Leak during heavy rain in floor board
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brvermilli21, Nov 12, 2018.
  1. Nov 12, 2018 at 3:33 PM
    brvermilli21
    brvermilli21 [OP] Well-Known Member
    Knoxville TN
    So its been raining very hard all day today here in Tennessee. When i got in my truck there was a big puddle in the passenger floor board. I looked quickly and best i could see was water was running down a wire and dripping to the center of the floor board.
    But by the time I drove home and got in there to look I couldnt see any side of the water. I looked at the wire where I had seen the drips but no wires were wet and no drips anywhere to give me a lead. I took the glovebox out and looked all around but no luck. Popped the hood and look around but nothing stood out
    Anyone ever see something like this? Any ideas?
  2. Nov 12, 2018 at 3:40 PM
    2015 TRD Sport
    2015 TRD Sport Well-Known Member
    South Carolina
    2021 TRD Pro
    Windshield leaking maybe??
    Trouble_The_Tacoma likes this.
  3. Nov 12, 2018 at 3:44 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Do you have ditch lights? Ive seen this with trucks equipped with ditch lights that require trimming of the cowl. The cowl wont get seated properly an the water drips thru where the cabin filter housing/hoses to the floor.
  4. Nov 12, 2018 at 3:49 PM
    BlueC0ma
    BlueC0ma Active Member
    07' TRD OR
    I have a similar issue but not exactly the same. When I pull my passenger weathertech to vacuum, there is condensation between the carpet and the mat, which is also a bit concerning.
  5. Nov 12, 2018 at 4:08 PM
    brvermilli21
    Knoxville TN
    not the windshield and no ditch nights but i had wandered if it was coming in from the cabin air filter area. I will pop the hood and make sure the plastic is seated properly.
    MattCowsmasher likes this.
  6. Nov 12, 2018 at 5:39 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Do you have a roof rack or have you beat/cut your pinchweld or done any work to your firewall?
  7. Nov 12, 2018 at 5:42 PM
    Bocsy44
    Bocsy44 Well-Known Member
    Erik
    Ottawa, ON, Canada
    09 DCLB Sport
    This that and the other thing.
    I would pull the cabin air filter and see what it looks like, if it looks like it has been getting wet or something of the like. might even be worth pulling the windshield cowling off and having a look to see if maybe there is a pin hole down there or something where water might be coming in
  8. Nov 12, 2018 at 5:46 PM
    King Rex
    King Rex Well-Known Member
    DFW, TX
    2009 DCSB TRD OR
    I had the same issue. Water running off the windshield into the cabin air intake underneath the plastic trim. Fixed it by taking a piece of sheet metal and forming it into a cover for the hole. Havent had a drop since.
  9. Nov 12, 2018 at 6:48 PM
    brvermilli21
    Knoxville TN
    Thanks all I'll check the filter tomorrow
  10. Nov 13, 2018 at 4:23 AM
    brvermilli21
    Knoxville TN
    rained all night...got in the truck this morning and dry as a bone...i didnt change or fix anything. Im guessing that I must have been parked at just the right angle yesterday at work that allowed the large amounts of puddled water to run inside somehow. I parked in the different area today and its raining still. I'll check at lunch and see if any water has made its way in
  11. Nov 13, 2018 at 4:32 AM
    Admiral Awesome
    Admiral Awesome IG:Bucklaooooo
    anthony
    Houston Texas
    2012 DC TRD LT
    Camburg 3in LT kit fox shocks/bypasses 315-75-16 Scs f5 wheels gunmetal 16x8 Prinsu rack 40in heretic light bar Cali raised ditch light Baja squadron pros McNeil fiberglass fenders Adv fiberglass bedsides Volant intake
    This
    brvermilli21[OP] likes this.
  12. Nov 13, 2018 at 6:34 AM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Did you find the cabin air filter or fan housing wet or moldy? I have the same kind of leak and the filter and fan were dry, no rust or water stains found. I found the "sealer" used around the air intake curb under the cowl to be porous. I coated that seam with autobody seam sealer. I'm not sure if I still have the leak. The carpet and floor pan were soaked under weathertech mat. I may try the sheet metal cover too. The air conditioning drain was clear and all body plugs in place. No holes added by me. I can't believe that gappy cowl to windsheild gasket is all that stops water from pouring into the cabin air intake.
