Leak from intake manifold gasket?
Discussion in 'Technical Chat' started by haolerot, Mar 7, 2016.
  1. Mar 7, 2016 at 2:19 PM
    haolerot
    haolerot [OP] Well-Known Member
    03 Tacoma TRD
    So, last week I took my truck in to get my valve cover gasket changed, as I was too lazy to do it myself. They called and told me that the rear cam seals have to be changed. Cool.
    So one week and $850 later, I notice that there is a new leak (that wasn't there last week) coming from my intake manifold gasket. Any ideas?
  2. Mar 7, 2016 at 2:30 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    they replace the intake gasket? i know on my buddys i removed it and flipped it over and the oil leaked out and kinda looked like that after it was back together and driven
  3. Mar 7, 2016 at 2:32 PM
    haolerot
    03 Tacoma TRD
    They didn't replace it, but had to remove/reinstall it when getting to the valve cover gasket. I was speculating that they put it upside down, but not sure.
  4. Mar 7, 2016 at 2:34 PM
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    Well there is nothing but air in there. Well and probably carbon. That is prob just from them cleaning with brake cleaner or some thing and some residual is it running fine?
  5. Mar 7, 2016 at 2:36 PM
    haolerot
    03 Tacoma TRD
    Seems to be running okay. I also suspected brake cleaner, but that leak wasn't there when I received the truck back from them. It has a sticky/oily feel.
  6. Mar 7, 2016 at 2:37 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    $850 and they didn't even replace the intake gaskets? Did they do both valve covers?
  7. Mar 7, 2016 at 2:38 PM
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    I wouldn't worry if its running fine. just clean it off & monitor just some residual from cleaning and reusing gaskets.
  8. Mar 7, 2016 at 2:41 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    crank your truck up, and pop the hood. spray brake cleaner around it to determine if there are any leaks... we did this to make sure my spacer wasn't leaking after install...
  9. Mar 7, 2016 at 2:45 PM
    Blacktaco2042
    wisconsin
    id clean off and see if it returns
  10. Mar 13, 2021 at 2:48 PM
    derektaco
    derektaco Well-Known Member
    1995 tac
    those is interesting post. I have oil spraying a very fine mist from under the plenum on my 95 2.7l. I'm very befuddled as to why oil would be spraying from the plenum area. it isn't leaking from the head gasket, and I know it can't be leaking from the intake itself... so where would oil be spraying from?
  11. Mar 13, 2021 at 2:50 PM
    derektaco
    1995 tac
    see the pooling on top of the intake. it's really befuddling. d
  12. Mar 14, 2021 at 12:30 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    year ???
    mileage ???
  13. Mar 22, 2021 at 1:16 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Could be oil mist collecting from your PCV system.
  14. Mar 22, 2021 at 1:27 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    If you do this, make sure it's flammable brake cleaner. A lot of the stuff is no longer flammable, ask me how I know o_O
