LED fog light brands
Discussion in 'Lighting' started by velodoc, Dec 5, 2020.
  1. Dec 5, 2020 at 9:51 AM
    velodoc
    velodoc [OP] Member
    I couldnt find a thread about replacing the OEM fog lights.
    What is the best brand for doing this with LED lights?
  2. Dec 5, 2020 at 10:00 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  3. Dec 5, 2020 at 10:01 AM
    velodoc
    velodoc [OP] Member
    Awesome. Thank you. I got lost looking.
  4. Dec 5, 2020 at 10:04 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Note all the updated products linked at the top of that thread. The Diode Dynamics SS3s are currently the top performers with several models to choose from.
    velodoc[QUOTED][OP] likes this.
  5. Dec 5, 2020 at 10:24 AM
    velodoc
    velodoc [OP] Member
    I'm looking for something that drops into the factory light mounts
  6. Dec 5, 2020 at 10:26 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    What year is your Tacoma? Most the products in that thread will fit the factory light mounts in a 12+ including the SS3s.
  7. Dec 5, 2020 at 10:26 AM
    velodoc
    velodoc [OP] Member
  8. Dec 5, 2020 at 10:27 AM
    velodoc
    velodoc [OP] Member
    2017. New here so sorry for dumb questions. Lol
  9. Dec 5, 2020 at 10:28 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The SS3s you linked above are the ones I was referring to. See the links at the top of the SAE thread you were pointed to for the reviews.
    velodoc[OP] likes this.
  10. Dec 5, 2020 at 10:55 AM
    velodoc
    velodoc [OP] Member
    I ordered the SS3s Pro (Driving). Exactly what i was looking for. Thanks man
  11. Dec 5, 2020 at 11:21 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Did you want fog lights or driving lights? Driving lights are a high beam pattern that cannot be used with vehicles ahead of you just like your stock high beams. Fog lights have cut offs so they can be run with oncoming traffic and are a low and wide pattern to aid in poor weather driving conditions. Your stock fogs are a fog light.
  12. Dec 5, 2020 at 12:00 PM
    velodoc
    velodoc [OP] Member
    Just changed the order, thank you for saying something, didnt realize that.
    crashnburn80[QUOTED] likes this.
  13. Dec 29, 2020 at 9:18 AM
    velodoc
    velodoc [OP] Member
    Super easy install and the lights are fantastic.IMG_6266.jpg IMG_6264.jpg IMG_6287.jpg
    Too Stroked and tclavell like this.
  14. Dec 29, 2020 at 10:14 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Nice looking truck and I'm glad you like your new lights. Speaking from personal experience with the DD SS3 fogs (I had the Pros and now have the Max's), proper aim is critical. I think you'll find that to get proper aiming with the Pros, you need to start with where you mount the pod itself within the supplied bracket before you install the unit. With the side bolts slightly loose, slide the pod all the way back in the bracket. Now, leave the bolts just tight enough so you can just move the pod up and down with your hand. Next, install the lights on both sides. With the truck on level ground facing a clean wall, move the lights all the way down in the mounts. Make sure the left and right sides are aimed level. Test drive the truck.
    I think you'll find that you're a bit high right now, but all the way down works almost perfectly. If it doesn't, move them both up just a bit. When you get them where you like them, tighten the adjustment bolts up. Enjoy being able to actually see at night and not bother oncoming drivers!
    crashnburn80 likes this.
  15. Dec 29, 2020 at 10:26 AM
    velodoc
    velodoc [OP] Member
    Excellent advice, thank you. I set the the adjusting bolts right in the center for now to begin with and then I will do what you say and start fine tuning them
  16. Dec 29, 2020 at 10:44 AM
    Chrischandler71
    Chrischandler71 Well-Known Member
    Athens, Georgia -Go Dawgs!!!!!
    2017 Tacoma TRD OR
    Lift, grill, tires, wheels
    I bought a set yesterday as well. They are backordered according to the website when i purchased them.. I got the sport in yellow.
  17. Dec 29, 2020 at 11:03 AM
    velodoc
    velodoc [OP] Member
    Cool! super easy to install, I went from the top and didnt have to remove anything from the truck. One video talks about popping off the grill or going from underneath and pulling back the fender shroud but i didnt have to do any of that.
  18. Dec 29, 2020 at 11:45 AM
    Chrischandler71
    2017 Tacoma TRD OR
    sweet, i will have to try that approach. I also just got an email saying they shipped. I wasn't expecting to get them for a few weeks.
  19. Dec 29, 2020 at 11:57 AM
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    Did you follow any video?
  20. Dec 29, 2020 at 12:05 PM
    velodoc
    velodoc [OP] Member
    I watched this video and did the pre-install the way they did it. I just didnt need to remove the grill like they did.
    https://youtu.be/-76P-Bw00Vg
