Leaking gear oil from passenger cv
Discussion in '1st Gen. Tacomas (1995-2004)' started by Allex95, Aug 7, 2020.
  1. Aug 7, 2020 at 8:23 PM
    Allex95
    Allex95 [OP] Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    Seem to be leaking diff fluid from cv?
    5B22CD3E-1F47-4F3D-B2CC-CB6704A2DC4D.jpg 3128276B-2402-43A8-BD72-FD7514FBECDE.jpg
  2. Aug 7, 2020 at 8:35 PM
    Ccrowe323
    Ccrowe323 Well-Known Member
    Cory
    Florida
    2001 Tacoma 3.4 DC 5speed TRD OR
    Ehh, it doesn’t look very wet to me. Are there actual drips that accumulate?
    I have yet to replace my CV seal on the passenger side as I must have bumped it replacing my CVs and it’s been leaking for the past year. Drops accumulate and I’ve just topped it off every couple months. It usually only takes one or two pumps and it’s back to full. Nothing major, I am planning to replace both side here soon though as I can’t trust it on a long trip like that. I’ve barely driven the truck as well for the past 8 months. But based off your pics I would say you don’t seem to be really losing much at all. Maybe just pop the fill plug off and give it a pump and see if it is low or now. I would doubt it would take more than a pump or two to get her back full unless it’s been leaking a long time without notice
    andrewtheadventurer likes this.
  3. Aug 7, 2020 at 8:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Are you sure its not dropping from above:? I had a leak I was sure was the CV, it turned out to be the oil pressure sender.
  4. Aug 7, 2020 at 8:50 PM
    Allex95
    allex
    There was a drop hanging under the cv and smellled like gear oil
  5. Aug 7, 2020 at 8:59 PM
    0xDEADBEEF
    Ah ok, thats pretty telltale. I'd probably just watch and wait, but I'm sure there's a youtube video on fixing it (I haven't had to touch mine yet..)
  6. Aug 7, 2020 at 9:03 PM
    Allex95
    allex
    Is it the seal on the cv axle? Or seal in the diff?
  7. Aug 7, 2020 at 9:08 PM
    Ccrowe323
    Cory
    Florida
    It is a seal in the diff. It seals the outer part of the CV to the diff so no fluid leaks out of the diff. It’s the rubber seal you see in the pic below just on the outside.
    That is your diff where the cv goes in.
  8. Aug 7, 2020 at 9:23 PM
    Allex95
    allex
    Do I need a special tool? And part number?
  9. Aug 7, 2020 at 9:27 PM
    Ccrowe323
    Cory
    Florida
    I would suggest watching Tim’s vid. He’s got the info your looking for along with a very good tutorial https://youtu.be/vcCT4UgFUTw
    Just skip past the CV boot part, but I would suggest replacing your CVs with NAPA since you will have them out. Napa has a lifetime warranty on them and you can replace them if anything happens, from a torn boot or if you break it Offroad. I can’t remember if it’s extra or not but it’s definitely worth it. Kinda like a buy once cry once thing
  10. Aug 7, 2020 at 9:44 PM
    Allex95
    allex
    i noticed that i could pull the cv out just a hair is that normal? the round gold part on the cv looks like it should not do that
  11. Aug 7, 2020 at 10:15 PM
    Allex95
    allex
    is it the axle shaft oil seal?
  12. Aug 8, 2020 at 6:12 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Yes, that's normal. There's a little in and out movement with the connection of the CV axle with the front differential. I agree that your leak doesn't look that bad. But, if you want to address it, you can use the video that was linked above and then use the video below to replace the seal.
    https://www.youtube.com/embed/mh1BK5--KrU
    Sreppep and Madjik_Man like this.
  13. Aug 8, 2020 at 7:12 AM
    Madjik_Man
    Colorado Front Range
    I watch so many of your videos that my girlfriend literally knows your voice. “What Timmy video you watching now?” She asks from the other room.
  14. Aug 8, 2020 at 8:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    As long as She has not started to play the videos when your sleeping
  15. Aug 8, 2020 at 8:59 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I just popped the old one out with a screwdriver, drove the new one in with the CV axle itself. Worked like a charm.
    Taco-Obsessed and cruiserguy like this.
  16. Aug 8, 2020 at 9:43 AM
    Madjik_Man
    :rofl:
  17. Feb 9, 2023 at 6:40 AM
    DoubleC
    DoubleC Well-Known Member
    Christian
    Oxford, MS
    1999 Tacoma 3.4 TRD (Natural White - the best white)
    I know this is 2 years old, but my 99 just started having this problem. Small leak under the passenger CV where it joins with the diff. Thought it could be the steering pump I just replaced, but the fluid isn't red and smells pretty bad, like used gear oil. Oil slowly accumulates and forms droplets under the skid.
    I also am able to move the passenger CV in and out of the diff more than the driver CV. Is this normal?
    Any helpful tips from anyone who was in this conversation or the OP? I drive my truck maybe once a week, and maybe a total of 20-25 miles max/week
    (not a daily).
    Thanks guys.
  18. Feb 9, 2023 at 7:14 AM
    eon_blue
    Azusa, CA
    I just want to say, 3 years later, this was not a good way to do the CV axle seal lol. It started leaking badly again not long after and I had to redo it the proper way (seating it at the proper depth) a couple times before it finally stopped leaking
    3JOH22A, Area51Runner and 0xDEADBEEF like this.
  19. Feb 9, 2023 at 7:31 AM
    DoubleC
    Christian
    Oxford, MS
    Thanks, would you say its an urgent problem if its not leaking too bad like @Ccrowe323 said, and would you suggest doing the way timmy does in his video? (Haven't watched yet)
  20. Feb 9, 2023 at 3:28 PM
    eon_blue
    Azusa, CA
    Yeah if I recall he uses a section of pvc pipe to seat the seal in, I believe it has to go in 5.5mm but double check that.
    I don't think it's an urgent issue unless it's puking fluid out, a few drips here and there won't hurt anything except the stains it leaves on the driveway. Can always top off the diff once in awhile to make sure it stays full
