Learning fishing knots.
Discussion in 'Boating & Fishing' started by aficianado, Mar 16, 2021.
  1. Aug 30, 2022 at 10:37 AM
    #41
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    just to add. i bought a tube of that line glue the fly fisherpeople use. i glue my knots for added security.
    my FG game is strong now, but i still love the Alberto. the Alberto is fatter but shorter. FG longer but thinner. (<---there is a penis joke in there somewhere)
    Thatbassguy likes this.
  2. Aug 30, 2022 at 11:09 AM
    #42
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    This is just me, but if I’m using a join knot it’s because I want to be able to wind that knot through the guides. Otherwise I can just use a barrel swivel. There are swivels made to pass through guides but really only on the largest rods.
    Anyway, the Alberto is almost twice as fat as the FG. Also, if you tie an FG properly it’s the strongest knot (which kind of blows my mind). So I don’t choose an Alberto because the FG is much less likely to get hung up on the retrieve. I also think the FG is easier to tie on the boat, I’ve found a quick way to do it.
    And who knew a knot conversation could give birth to dick jokes! TW really does harness the full creative energy of its members. So to speak.
  3. Aug 30, 2022 at 11:46 AM
    #43
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Hook78 and Thatbassguy like this.
  4. Aug 30, 2022 at 8:04 PM
    #44
    Lava-road
    Lava-road Well-Known Member
    2019 trd-off road
    Hard top camper...many more to add+
    It is good to learn new knots. You also can add bigger guides? It just makes the rods heavier.
    I have a casting rod (one of a kind) with Aflco roller guides and a Aftco tip (large ring) for casting. Ulua fishing rod. 60-80lb class , shoreline fishing. We toss 9 oz sinkers with wire for anchors.
    that San Diego reminds me of a clinch knot. Which I have been using for over 40 years….so similar.
  5. Aug 31, 2022 at 9:32 AM
    #45
    chuam
    Marcus
    San Diego
    Definitely similar but stronger. You can also double up the line and tie the same knot to max it out.
  6. Aug 31, 2022 at 10:06 AM
    #46
    capttommyz
    capttommyz Member
    Tommy
    2022 White Tacoma SR5 4x4 Double Cab
    Use the Albright. Better knot anyway.
  7. Aug 31, 2022 at 10:26 AM
    #47
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    For small pound test I much prefer uni to uni, much easier to tie than the Albright, much slimmer, never had one break. To me the Albright is a purely high pound test offshore fishing knot. Besides, for that purpose I prefer the FG.
    capttommyz[QUOTED] likes this.
  8. Aug 31, 2022 at 10:40 AM
    #48
    Lava-road
    2019 trd-off road
    For heavy fishing lines, Ulua style of fishing in Hawaii, 80 lb main line to leader line 200 lb mono. It is common to use the Albright knot with the Bimini twist knots. Create for joining two different line sizes. Casting from shoreline.
    Please watch a few YouTube videos of Hawaii Ulua fishing .
  9. Aug 31, 2022 at 10:44 AM
    #49
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    i use 4 or 5 different knots
    i don't even know the names of them
  10. Aug 31, 2022 at 11:44 AM
    #50
    Lava-road
    2019 trd-off road
    I gotta laugh at that, most of only use a handful of knots fishing. Yes I do not know all the names either.
    As long as it works for us, the name is not important.
    I do enjoy reading and learning new knots for fishing. But the main goal “it works” and simple to use.
    The Albright knot and Bimini twist is not a easy knot for beginners, once you master it. You will never use anything else. Over 40 years using this theses knots. Knotting to it!
    jon_elc likes this.
  11. Aug 31, 2022 at 1:32 PM
    #51
    chuam
    Marcus
    San Diego
    I used to use the bimini to albright all the time for connecting spectra to mono/fluoro. I switched over to the uni to uni for the lighter stuff (this knot works way better than I realized. Had a 130lb bluefin on for 4.5hrs on 30lb test and it held) and make my own windons now for the heavy stuff. Loop to loop connections are superior and cast better through the guides for my applications.
    Hook78 likes this.
  12. Aug 31, 2022 at 1:51 PM
    #52
    Lava-road
    2019 trd-off road
    Thank you for the Uni to Uni knots. Hawaii shoreline fishing species have a wide range of fishing lines and gears. I do use lines from 6lb to 80lb mainlines.
    This is a great knot to know and use. Not only for joining two lines ,but for tying hooks , lures, swivels.
    So close to the clinch knots.
    I read that the clinch knot is NOT recommended if tying to any “braided lines”. Be aware.
  13. Aug 31, 2022 at 3:08 PM
    #53
    chuam
    Marcus
    San Diego
    If tying straight braid to a lure/swivel, etc. I use a double San Diego: https://www.youtube.com/watch?v=WFMR0a4MZ8g
    The improved clinch will slip if tied directly with braid
  14. Sep 1, 2022 at 2:16 PM
    #54
    Lava-road
    2019 trd-off road
    Good to know,. I just switch over to braided lines in my lite spinning reels. Cast farther ,can carry a heavier line weight. I also use those spray to keep the lines tangle free.. Thank you
  15. Jul 21, 2023 at 9:50 AM
    #55
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Pretty old thread but fitting for my questions...
    New to the fly fish world. My rod reel combo I just received doesn't have a factory loop at the end of the fly line. I ordered new leaders which come with the loop.
    • Can I do a Perfection Loop on my fly line? Or is there a better loop knot to make here ?
    • With a permanent loop on the fly line, I would then use a loop to loop knot for quickly changing out leaders in different situations. Would this be acceptable ?
  16. Jul 21, 2023 at 10:01 AM
    #56
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    For your consideration:
    https://troutbitten.com/2019/03/06/...taching-your-leader-to-the-fly-line-this-way/
  17. Jul 21, 2023 at 10:19 AM
    #57
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    This trilene knot is simple and effective for freshwater Midwest fishing.
    Typically will snap your line or bend the hook before breaking the knot.
    jon_elc likes this.
  18. Jul 22, 2023 at 2:33 PM
    #58
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    If you are bound and determined to use the loop to loop connection for a leader then tie one on with a nail knot. When it's time to use another leader just leave the old leader on, clip the butt about 6" long and tie a perfection loop in it. There are a multiple leader to fly line connection gimmicks out there, the little metal eyes with barbs on the shank, the plastic footballs that you slide on and tie overhand knots, the welded loops etc. etc. None of them work better than the old nail knot and most all of them hang up in the tip top line guide. I used loop to loop for some years and got tired of them hinging and hanging in the rod tip, went to nail knots exclusively. Takes a couple minutes to tie and no issue to do it streamside. Good luck with whatever you choose.
    And for bass fighing with hard tackle I use palomar knots mostly. Fly fishing for trout I use pitzen knots and double pitzen to tie tippet on.
    themcnertney likes this.
