do. I’ve got a 2017 TRDOR. I HATE my headlights, dim, they seriously have a line where they cut off vertically. I want white, bright, see an elk a mile away headlights. I like the thought of LED’s. I run some aux lights off road but can’t on the highway. I need suggestions. What about the 2021-2022 factory lights? And I apologize if this had been done to death.
  2. Jan 22, 2022 at 2:24 PM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jan 22, 2022 at 2:26 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    First off, your lights are designed to have a vertical cutoff to prevent blinding oncoming traffic so you are not going to be able to get around that legally. The least expensive option is to do the H9 bulb mod. The most expensive option is to purchase the factory LED’s and then get the wiring harness adapter. Only problem with LED’s is if you are in snow county the lenses don’t get warm enough to keep the snow off.
    Chew and Montana_Actual like this.
  4. Jan 22, 2022 at 2:32 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Diode Dynamics (and others) offer HID conversion kits that keep the cutoff and factory optics pretty much unchanged but push out more light overall. It's less $ than a OEM LED assembly swap, more than a H9 lamp change. There are some poorly performing HID kits out there, though.
  5. Jan 22, 2022 at 2:41 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  6. Jan 22, 2022 at 2:42 PM
    MGMDesertTaco
    https://www.tacomaworld.com/threads/2020-tacoma-oem-led-headlight-megathread.592039/page-123
    Pick up a harness from Dave Easa
    https://www.tacomaworld.com/threads...ight-megathread.592039/page-122#post-26799092
  7. Jan 22, 2022 at 2:46 PM
    MGMDesertTaco
    Here's mine with ss3 Max's. I have a 2020 trd or grille arriving next week...
    vivid02 and mines like this.
  8. Jan 22, 2022 at 2:49 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    If you want to swap the housings you may be able to find a set of OEM LED Headlights used for under $1000 on eBay or on the 3rd Gen Parts Marketplace here on TacomaWorld. If you buy them new from the dealership, they'll cost you ~$1,300+.
    Right Headlight - 81110-04290
    Left Headlight - 81150-04290
    I have a set of Morimoto XB LED Headlights (version 2) and they're amazing. I think crashnburn80 says they perform almost as well as the OEM LED Headlights. I was able to purchase mine for $1,400. Here are some links to where you can purchase a set.
    Morimoto XB LED Headlights w/ White DRL - TheRetrofitSource - $1,431
    Morimoto XB LED Headlights w/ Amber DRL - TheRetrofitSource - $1,489
    jdjones likes this.
  9. Jan 22, 2022 at 2:54 PM
    MGMDesertTaco
    tacoshell88 and brandon78lusch like this.
  10. Jan 22, 2022 at 3:01 PM
    Volt
    Volt Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    The headlights are terrible. However, do check the aim of your headlights. They are easy to adjust. I installed the Toyota led fog lights and they help a lot when adjusted correctly. I always run the fog lights and the headlights together.
  11. Jan 22, 2022 at 3:18 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
  12. Jan 22, 2022 at 5:19 PM
    OCD TACO
    OCD TACO Well-Known Member
    2021 Tacoma TRD OFF ROAD
    Agree, I love mine.
    I’d much rather have the non-TRD PRO version though.
    The little bit of chrome wouldn’t bother me but the “TRD PRO” on my non-TRD PRO would.
    Chew, justin23 and Panchito V like this.
  13. Jan 22, 2022 at 5:54 PM
    MikeyMcFly
    I'm a Masshole
    Building a Broja
    Agreed, which is why mine are the non-Pro. That opens a whole other can of worms though.
  14. Jan 22, 2022 at 6:06 PM
    the_wanny
    the_wanny Overlanding is just you cosplaying being homeless
    콜로라도
    20 Taco TRD Off Road, 16 Lexus LX570
    DEPO now makes replacement LED headlights for the 3rd Gen Tacoma. I saw a set on Ebay so that's another alternative for those wanting to upgrade. Probably not as good as OEM, but they're at least reputable so in theory should be better than the countless various Mainland Chinese brands out there.
    https://www.ebay.com/itm/265336437576
    Personally I'm not too impressed with Morimoto so look out I might be unloading my V2 led headlamps for cheap soon lol...
  15. Jan 22, 2022 at 6:07 PM
    Montana_Actual
    Montana_Actual ;)
    This.
    Please, PLEASE, PLEASE, do not just swap your headlights for bulbs that are not meant to be put in those housings. Just spend the extra money for the whole setup and be done with it. If you plan on keeping your truck, it's worth the investment.
    No need to apologize. Sometimes it can be information overload. Take your time and do it right.
  16. Dec 16, 2022 at 4:37 PM
    ivan5105
    ivan5105 Member
    ivan
    San Juan, PR
    2016 Off Road Tacoma 4x4
    KDMax tuning,BP51,TRD intake and exh.,5.29
    Change to oem led headlight on my 2016 and is fantastic!
    MGMDesertTaco likes this.
  17. Dec 16, 2022 at 4:43 PM
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    I bought the $1500 morimoto xb's...my 04 camry halogens are brighter, not lying. seriously horrible down the road...oh blinding 10 feet in front of the truck or looking right at them. if you don't have hid get morimotos hid's...if you do...don't know. just make sure if you install a light bar it shuts off when the low beams are on.
    you'll still find lots of stuff with folks boasting of their luminosity so I can't explain it to you, but down the road led's just suck. I've never been disappointed with hid's and I hate when folks put on led light bars that aren't high beam only
  18. Dec 16, 2022 at 4:44 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    The ONLY two viable and legal options for you are swapping out the stock H11 bulb (which is a Long Life, read dimmer bulb) for the same H9 that is in your current high beams, or to buy the factory LED with the harness referenced above. The factory LED is a superior light all 'round and is just fantastic. As someone mentioned previously, proper headlight aim is paramount. The OEM halogens with H9's and aimed properly are actually pretty decent lights and the high beam portion is great. The 2020 LED is broader, smoother, brighter, whiter (about 6200Kelvin after they break in) and just feel right. They're really a small investment in safety.
  19. Dec 16, 2022 at 4:46 PM
    mushroom_man7
    mushroom_man7 Well-Known Member
    my 3 foot long LED bar will be waiting to melt your eyes lolcut off points are for incoming traffic.
  20. Dec 16, 2022 at 5:45 PM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    First things first: read this link
    http://danielsternlighting.com/tech/aim/aim.html
    Very carefully, and then find a suitable location to take the time to measure, (tape)mark and (if necessary) adjust the aim of your headlamps As They Currently Are.
    Next, of you have the halogen lamps, buy the same phillips H9 bulb that goes in your high beam, and use a pair of needlenose pliers to remove the small green plastic insert in the OEM H11 wiring harness plug. You can then install the H9 in place of the H11 bulb. You get about 70% more light Focused Correctly down the road vs a standard H11. A high performance H11 will reach about the same maximum distamce as the H9, but will have less light throughout the beam pattern.
    If you need more ligjt, them you need more light. Check out this thread: https://www.tacomaworld.com/threads/the-sae-j581-aux-high-beam-thread.696597/ in the lighting subforum. There are plenty of pics of some different lamps, including some excellent apples to apples test/comparison data by @crashnburn80. Theres only ao much that can be done to make real/effectice improvements to the factory ligjts, and them its time to turn to the aftermarket, and choose carefully what you choose to use.
