LED headlights on high beam
Discussion in 'Lighting' started by cruicad, Nov 23, 2014.
  1. Nov 23, 2014 at 2:10 PM
    cruicad
    cruicad [OP] Cruicad
    Andy
    Cary NC
    Recent Pre Runner purchace
    Just installed LED headlights and am very pleased with low beam performance, but there is almost no difference between low and high beam
    Any suggestions?
    I also have LEDs in the factory fog lights and these are useless.
    What I am trying to achieve is more light on high beam and am wondering if I could replace the fog lights with something else and rework the wiring so the fog replacements could come on independently or when high beam is selected.
    I understand that the current fogs are not wired to be on with high beams and for there intended purpose I understand why.
    Any help appreciated as always.
  2. Nov 23, 2014 at 4:52 PM
    Figg
    Figg Well-Known Member
    Houston
    12 TRD Sport 4X4
    Led bar up top, another tucked away in lower grille. 6" Pro Comp, 35's.
    If you REALLY want performance out of your lights you won't be able to beat a good set of projectors with quality HID bulbs. LEDs, or at least the ones on the market we use, have the brightness, but lack the throw of HID's and even a good set of halogens. I have a buddy with leds in his tundra and my silverstars look better, have good cutoff lines and plenty of throw on high beam. Unless you build the optics/reflectors specifically for that led you are installing you will not get everything it has to offer. Just my 2 cents.
    There is a thread on here for modding your fogs to be on whenever. Completely independent from your lights. I think it was called anytime fog light mod or something like that.
  3. Nov 23, 2014 at 7:04 PM
    xtyfighterx
    xtyfighterx Master Shredder
    Ty
    CDA Idaho/ Deadhorse Ak
    09 DC SW TRD OR/ 2015 tundra CM off road sr5
    3in lift, 5100s front and rear, OME 887 springs 2in aal, 285 75 16 Duratracs, mb 352 black wheels, white sport grill, derp'd lower valance, derp'd front toyota emblem white, tinted windows, tinted tail lights, trd shorty antenna, trd hitch cover, trd valve stem caps, trd neoprene covers, trd all weather floor mats, kenwood double din, stampede window visors, flyzeye interior leds, anytime fog light mod, flashlight mod, kool vue intake, LED dome light, Lund bug shield, TRD shift knob,front mud flaps removed, Debadged, truxedo roll up bed cover, led fog light bulbs, led parking light bulbs, led dtrls bulbs, led headlight bulbs, led back up light bulbs, led license plate bulbs, tinted license plate covers, 18" magnaflow muffler, 32in ebay, light bar, coverking neoprene resr seat cover, oem trd skid plate, trd decal on center caps, oem trd exhaust tip, blacked out pinch welds, color matched mirror covers.
    How many lumens are your bulbs?
  4. Nov 23, 2014 at 9:05 PM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Yeah yer best bet is to get some same size led spot off road lights and put those in if you're only using them as high beams. Then wire them up to a seperate relay with the high beam as the activating switch. That's how I have all my led bars wired up. Not sure how hard/easy it will be getting em in the factory fog light spot, but I've seen a couple guys do it. I believe rigid makes some mounts for their pods, but that is a bit pricey for just a little light. You should be able to find some round ones the same size and retro them in. Perhaps eBay. But you'll have to sift thru all the junk in there and find the good ones that you like.
    Edit: or just get a bumper led bar;) Because anything you get in the fog location really isn't going to be a whole lotta light to be used as high beams further down the road. They'll help, but I think you would be better off investing in spot lights, or an led bar. Even with all my led bars, I still wish I had more light thrown down range. I plan to get some 4.5" round led light cannons for that myself. I found a pair for $200 and will be mounting them on ditch light brackets. Anyways.. just my .02 and trying to help. Because I would rather you consider other options maybe even down the road if you can't afford it now. Because I have a feeling you want a ton of light and the truth is that you won't get much out of fog light replacements.
  5. Nov 29, 2014 at 9:03 AM
    cruicad
    Andy
    Cary NC
    Thanks for all the input. I will digest and determine what I should do. I am thinking a pair of spots on a bull bar may be a better bet or an LED light bar
  6. Nov 29, 2014 at 9:18 AM
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    The LED bar will put out a ton more light than the spots, i use that along with my high beams pretty much every time i drive at night
  7. Dec 1, 2014 at 6:27 AM
    BriteAssLEDs
    BriteAssLEDs Active Member
    Charlotte, NC
    What kind of LED headlights do you have? Several members of this forum have purchased ours over the last few months and have been very pleased with the results. Our headlights are 3,200 lumens per bulb. We also carry the same high-output 3,200 lumen bulbs for your fog lights and the two combined provide amazing light output. Maybe some of our customers will chime in.
  8. Dec 1, 2014 at 3:15 PM
    cruicad
    Andy
    Cary NC
    5000 on the headlights. Not sure on the fogs, but they are useless right now.
    Looking for the best way to get more light further out when on high beam. Low beam is very good for me.
  9. Dec 1, 2014 at 3:21 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Pretty wishful figures I have 100 watt H4's and they are less than 3000 lumens.
  10. Dec 2, 2014 at 4:32 AM
    cruicad
    Andy
    Cary NC
    Maybe that is 5000 for both. Sounds more likely now I think about it
  11. Dec 2, 2014 at 7:26 AM
    BriteAssLEDs
    Charlotte, NC
    There is not an LED kit on the market that is 5,000 lumens. A lot of the lower-end kits add the lumen output of both bulbs and advertise that as the output. That's probably what it is. Check out our kits. This thread has a lot of customer comments, pictures, video, etc. Let me know if you have any questions!
  12. Dec 2, 2014 at 7:38 AM
    Caduceus
    Caduceus Well-Known Member
    in the Bluegrass
    09 DCSB TRD 4x4
    Yeah, but LED's usually put out an unfocused blast of light, versus the more focused lights. You might actually get better use from spotlights vs a LED bar. I know with my bar, I'm seeing the tops of trees getting a lot of light too - and yes, it's aimed appropriately.
    Sure, it complements my high beams, but it could be better.
  13. Dec 2, 2014 at 3:09 PM
    NightProwler
    Harlan
    Maricopa, Az
    X2. Pretty much ALL light bars are disigned to give you a ton of light, but in the first few hundred feet. That's about it really, regardless whether they are spot or flood. Spot bars are a little more focused, but not by much. Floods just throw it out and dissipate the light everywhere. But beyond that few hundred feet, the light just gets washed out and is pretty dim down the road. Some really expensive bars such as vision x will throw farther. As well as the ones with the bigger 10 watt reflector bowls like I have. I have more light down range than most, but it's still not much. I still want more light the road up to about 1k feet. hence the want for the light cannons. I still have a hard time seeing objects (debris) in the road like tires and junk.
    I think op should get some cheap flood lights for his fogs. Then get some led light cannons:) I think that would work best. That way you have a bit more flood light in front of vehicle and to the sides, then a ton of light down range. If you're not wanting a ton of flood light that is.
  14. Dec 5, 2014 at 5:43 AM
    bmiller
    bmiller New Member
    Bryan
    Durham nc
    Overall you would be much happier with a bi-xenon retrofit. LED technology is on the way but isn't quite there yet for a plug and play application. I have a shop in Cary that does retrofitting. "Defiant Custom Rides" is off Evans Rd. near Weston Parkway. I am a dealer for TRS, and Morimoto. It always helps to have someone local to talk with in person about your options.
