Leaking Coolant Reservoir Tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taconest, Dec 12, 2019.
  1. Dec 12, 2019 at 9:36 AM
    Taconest
    Taconest [OP] Well-Known Member
    Boise, ID
    06 Tacoma DCLB 4X4 V6 4.0L
    Bilstein 5100/ Dirt King UCA/ OME 886 Fronts, Fox 2.5 DSC/ HD Dakkars, 4.88 Gears, Eaton Rear Locker, 33" Ridge Grapplers, ARB Front Bumper, Fab Fours Rear Bumper, DIY Roof Rack, Wildernest Topper, Wood Stove, Snorkel
    This write up is for anyone that may have a leaking coolant overflow tank. This could be a quick first area to check before you pull the shroud from the truck.
    Symptom: When filling my overflow tank to the full line I would immediately notice it would start to leak coolant until the reservoir reached a certain level and would stop leaking. Tried this multiple times with the same result. So I figured my overflow tank was cracked and wanted to see if I could seal it back up without having to buy a whole shroud assembly. I tried to find anything on if these could be separated and could not find any posts or pictures confirming this, so I tore into it.
    IMG_4571.jpg[​IMG]
    Once I removed the shroud from the truck I found out I could remove the coolant reservoir tank from the shroud and it was its own unit.
    I filled the tank with water, found the crack, and then ran a bead of silicone along the crack.
    As you can see, if you need to remove your coolant reservoir tank, you can do so without removing the whole shroud FYI. I have been running this for 3 months (1500 miles) and it has held so far.
    95SLE and Rob MacRuger like this.
  2. Dec 12, 2019 at 12:09 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Mine leaks at the hose connection to the radiator overflow. Not much, but the pink crust is quite annoying.
    jtaco11 and TheDevilYouLove like this.
  3. Dec 12, 2019 at 12:31 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    I'd keep an eye on it. RTV silicone isn't a good adhesive and the material of construction for that tank (polyethylene) isn't an easy one to bond anything to.
    I might have tried a hot melt adhesive or trying to re-weld the crack with something like a soldering pencil.
    cruxofthebisquit likes this.
  4. Dec 16, 2019 at 9:02 AM
    Taconest
    Boise, ID
    My thought was that I wasn't actually glueing two pieces together, but more sealing a crack like you would a bathtub, or around a window. I tried cleaning the plastic really good, because as you mentioned I was worried about it bonding to such a slick surface. In hindsight, I probably should have scuffed it up a bit with some sandpaper as well.
    I thought about trying to re-weld it, but have only really read about ppl doing it and haven't tried it before. Is hot melt adhesive just using a normal hot glue gun and stick, or is there a particular type of stick to buy that will bond better?
    Thanks for the input!
  5. Dec 16, 2019 at 11:04 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    The silicone seal will not stick long on that type of plastic. Plastic welding would work. Harbor Freight has plastic welders for $15, which is probably about what you'd pay for a salvage yard tank.
    cruxofthebisquit and Muddinfun like this.
  6. Dec 16, 2019 at 11:27 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Same here
  7. Dec 16, 2019 at 11:36 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Canoe and Kayak leaks are fixed with soldering irons. *little bigger than wiring but it'll work* If you need filler, trim with razor knife from a too thick spot.
  8. Dec 16, 2019 at 2:28 PM
    Taconest
    Boise, ID
    This was going to be my next solution if the silicone did not hold. I have plenty of buddies that are pretty familiar with welding kayaks (even some of mine that I have cracked over the years) and have the tools to do so.
    I haven't been super regular at checking my local junkyards but it seems like in Idaho if a Tacoma makes it to the junkyard its either parted out in a week, or someone buys the whole truck for parts.
