Leaking Supercharger?
Discussion in 'Performance and Tuning' started by WOODEX M.E., Aug 9, 2015.
  1. Aug 9, 2015 at 11:04 AM
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    Hey guys, it looks like i have a leak coming from the front of my TRD supercharger. Any expirience on this situation? How much of a deal is it? I still have 2k left on my warranty but i feel the dealership will weasle out since i installed a cold air intake a couple months ago. Just curious, but if toyota wants a ton of money and doesnt cover it under warranty, i may just take it out of the truck and sent it to steigmeyer for a rebuild and some other things. Unit has about 51k on it. Any opinions?
  2. Aug 10, 2015 at 3:44 PM
    WOODEX M.E.
    Corey
    Maine
    Nothing? Nothing at all......
  3. Aug 11, 2015 at 9:44 AM
    nine3
    nine3 Well-Known Member
    Seattle, WA
    14 DCSB TRD OR Supercharged MT
    Looks like the seal on the input shaft might be leaking. You might want to try and clean it off and see if it comes back (just to rule out if it's engine oil that got on it during an oil change). How long has it been there?
  4. Aug 11, 2015 at 4:39 PM
    WOODEX M.E.
    Corey
    Maine
    Its been there for about 2 - 3 months and looks like it has slowly grown. I just took it in to toyota and they put a dye in my engine oil to see if that is coming from somewhere. I think its the input shaft as well, but i forgot to say they when i was talking to toyota. Ill be back in about 2 weeks for a follow up.
  5. Aug 11, 2015 at 7:30 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  6. Aug 12, 2015 at 3:03 PM
    WOODEX M.E.
    Corey
    Maine
    I thougt it was the snout seal too from initial inspection. Any hard prooven way to determine that? Toyota said they couldnt find anything wrong. But i have about 2,500 miles left on my warranty.
  7. Aug 31, 2015 at 3:54 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    update?
  8. Aug 31, 2015 at 3:58 PM
    WOODEX M.E.
    Corey
    Maine
    They cleaned the crud off and told me to come back after a few hundred miles or so. I have checked it sense and have not seen any come back? So either it was something else or its out of snout oil. I know it wasnt checked because it has tamper proof paint mark on the plug still. Ill be going back in next week just before the the 60k mark.
  9. Aug 31, 2015 at 3:59 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Prob leaking from the snout seal for a little bit but stopped?
  10. Aug 31, 2015 at 4:50 PM
    WOODEX M.E.
    Corey
    Maine
    Haha i guess. I have a feeling im going to have to push to get the local Toyota to actually check it.
  11. Aug 31, 2015 at 6:23 PM
    VolcomTacoma
    Jeff
    NorCal
    If you still have your stock intake, throw that back on and take it in to them or a different dealer and have them look into it seriously.
  12. Aug 31, 2015 at 6:28 PM
    WOODEX M.E.
    Corey
    Maine
    i may just have to.
  13. Aug 31, 2015 at 6:43 PM
    VolcomTacoma
    Jeff
    NorCal
    I would highly recommend you throw it back on, go to a different dealer and have them look into it. Then you have 100% power behind you with a 'voided' warranty
  14. Sep 15, 2015 at 8:01 PM
    WOODEX M.E.
    Corey
    Maine
    Just an update. I am at the end of my warranty, well actually i had 300 miles left, and i installed the urd supergrip pulley. Once i pulled the pully off, behind it on the supercharger snout was clean and dry as a bone. So the mystery continues, but it was not the charger snout.
  15. Sep 15, 2015 at 8:08 PM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    I've used ZZP for more than 10 years. Never had a complaint with their service.
  16. Sep 15, 2015 at 8:09 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    how you like the new pulley?
    i was thinking bout doing that soon
    easy install?
  17. Sep 16, 2015 at 8:02 AM
    WOODEX M.E.
    Corey
    Maine
    Yeah the install was about 1/2 hour minus the extra time it took me to get my skid plate off. The bolts were so rusty one wouldn't come off even with oil, so it broke. The pulley is better but its not like a throw you back difference. I can feel a difference, but barely. Mostly I notice that the engine is more responsive throughout normal driving midrange, rather than an all out performance gain. Also it looks sweet. I say its worth the $100.
  18. Sep 16, 2015 at 3:36 PM
    Blacktaco2042
    wisconsin
    howd you install it
  19. Sep 16, 2015 at 4:13 PM
    VolcomTacoma
    Jeff
    NorCal
    By following the included instructions
    WOODEX M.E.[OP] likes this.
  20. Sep 16, 2015 at 6:26 PM
    WOODEX M.E.
    Corey
    Maine
    Yep followed the instructions to a T and it worked flawlesly.
