Leaf spring upgrade recommendations?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Baby, Oct 26, 2015.
  1. Oct 26, 2015 at 10:06 PM
    Baby
    Baby [OP] Well-Known Member
    Northern, CA
    03 Tacoma 3.4
    I'm looking for some advice on suspension repair/upgrade.
    The rear of my '03 TRD with 115k miles sags like a 70-year-old roller derby queen. The truck rolls quite a bit in corners. I haven't touched the suspension, tires are stock size. The truck is no longer my daily driver and is used a few times a week, often to carry several hundred pounds of lumber or sand bags or whatever, and sometimes to carry camping gear. Once or twice a year it sees a muddy trail. So I'm looking for a decent ride, mostly on pavement or washboard, and durability/longevity in the replacement parts.
    I definitely need leaf springs and likely shocks front and rear. There's a lot of stuff out there; what do you think are good options for my needs? And should I consider additional suspension parts?
    YotaDan likes this.
  2. Oct 27, 2015 at 1:13 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Iwent with the Heavy Duty Springs From General Spring out of Kansas City
    Then added Super Springs but I carry @ 1000 pounds each time the truck gets used.
  3. Oct 27, 2015 at 6:34 PM
    Mischief
    Mischief misadventurer
    Christi
    Duke City NM
    2004 Tacoma crewcab TRD
    I took mine to a spring shop and they re-arched the springs and added a leaf and replaced the bushings for $420. I thought that was ok. If I wanted another leaf to carry more weight, I'm sure they would have done that too. Most decent sized cities have a spring shop 'cause all trucks need springs
  4. Oct 27, 2015 at 8:50 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Theres lots of options out there...
    SlimeInnaTaco likes this.
  5. Oct 28, 2015 at 7:42 AM
    Baby
    Northern, CA
    03 Tacoma 3.4
    Thanks for the suggestions. Yes, lots of options, lots of threads. It's overwhelming. The General Springs HDs look better than what my local offers. OME look like good options as well.
  6. Oct 28, 2015 at 7:43 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Chevy Leaf Springs :headbang:
    SlimeInnaTaco, Parkvisitor and 4WD like this.
  7. Oct 28, 2015 at 7:58 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    For the weight, OME Dakars. But you'll get some lift there. You could also go with OEM springs and airbags.
    Hamer95USA likes this.
  8. Oct 28, 2015 at 8:09 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Stop it.......:p
  9. Oct 28, 2015 at 8:09 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rofl:
    ok :pout:
  10. Oct 28, 2015 at 8:11 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Is that a 63" main ?
  11. Oct 28, 2015 at 8:13 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yes sir off a 98 Silverado 1500
    3 leafs sitting nice on my rig
    :drool:
    YotaDan and 4WD[QUOTED] like this.
  12. Oct 28, 2015 at 8:22 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Awesome stance !! Well done ....:thumbsup::thumbsup:
    Hamer95USA, 33harman and Rattletrap66 like this.
  13. Oct 28, 2015 at 8:23 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    thank you good sir!
  14. Oct 28, 2015 at 8:27 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    How much lift do you have in the front compared to the back? I have 3" in the front and want new leafs but no more that 1.5" of lift in the rear
  15. Oct 28, 2015 at 8:29 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    never measured the back after the chevy leaf springs went in but I can do that when I get off work soon. Front was lifted right at 3"
    Originally when stock, the rear was 1" higher than the front if that helps
  16. Oct 28, 2015 at 8:37 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    oem or anything claiming to be oem equivalent are NOT good options, they are weak as shit and not worth buying so you want something rated above eom specs.
    go with the general hd springs http://www.generalspringkc.com/product_p/90-237hd.htm
    they add an extra 400 lbs load capacity for hauling stuff and ride great.
    for the front just buy the Monroe all in one struts
    MONROE 171352L Quick-Strut https://www.rockauto.com/catalog/raframecatalog.php?catalog=904&partnum=171352L&a=www.google.com+Search+for+MONROE+171352L&blanktemplate=true
    MONROE 171352R Quick-Strut https://www.rockauto.com/catalog/raframecatalog.php?catalog=904&partnum=171352R&a=www.google.com+Search+for+MONROE+171352R&blanktemplate=true
    then add a nice set of quality rear shocks
    GABRIEL G63494 http://www.rockauto.com/catalog/raframecatalog.php?catalog=962&partnum=G63494&a=www.google.com+Search+for+GABRIEL+G63494&blanktemplate=true
    these parts will return your truck back to riding like brand new again without changing the ride height at all or spending a lot of money for fancy names on the boxes.
    I just put this setup on my 04 and it rides like a Cadillac now
  17. Oct 29, 2015 at 9:07 AM
    Baby
    Northern, CA
    03 Tacoma 3.4
    OME, not OEM. :) I had considered the Monroe route, but I'm a little concerned about longevity. Thanks for the suggestions.
    Rattletrap66 likes this.
  18. Oct 29, 2015 at 9:12 AM
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :laughing:
  19. Oct 30, 2015 at 12:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I just installed the loaded Monroe Struts .
    Getting the old ones off was a pain even with spraying with Kroil the top bolts all broke loose and just spun and needed to be cut off.
    I did my lower Ball joints at the same time .
  20. Oct 30, 2015 at 5:18 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    So are the only options out there for near stock height:
    Dorman/OEM stock
    OME Dakars
    General KC
    Thats the impression im getting.
