LED backup lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Nov 14, 2019.
  1. Nov 14, 2019 at 5:20 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    After much thread-viewing, I believe I have come to the conclusion that unless you upgrade housing, no bulb (LED or halogen) will produce a "brighter" output, just color.
    I hope I'm wrong, I see these JDM ASTAR LED 1200 lumens as the most popular option among Tacoma owners on the forum.
    Can anyone vouch for this? I'm looking for BRIGHT backup lights that won't melt or cause any other problems. I want to upgrade my OEM backup lights in my 2002 Tacoma.
  2. Nov 14, 2019 at 7:01 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    I repainted my housings silver since the paint was flaking off after 20 years. It came out pretty good and I put the led bulbs in. It definitely whiter than it was before. It's a little brighter and I haven't melted the housing yet.
  3. Nov 14, 2019 at 8:40 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I got these a few years back. Just these, no other modification to wiring or anything. LEDs have less amp draw, so I doubt you'd need to worry about the wiring.
    https://www.amazon.com/gp/product/B074SZY3L3/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    I don't have a light meter but I light up my neighbor's house across the street, whereas the stock lights I could barely see my fence.
    So I could really care less if this is an effect of the whiter light or the actual lumen output.
    I'm going to go out on a limb and say that if you want anything brighter (significantly) you need external LED pods. And if you do that, don't hook them directly to the reverse circuit - I feel bad enough if I'm backing up in a parking lot or near a street with these... Just wire to a switch.
    cruiserguy likes this.
  4. Nov 15, 2019 at 1:17 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have never had anything but problems with LED bulbs!!
    I no longer use them I just use LED lights.
    I do lots of backing up in the dark
    I have a project to install a light bar for back up lights just never got to it yet
  5. Nov 15, 2019 at 3:30 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I've used similar bulbs in the Cruisers and those throw some serious light.
    jbrandt[QUOTED] likes this.
  6. Nov 15, 2019 at 3:46 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    LED's will never get remotely hot enough to melt anything. My 200W LED light bar heat sink barely gets warm to the touch when it's on for a long while. That's the beautiful thing about LED, they can produce great light output without excessive heat.
  7. Nov 15, 2019 at 10:43 AM
    Cutter_
    Do these just plug into the existing housing?
  8. Nov 15, 2019 at 12:20 PM
    jbrandt
    Justin
    yep
    IIRC, they may be polarity specific, so if you plug them in and it doesn't work, flip it around and it should be good to go.
  9. Nov 15, 2019 at 2:34 PM
    itsmerandy
    itsmerandy Well-Known Member
    Kentucky
  10. Nov 15, 2019 at 2:48 PM
    jbrandt
    Justin
    You only need a resistor for the turn signals. Backup lights you shouldn't be adding anything.
  11. Nov 15, 2019 at 2:51 PM
    itsmerandy
    Kentucky
    You're right! I needed them for my turn signals. Thanks for correcting me.
  12. Nov 15, 2019 at 3:34 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    WRONG !!! If you replace the turn signals with LED all you need is LED compatible flasher, not a stinking resistors.
  13. Nov 15, 2019 at 3:39 PM
    jbrandt
    Justin
    the resistors are a dumb bandaid fix, but they do work. But you're correct that a proper LED flasher is the best method to prevent the hyperflash.
  14. Nov 15, 2019 at 4:15 PM
    RysiuM
    Rysiu
    The only reason I did not put LED in blinkers in my 2012 4Runner is that there is no LED compatible flashers for that truck. I have a bunch of resistors that were included "free" with some LED bulbs purchase, but I would never put them in any of my cars.
  15. Nov 15, 2019 at 4:19 PM
    jbrandt
    Justin
    Yeah, the 5th gens use a lot more solid state circuitry, so that makes it hard to change stuff around.
    But it's not like resistors are going to make your truck explode.
  16. Nov 15, 2019 at 4:35 PM
    RysiuM
    Rysiu
    They defeat the main purpose of installing LED: less current, less stress on all connectors. The LED durability is not an argument here as blinker bulbs life is very, very long (comparing to headlight for example) - I have that truck since 2013 and after 60k miles it has all original blinker incandescent bulbs (I have LED backup, LED front markers, LED interior, Osram LED DRL/FOG, LED bar and custom made LED rear fog lights). I'd love to have all LED (except headlights of course) but because of the flasher I can't put LED blinkers and because of bad experience with "dual intensity" tail/stop bulbs (in Tacoma they had a current leak) I still have incandescent tail/stop bulbs.
    In Tacoma I have all LED (except headlight of course) and no stinking resistors. Welcome to my OCD :rofl:.
  17. Nov 15, 2019 at 4:42 PM
    jbrandt
    Justin
    Oh I understand, I don't really like the idea of resistors either, but if that's your only option and you like the LOOK of LEDs, go right ahead, you won't kill anything.
    ONLY LEDs I have are the backup lights. Don't see a need to do any of the others. Maybe once (if) my turn signals blow I'll go LED. So far they've lasted 15+ years.
    The ONLY advantage to the LEDs (relevant to this thread) is their brightness. That's the only reason I switched. I don't need super bright turn signals or brake lights. I've never gotten rear ended because they couldn't see my lights. (I did get rear ended by a kid on his phone, though)
  18. Nov 15, 2019 at 5:05 PM
    cruiserguy
    Elijah
    SEKS
    Kinda off topic, but someone like you can appreciate this, when I got my Tacoma, 3 years ago, the headlight bulbs were the original Koito bulbs. I was shocked. Oem spec stuff is built for best longevity and best reliability, not necessarily best 'performance'.... Which is why I love Toyota, they're the best at it.
    Can you believe those Koito bulbs???! They were 16 years old. I actually saved them for spares as they still work. Just not super bright like my Osrams :cool:
    RysiuM[QUOTED] likes this.
  19. Nov 15, 2019 at 5:11 PM
    RysiuM
    Rysiu
    That's not the case for most of LED bulbs. There is no significant difference in brightness even in quality LED bulbs - the physics don't allow that to happen at least with existing technology. It's a long explanation, but I can provide if you have patience for that :). The major unquestionable benefit of having LED bulbs is low current draw. It is good for 20+ years connectors and contacts (they are not gold unfortunately so they age). And resistors just ruin it.:annoyed:
  20. Nov 15, 2019 at 5:12 PM
    BiNiaRiS
    BiNiaRiS Well-Known Member
    Portland, OR
    outside of it being an extra step, is there something bad about running a resistor? you make it sound like it's bad for the truck, lol.
