LED H11 Low and Fog Lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Vasmastr, Jan 4, 2022.
  1. Jan 4, 2022 at 8:42 AM
    Vasmastr
    Vasmastr [OP] Have Tacoma, Will Travel...
    North County San Diego
    2016 Tacoma V6 3.5L TRD Sport
    Hey Ya'll,
    I installed the same LED bubs in my Low Beam and in my Fog Lights.
    The Fog Lights light up the night, The Low Beam light seems to be getting lost in the ether...
    On a 3 lane highway at night. From the center lane I can see the lanes to my left and right and about 20ft in front of me with both Headlight and Fogs on.
    With Fogs off, I can really see $#!+..?
    Any help would be appreciated..
  2. Jan 4, 2022 at 8:45 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
  3. Jan 4, 2022 at 8:46 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The H9 mod in the low beams has worked great for me. About the only time that the headlights get washed out is in a generally well lit area or when I am driving near other vehicles with high output lighting.
  4. Jan 4, 2022 at 9:04 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP....yank those LEDs out of the Low Beam. Go back to an OEM type bulb.
    An LED in a non-LED housing only results in beam scatter. An unfocused beam is useless.
  5. Jan 4, 2022 at 9:16 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I've had tremendous success using the bulbs specified by a professional lighting engineer employed by the largest automobile manufacturer in the world.
    philth, ceh527, Sinagua and 7 others like this.
  6. Jan 4, 2022 at 9:20 AM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I had a set of LED's from my Subaru and did not like them. Installed HID's and the light is much better and more full. I plan to install the RX350 HID projector this summer.
  7. Jan 4, 2022 at 9:21 AM
    eurowner
    eurowner Duke Sky
    Scoty
    https://www.danielsternlighting.com/tech/bulbs/Hid/conversions/conversions.html
  8. Jan 4, 2022 at 9:28 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I get what you're saying, but do disagree. The gov spec is so outdated with respect to lighting (FMVSS). It seems there is some recent update for adaptive lighting.
    IMHO, the H11s were a bad choice for output and the low beams were aimed to low from the factory.
    The funny part is the 2020+ LEDs. They are wicked bright when coming in the other direction. It is funny, but they appear like bad retrofits until the cutoff hits, which seems to be set pretty high. Seeing other factory LEDs, I would say that they are the brightest when oncoming? I haven't seen them from inside yet.
  9. Jan 4, 2022 at 9:28 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
  10. Jan 4, 2022 at 9:35 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Apologies... didn't realize Gen 3 thread...
    Use an H4... these came recommended and can see an improvement over OEM.
    https://www.amazon.com/Philips-RacingVision-Headlight-12342RGTS2-Upgrade/dp/B08KGH3JK8?crid=3KSFT5ZII0JLY&keywords=H4+racing+vision&qid=1641317627&sprefix=h4+racing+vision%2Caps%2C108&sr=8-12
    These are NOT the high output 90/100w with upgraded harness bulbs... I may go that route in the coming weeks. The Racing Vision above are nice for now.
  11. Jan 4, 2022 at 9:41 AM
    eurowner
    eurowner Duke Sky
    Scoty
    For the 2nd Gen, you are correct. 3d Gen Tacomas are Not H4.
    tonered likes this.
  12. Jan 4, 2022 at 9:41 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Can the stock housing handle a 90w bulb?
  13. Jan 4, 2022 at 9:44 AM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    GarlicFarts and tonered[QUOTED] like this.
  14. Jan 4, 2022 at 9:50 AM
    Toy_Runner
    Toy_Runner Well-Known Member
    99 4Runner SR5
    3" OME lift, heavy coils f/r 3/16" steel skids Modified Coastal Offroad diy bumper 5spd swap ('98 donor)
    Outdoorgb's recommendation is useful for the 2nd Gen Tacoma, but not at all for the 3rd Gen.
    A philips H9 (65w nominal rating, about 75w in practice) bulb is close enough to stock wattage for an H11 (55w nominal rating, about 60w in practice) bulb that it is fine on the OEM wiring harness. An H9 is also placing its filament in the same exact location as an H11, so the bulb will be properly focused by the projector low beams small reflector bowl.
    So many headlight bulb threads, it's a wonder how people miss the 200 page testing and recommendation thread...
    Bastek and tonered[QUOTED] like this.
  15. Jan 4, 2022 at 11:09 AM
    desmodue
    2016 TRD OR AC
    I do believe it is possible to obtain better/brighter/further lighting than OEM.
    I also believe less than 5% of those that stray from OEM do actually improve their lighting, 75% not only reduce lighting performance, but blind on coming traffic as well and 20% spend several hundred dollars to gain nothing.
    ceh527, AthensTac, Sinagua and 5 others like this.
  16. Jan 4, 2022 at 11:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I 100% agree with everything that you have said.
    I hope that I am in that 5% zone with the $16 that I spent.
    CaptainBart45 and eurowner like this.
  17. Jan 4, 2022 at 11:46 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Sounds like everything went exactly as expected (being serious). LEDs in halogen assemblies are not an upgrade, they are a significant downgrade and often a dangerously low performing one. IIHS has cracked down on all domestic LED headlight bulb sellers forcing them to recall their unsafe products as they are federally illegal. You obviously fell for some illegitimate brands misleading marketing. A basic $9 bulb significantly outperforms even the worlds most advanced replacement LED in a 3rd Gen headlight, and it sounds like you bought something that was far form the most advanced product on the market. If you want to correctly run LED, you need an LED assembly the best of which is the OEM LED headlights. See the headlight thread below, specifically post #2 and #3. Best option for the halogen assemblies is performance halogen bulbs.
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    The fact you say your fog lights 'light up the night' is also further evidence that the products you are running are a failed design that doesn't work correctly. Foglights shouldn't light up anything other than the the area immediately infront of your truck with sharp cut offs. Regardless of whatever company sold you these products, they deliberately sold you stuff that doesn't work. To correctly run LEDs in your fogs you must replace the entire assembly with one designed to use LEDs. You cannot put LEDs in your halogen fogs, designed for halogen lights, and get a good outcome. That requires halogen bulbs, not LED. To use LED you must use an LED assembly, and the LEDs are fully integrated in an LED assembly, not something you can remove. See the thread below, check out Diode Dynamics SS3s linked at the top.
    https://www.tacomaworld.com/threads/the-led-sae-j583-fog-pod-fog-light-review.554813/
  18. Jan 5, 2022 at 1:26 AM
    bamataco4x4
    bamataco4x4 Well-Known Member
    Derek
    2021 Tacoma SR 4x4
    I will disagree with the light snobs on here yet again. My under $40 LED's provide me MUCH better vision at night than the stock yellow light halogens. The difference is huge. No one has ever flashed at me or told me they were blinded by them. Tech has gotten better over the past couple of years, its not cut and dry anymore. https://www.gizmodo.com.au/2020/03/...dlights-work-and-others-just-blind-everybody/
  19. Jan 5, 2022 at 2:08 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Very nice. I totally agree!!!!
    bamataco4x4[QUOTED] likes this.
  20. Jan 5, 2022 at 4:41 AM
    Montana_Actual
    Montana_Actual ;)
    Lol. Ignorance is bliss.
    MikeyMcFly, Sinagua, Chew and 2 others like this.
