Learn From My Mistake - Replace Plastic Oil Filter Housing With Metal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by loveinyourmouth, Apr 24, 2018.
  1. Apr 24, 2018 at 7:14 PM
    loveinyourmouth
    loveinyourmouth [OP] Well-Known Member
    2016 Tacoma DCSB SR5 4x4 - Red
    Bone stock
    TIFU by trying to change my own oil. I've changed my own oil on all my cars growing up, so after the free oil changes ran out on my shiny new truck, it was time to change my own oil again.
    I purchased a toyota-shaped oil housing wrench from O'Reilly Auto Parts and it seemed to fit very snugly. First I tried to remove the housing with a regular ratchet with zero luck. Next I used a breaker bar to get some leverage on this bad boy, but still didn't have luck (are you kidding me?). I thought the housing was metal, so I decided to try and use my impact drill...
    Oil started coming out of the housing, so I initially thought everything was OK. After further inspection, one of the tabs broke off of the plastic-ass oil filter housing, exposing the inside of the housing to the world.
    So I've concluded any number of the following:
    1.) The dealership put the housing on way too tight.
    2.) The plastic housing is a piece of garbage.
    3.) I'm a stupid idiot for not being patient and sticking with the breaker bar (c'mon I didn't want to bust my knuckles open!)
    Bottom line... order one of these metal housings made by Toyota and live worry-free for the life of the truck. I have one being sent via 1 day shipping.
  2. Apr 24, 2018 at 7:16 PM
    growyourmind86
    growyourmind86 Well-Known Member
    2017 trd Tacoma
    Yes I also had mine on real tight to. I had to use a lot to get it off. People keep saying there is a tab that holds it on, but I do not have a tab on mine. It just was super tight.
  3. Apr 24, 2018 at 7:16 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Dealership must have way overtightened it. The torque spec is stamped right into the Housing and its only like 18 Ft Lbs.
  4. Apr 25, 2018 at 1:29 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Is that metal or plastic? I can't find the material on the site.
  5. Apr 25, 2018 at 1:42 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Is the filter housing a direct fit? I'm just making sure because I remember reading some people had to fabricate them to make it fit. But that was a long time ago, so I just wanted to see if this is a direct replacement.
  6. Apr 25, 2018 at 1:49 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I've been doing cartridge oil filter changes on Toyota engines since 2004. I've never damaged any plastic housing.
    First...make sure you're using the Toy640 housing wrench. Regular filter cap wrenches that almost fit aren't good. You risk damaging the housing.
    Secondly....and very importantly....the housing is sealed via an o-ring not a gasket. Therefore there is NO NEED TO TORQUE THE HOUSING DOWN TIGHTLY. A light snug is all it needs.
    TRDSport10, ka3ak, Vmax540 and 24 others like this.
  7. Apr 25, 2018 at 1:55 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    BRFab, Speedbird, max_o and 12 others like this.
  8. Apr 25, 2018 at 2:24 PM
    shakerhood
    Southern Ohio
    That is the same one I use too.
  9. Apr 25, 2018 at 2:28 PM
    Plain Jane Taco
    USA
    Bought it many years ago. It fits all Toyota/Lexus cartridge filter housings
  10. Apr 25, 2018 at 2:47 PM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Guys, its plastic and has an o-ring. Hot, cold, hot, cold, hot, cold. That plastic and the O-ring will most likely be tight even with oil on it and the canister. I have filters at work that are almost impossible to get off and I only tighten them by hand. It happens and probably not because of over torque.
    pdeinc, BRFab, gilligoon and 9 others like this.
  11. Apr 25, 2018 at 2:48 PM
    Plain Jane Taco
    USA
    If you're a DIY'er you need to buy one. Except for the old 1NZ engine still found in the current Yaris....all other Toyota/Lexus in North America use cartridge filters. Not sure about the Mazda produced Yaris iA though. Don't know if it's a spin-on or a cartridge
    All GR, AR, 2ZR and UR engines use a cartridge filter. That accounts for about everything you can buy in N. America these days.
  12. Apr 25, 2018 at 2:50 PM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    Best Slope CO
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches and MESO stuff
    How many ugga-duggas is that? 19 year old Toyota service techs working the oil change line need to know.
  13. Apr 25, 2018 at 2:53 PM
    loveinyourmouth
    Bone stock
    Well I won’t have to worry about over-tightening, because I’ll be performing all of the oil changes moving forward. Unfortunately, the dealership over tightened the housing on my last oil change, so I had to deal with this problem.
    Thanks for the advice!
  14. Apr 25, 2018 at 3:04 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    That's common, I swear Hercules tightened the housing on my wife's corolla, I needed to use a breaker bar and hammer to remove it.
    shakerhood[QUOTED] likes this.
  15. Apr 25, 2018 at 3:37 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Those idiots couldn't put access door on skid and oil change together. Actually started removing my skid. Then because I didn't trust them and was watching told them to open the access door.
    They just said 'oh ok thanks'
    I then went to the service rep and requested a certified tech inspects because they couldn't even figure out the access door. Same thing the pro has lol.
  16. Apr 25, 2018 at 3:48 PM
    Shellshock
    Iowa
    Just had the same issue with mine. Previous oil changes were done at the dealer and the filter was on so tight I couldn't get it to come loose or the drain cap. I'm pretty sure they just stuck a 3/8" into the drain cap and tightened the whole thing on. It was WAY beyond the 20 ft/lbs for the filter and 10 ft/lbs for the cap.
    Mine is now replaced with a metal one and not going back to a dealership.
  17. Apr 25, 2018 at 4:02 PM
    JMag
    JMag Well-Known Member
    Jonathan
    Baton Rouge
    2017 TRD Sport Blazing Blue Pearl
    I’ve always tightened it as much as I could by hand and that’s it. It’s gonna snug itself up more from thermocycling.
    oconnor, Freegolf and Cole man like this.
  18. Apr 25, 2018 at 4:23 PM
    Cole man
    Cole man I like a clean taco....
    Paul
    Bluegrass state
    2017 tacoma SR 4x4 V6 MGM
    Stock so far
    I dont think ill even use the free oil changes from the dealer. I dont have much faith in them. I enjoy doin my own oil and what ever else i can do on my stuff.
    IronratPR, hfjeff, WVTacoma08 and 5 others like this.
  19. Apr 25, 2018 at 4:27 PM
    Freegolf
    Denver
    This man understands.
  20. Apr 26, 2018 at 7:30 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    This just dropped to $17.02!! Yesterday it was about $30 or so! Free shipping!!! Mine is on the way.
    nightcrawler likes this.
