Leaf Springs vs Coil springs - Is it worth moving beyond the SR?
Discussion in '4th Gen. Tacomas (2024+)' started by sopranojam85, Mar 26, 2024.
  1. Mar 27, 2024 at 8:55 AM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    I'd probably get the better trim. You will likely have major fomo once you realize how many features got taken out of the SR. It's quite barren inside despite the relatively high price.
    sopranojam85[OP] likes this.
  2. Mar 27, 2024 at 8:59 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    My deaver full leaf pack cost like 1100 the ome rear coils on my 4Runner are like 200
    leaf or coil the taco has a pretty light payload rating
  3. Mar 27, 2024 at 9:13 AM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Also worth consideration is that despite using an identical motor, Toyota intentionally restricts power on SR trims for paying them less money.
    Even if you decide now that an SR is the way to go, you might be kicking yourself later this year when we see discounts on higher trims. If you don’t feel compelled to decide quickly, you’ll probably save money and get additional features simply by being patient.
    TS4x4 and sopranojam85[OP] like this.
  4. Mar 27, 2024 at 9:29 AM
    sopranojam85
    sopranojam85 [OP] Well-Known Member
    2024 Black Tacoma SR DBL cab 4x4 6M
    When I first called about this truck to get on the waiting list, they said it may take over a year. Then after everything was completed, they said July. I'm honestly not sure if I'll be ready to pull the trigger in July or not, and may very well wait a bit longer, if for no other reason than to let these prices cool off some.
    StayinStock and Malvolio like this.
  5. Mar 27, 2024 at 9:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Not on the SR Manual, it also has 270 HP like the Off Road and Sport.
  6. Mar 27, 2024 at 9:41 AM
    TexasTacoma713
    TexasTacoma713 Well-Known Member
    PNW
    2024 OR
    Looked at a 2024 SR yesterday.. Was considering swapping the leafs to the coils and it’s not possible. The link mounts on the coil suspension is welded vs the leaf mounts are also welded differently.
    I would assume aftermarket leafs for the SR will be nonexistent as not many of this trim will be modded.
    The SR trim is a good buy but payload and towing capacity are downsides.
  7. Mar 27, 2024 at 9:44 AM
    sopranojam85
    The SR manual has the same payload and towing capacity as higher trims. Yet another thing that makes the SR manual a bit of a unicorn worth considering...
    jayuu, shakerhood and Lt. Dangle like this.
  8. Mar 27, 2024 at 9:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not sure why you'd consider taking on such a "swap"
    It's like a 1st Gen Tacoma rear vs 3rd Gen 4Runner rear; same rear end but completely different mounts welded up from the factory. If you were to replace the rear setup at all on either, you wouldn't do it for the factory-version of the other.
    You'd go fully custom for the most travel/articulation.
    taco terror and Fast1 like this.
  9. Mar 27, 2024 at 9:48 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    I have a 2017 DCSB Sport MT and love it. However, If the SR came DCSB in a MT in 2017, I would be driving that and would have saved the money.
    Junkhead, jayuu and sopranojam85[OP] like this.
  10. Mar 27, 2024 at 10:01 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Where do you see that? The configuration I can see shows all the manuals are short 50hp/70 ft/lbs regardless of trim.
  11. Mar 27, 2024 at 10:45 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Not on the MT. It has the same power any trim does.
  12. Mar 27, 2024 at 10:48 AM
    Lt. Dangle
    Ohio
    Website is wrong per Engineers and Sheldon.
  13. Mar 27, 2024 at 11:16 AM
    sopranojam85
    So the "Specs" table in Toyota's website is correct, but the "builder" flow has a typo? And so therefore is the towing capacity of the SR manual also the same as the other higher trim MTs (6,400 maximum, and 640 tongue weight?)
  14. Mar 27, 2024 at 11:43 AM
    TexasTacoma713
    PNW
    2024 OR
    Tow capacity on any leaf spring model is 3500lbs I believe
  15. Mar 27, 2024 at 11:48 AM
    #35
    sopranojam85
    If what you're saying is true, then the specs table also is wrong in regards to the SR5 XtraCab models that have leaf springs, but have 6,500 lbs towing capacity.
  16. Mar 27, 2024 at 4:40 PM
    #36
    Lt. Dangle
    Ohio
    Any SR equipped with the tow package has the higher tow rating. It's in the options part of the memo I snipped earlier.
    I will find the section later when I get a chance if someone doesn't beat me to it.
  17. Mar 27, 2024 at 5:58 PM
    #37
    Walliby
    Walliby Well-Known Member
    Massachusetts
    2023 TRD OR DCSB Auto
  18. Mar 27, 2024 at 6:38 PM
    #38
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Yep, same here. At the very least, I had to get the sport with premium and tech package. Thanks Toyota
    shakerhood likes this.
  19. Mar 27, 2024 at 7:45 PM
    #39
    shakerhood
    Southern Ohio
    Correct, the SR MT, OR MT, and Sport MT all have 270HP / 310 Ft. Lbs Torque.
  20. Mar 28, 2024 at 8:27 AM
    #40
    sopranojam85
    There's a lot of conflicting info. Here's a thread that talks about the model code info:
    https://www.tacomaworld.com/threads/detailed-2024-tacoma-model-code-info.827383/
    If this is accurate, then the model code for the SR 4x4 is TZNA46.
    If we only look at the 2024 Tacoma user manual, the TWR for that model is 3500 lbs. This table makes no distinction between the manual transmission or automatic transmission variants (which presumably we THINK has more horsepower than the automatic detuned variant.)
    There's an SR Manual for sale in Silver City, NM, and their website suggests towing capacity is max 3500 lbs. https://www.hatchtoyotastateline.com/auto/new-2024-toyota-tacoma-sr-silver-city-nm/86856508/
    So now this begs a few questions...
    Does the SR5 4x4 XtraCab with leaf springs also suffer the same towing capacity? If so, there's another typo.
    If the SR 4x4 with MT has the same horsepower and torque as the other two trim levels with the MT, then what's to stop the SR 4x4 MT from towing close to 6500 lbs? If the issue is leaf springs, this contradicts with the SR5 that has leaf springs above. If the issue is a lack of a rear stabilizer bar, that could possibly be added on. I do not know who to believe at this point.user manual TWR.png Screenshot 2024-03-28 at 10.24.46 AM.png
