Leaves & trash in blower motor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by El Cid, Oct 23, 2013.
  1. Oct 23, 2013 at 6:49 AM
    El Cid
    El Cid [OP] Well-Known Member
    South Carolina
    11 Access Cab, 4 cyl, man., SR5
    I park my 2011 Tacoma near an oak tree and it only has 5,000 miles on it. The dealer found leaves, trash, etc. covering the cabin filter and said it was also in the blower. Some of the stuff was from a tree 200 feet away. They had to drop the blower and clean it out.
    Why is trash getting into the blower?
    Anything that can be done to prevent it, short of a truck cover?
    Thanks
  2. Oct 23, 2013 at 6:53 AM
    Large
    Large Red
    I've had a couple of small leaves and maybe a piece of a napkin in there, I just clean it out and keep truckin'
  3. Oct 23, 2013 at 7:35 AM
    Cain
    Cain Well-Known Member
    Southern California
    2012 Tacoma
    Chrome don't get you home
    I found debris in mine as well I parked in a covered area
  4. Oct 23, 2013 at 8:17 AM
    trint99
    trint99 Well-Known Member
    Trint
    Conifer, CO
    2011 AC 4x4 TRD-OR
    4xInnovation sliders,5100 leveling lift,Anytime rear camera mod
    Was driving my wife's Corolla the other day when the there was a weird noise from the glove box and the airflow from the vents just quit.
    Got it home and took it apart, it had four Starbucks napkins sucked into/around the filter. They had been in her glove box. When you open the recirc vent, it sucks in just a couple inches above the open top of the glove box.
    :facepalm:
    Absolutely no baffles or anything to guard stuff getting sucked in. No doubt the Taco is the same. And I'll bet the fresh air is similarly stupid. Looks like a good place for a cheap mod! Hmmm.
  5. Oct 23, 2013 at 8:20 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    The debris that gets in mine is nothing like my old Ranger. I used to have pine needles that would assault anyone in the cab. They came out the vents like blow darts.
  6. Oct 23, 2013 at 8:26 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    So if you didn't like someone you would just close your vent and turn it on high? :D
  7. Oct 23, 2013 at 8:39 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    That sounds kind of cool. Any in-laws you don't like? Have them sit there.
  8. Oct 23, 2013 at 9:04 AM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    I wouldn't have thought they would get that far in there. I try to avoid parking under trees in the fall. When I can't avoid it, I take the shop vac and clean 'em out pretty regular. I don't like the idea of them getting down into the fenders and sitting there holding moisture and promoting rust. I know I can't get them all, but I can damn sure try.
  9. Oct 23, 2013 at 9:23 AM
    BamaToy1997
    Bill
    Navarre, FL
    It is not Toyota exclusive, I can tell you that. I have seen this in every model of vehicle I have worked on. Unfortunately the fresh air intake is always not optimum. It is a draw at some point between filtering out stuff, and allowing good airflow with reduced noise. Mercedes experimented with a very restrictive fresh air intake system on one of their lower production models. It REALLY turned into a fiasco because sure, it filtered out EVERYTHING, but the restriction of the design to airflow caused extreme noise when the fan was on high.
  10. Oct 23, 2013 at 9:25 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    Just pipe it to the fender like the Air intake :notsure:
    I've seen someone, may have been the guy that piped his air intake to the cowl put some mesh under the cowl. Solved his problems.
  11. Oct 23, 2013 at 1:15 PM
    BamaToy1997
    Bill
    Navarre, FL
    Maybe I am wrong, but I thought that guy piped his ENGINE intake to the cowl, not the AC fresh air intake. But I may have read a different thread.
  12. Oct 23, 2013 at 3:03 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    That's what I meant.
  13. Oct 23, 2013 at 3:56 PM
    BamaToy1997
    Bill
    Navarre, FL
    Right, but here they are talking about their fresh air intake drawing in stuff, and trying to figure out a way to prevent it..... That is what I was pointing out. Or were you trying to make a different point and I am just blind as a bat. Hahaha.
  14. Oct 23, 2013 at 4:02 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  15. Oct 24, 2013 at 6:12 AM
    El Cid
    South Carolina
    I had a '97 Ranger that I parked in the same location for six years and never had a problem with it. Don't recall if it had a cabin filter, but it probably did and I always change/check them annually in all my vehicles.
    Checked Tacoma out yesterday and removed the new cabin filter. Had leaves on it after less than 24 hours.
    I guess the big round "hole" that sits below filter box is the blower?
    Checked out the cowl(?) area grate and dealer had not cleaned it all. Why clean blower and put in new filter and not clean the cowl grate? Vacumed all around it out.
    Personally I think the problem is that the holes in the cowl grate are too big. Too small and they would get blocked, but these things are big and lots of them.
    Thinking of maybe getting some plastic screen wire and cut a strip to lay over cowl area when parked at home. Probably slide one side under hood and other under wipers.
    Also, parked it facing away from trees.
  16. Oct 24, 2013 at 6:33 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    It was 2 points. 1) put mesh under the cowl. 2) pipe the AC air intake to the fender.
    Got snorkel! :rofl:
  17. May 25, 2015 at 6:33 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    Sorry to revive a dead thread, but are there any tutorials on cleaning out the vents?
