LED dome light not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Suggs12, May 2, 2016.
  1. May 2, 2016 at 7:15 AM
    Suggs12
    Suggs12 [OP] Well-Known Member
    Logan
    Johnson City, Tennessee
    2004 PreRunner
    3" Lift kit, Bilstein 5100 front and rear, 2881 EMU coils, 2" Deavers AAL, 18x9 KMC rockstar 1 wheels and 33" Nitto Terra Grapplers, Debadged, Grillcraft insert, clear corner and turn lights, 6k Leds, 30" Led light bar, 4 Pod fog lights.
    I recently purchased LED interior lights and installed them. They work fine when the truck is on but when I turn off my truck and open the door, they never turn on. I can turn the dome light from "door" to "on" and still get no lighting. Has anyone had this issue and know of a fix for it?
  2. May 2, 2016 at 7:29 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The 01+ trucks the dome dims when the truck is off it will do that with all 01 to 04 trucks if you just place a bulb in the socket.
    FirstGen Jer likes this.
  3. May 2, 2016 at 7:36 AM
    AdeptFox
    AdeptFox Active Member
    Jake
    Vermont
    2015 Access Cab 4x4
    You'll need to add some 1W 100ohm resistors. I used 2 for the dome light and 1 for each map light.
  4. May 2, 2016 at 8:04 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I went with these for my dome and map lights and I have no problems at all. No resistors and no flickering issues. If you have Amazon Prime, give them a try. Don't like em, send em back. I have nearly completed my switch over to LED and haven't needed resistors at all. I found that depending on the LED used, flickering can happen. Different LED suppliers, different results.
    http://smile.amazon.com/dp/B013FW3XCQ/ref=cm_sw_r_tw_dp_2V2jxb0Z7B0TX
  5. May 2, 2016 at 8:59 AM
    Indy
    Indy Master of all I survey.
    People change to LED to save energy, then add resistors that burn just as much energy as a regular bulb. Logic?
    Wyoming09 and Boost4pwr like this.
  6. May 2, 2016 at 9:15 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I think most people switch for the brightness and looks of led.
    CrustyTaco and Boost4pwr like this.
  7. May 2, 2016 at 10:59 AM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    I wonder if you can change a relay or something so you don't have to add resistance.
  8. May 2, 2016 at 11:50 AM
    Area51Runner
    You don't have to use resistors. That's what I was saying. It just depends on the LED. I've swapped out to led for maps, dome, headlights, reverse, converted signals to switchback LEDs and side marker lights are also LEDs. Aside from the OE flasher relay swap to prevent hyperblink I haven't done anything else besides change bulbs. :)
    I can't be 100% that it was the flasher relay but I don't believe it was. I had dim flickering in the dome until I tried different LEDs in those three - maps and dome.
  9. May 2, 2016 at 1:14 PM
    ClevSix
    IL/IA
    If you buy a LED like the one posted above it already has additional circuitry allowing it to be installed without having to worry about polarity as well as avoiding the need for added resistors. So yes, buying certian LED bulbs solves the OP's issue however, you are still using more power then necessary because of the added circuitry. I would think you could just as easily change a relay, bridge a circuit or something, similar to swapping the flasher, to get any LED to work without the dimming/flickering the OP is talking about. It may not be worth the time or cost but you never know... I'd rather the interior lights didn't dim when the truck is off anyway.
  10. Dec 18, 2017 at 9:48 PM
    Knoxdavid34
    Knoxdavid34 Stranger with candy
    David
    Nashville
    02 Prerunner 4x4
    TRD Off Road sticker. Not the whole package, just the sticker.
    Gonna try and bring this thread back to life. Is there anyway to stop the truck from dimming the dome light when the truck is off.
  11. Aug 23, 2020 at 11:27 AM
    bullmoosebell
    bullmoosebell Member
    2003 PreRunner V6
  12. Aug 23, 2020 at 11:40 AM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    The led light needs a resistor in the circuit. This is the one i used and everything works perfect. It even dims when I lock the truck.
    https://www.amazon.com/dp/B07HF47RV9/ref=cm_sw_r_cp_apa_i_hFRqFbXCASE3J
  13. Aug 23, 2020 at 11:42 AM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
  14. Dec 13, 2020 at 9:54 PM
    ElTacoRojo_
    ElTacoRojo_ 3.4Andy
    Chicago,Il
    2002 Tacoma Prerunner TRD Off-Road
    so the only way i can fix it is resistors and not relays?ive also bought one of the sylvania zevo bulbs but it just dims until i turn it,then it fully lights up
  15. Dec 14, 2020 at 5:55 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Short answer is yes. The system needs to see a bit of resistance in order to function properly. Easiest is to solder a small resistor from one end of the bulb to the other. Works like a charm.
  16. Dec 14, 2020 at 6:16 AM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    What ohm resistor did you use? I've been using one the ones I linked above but have to run it outside the truck because it get hot quick
  17. Dec 14, 2020 at 6:22 AM
    Synergy001
    Synergy001 IG: @pnwx.taco
    PDX
    00 ACLB -Daily, 16 DCSB -Adventure Rig
    Good to know this is normal with LED bulbs in the 1st Gen. I just noticed it a couple months ago. I thought I had a short somewhere so I left the dome lights on off instead of door to be safe lol! Now I need to find correct bulbs that won't dim.
  18. Dec 14, 2020 at 6:28 AM
    Knoxdavid34
    David
    Nashville
    02 Prerunner 4x4
    The only buld I'm aware of that won't dim is the old school incandescent bulbs. I domt think any of the led buld will work unless you put a resistor in the circuit but it easy to do.
    Synergy001[QUOTED] likes this.
  19. Dec 14, 2020 at 6:52 AM
    Synergy001
    PDX
    Yeah the incandescent bulbs for sure won't since it has more resistance than the led bulbs. I like the brightness and color of the led bulbs so I will try to find some with the resistor built in. If not I'll just add a brown/black/gold resistor or something.
  20. Dec 14, 2020 at 3:26 PM
    ClevSix
    IL/IA
    Another solution would be to add more led lights to the circuit. One could mount multiple lights around the cab all wired to the dome light.