  13. Nov 13, 2018 at 8:31 AM
    96carboard
    96carboard Well-Known Member
    Make sure to clean all the crap out from the air intakes under the hood. Also, there is a drain... somewhere. If it got plugged up with crap, there won't be anywhere for the water to go except into the cab.
  14. Nov 13, 2018 at 9:22 AM
    King Rex
    DFW, TX
    2009 DCSB TRD OR
    Never found it moldy, it looked fine when covered it.
  15. Nov 13, 2018 at 10:56 AM
    Troyken
    NY
    Yes, the area below the plastic cowl drains out through holes near the fender corners. I did find some maple tree seed pods and other debris stuck in the drain holes. I cleaned them out and ran the hose in there. The water came out the bottom of the fender on the passenger side in my case.I park pitched slightly forward and more tilted to the passenger side in the driveway.
  16. Nov 13, 2018 at 1:17 PM
    JSB10
    JSB10 Well-Known Member
    2005 Tacoma
    I was having the same problem as my passenger floorboard would fill up with water only when it rained. I couldn't find any place where it was coming in so I took it to the shop and they did the leak test for the windshield and found the leak. Aftermarket windshield and so far no more leaks. Most shops in my area were around the same price give or take a few dollars.
  17. Nov 13, 2018 at 1:20 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Looks like your passenger couldn’t hold it in
    96carboard and brvermilli21[OP] like this.
  18. Nov 17, 2018 at 12:31 PM
    Troyken
    NY
    Update: We had almost three inches of rain plus snow this week, floor was SOAKED again. I pulled door sill trim and the kick panel off. I pulled back the carpet, floor was soaked under carpet. I ran the water hose from mid windshield and had my son look inside. Two solid streams of water flowing from under the dashboard in line with the heater air intake and pooling on the floor.I have a 1/16 gap in the cowl to windshield trim gasket. The water was flowing between the cowl gasket and the windshield, right off the windshield into the heater intake and coming out on the floor AND the condensate drain tube at the same time, It was NOT leaking from the blower motor housing. I made sheet metal shield similar to above to cover the heater intake and reinstalled the cowl with sealant between the windshield and the cowl gasket. I proved the leak first by putting duct tape over the cowl to windshield joint and running the water again. No water entry.
    I think this will solve the issue. How can there not be a TSB or recall on this? I cannot believe how poor this design is. How can that be the ONLY seal? That cowl warps away from the windshield in places like over the air intake and leaks like a sieve. We have been getting tropical type downpours regularly all year and there is no way this setup cannot leak over time.
    As for the mold and mildew, I mixed up a pail of hot water and lysol and poured it on the passenger side carpet after removing the floor drain plugs. I let it soak for about an hour and the sucked up the remaining water with a green machine cleaner. It smells better for sure.
  19. Dec 3, 2018 at 6:25 AM
    Troyken
    NY
    Update: Again, we had about 3 inches of rain in heavy downpours this week. So far the floor is dry. I think the windsheild cowl sealant did the trick . The sheet metal shield is a backup. There was a persistant mold smell. I soaked the floor and carpet with about a quart of a pre-mixed disinfectant, in gallon form, from Home Depot. I left it wet for a week and then vacuumed up with a wet/dry vac. It had no effect on the carpet color and the smell is very faint if anything now that it is dry. The next two days should be warm and dry. I'll put the weathertech mat back on Wednesday I think.
  20. Dec 7, 2018 at 7:58 AM
    Tectonic
    Tectonic Well-Known Member
    James
    Tucson, AZ
    12 TRD Sport DCSB 4wd
    Bilstein 5100 all around OME 884 Wheelers 1.5" 3 leaf progressive aal 255/75r17 Hankook Dynapro ATM ARE camper shell Hella Sharptones (4)
    I had the same issue and could not figure it out for a long time. Eventually I realized it was coming in through the bolt holes on the roof used to secure the roof rack. I guess there is a path for water from those holes to the floorboard. Do you have a roof rack or exposed bolt holes? It's an easy thing to check. Even if you don't, just remove the rubber gaskets on the roof rack channels and check to make sure the bolt holes are not open. If they have never been used they will have a thin foam/tape seal over them
