Leaf spring spacer question.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by whitepony04, Oct 8, 2019.
  1. Oct 8, 2019 at 11:39 AM
    whitepony04
    whitepony04 [OP] The Big Igloo is coming...
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Eibach pro kit, 3 leaf aal, ecgs, fn fx pros, bfg ko2, gator sfx, Meso stuff
    Ok, the front of my taco sits at 38” on driver and pass, dead even. The rear driver sits 1/4” lower than the rear pass. It has sat like this before and after the lift.
    I need to chase down a small but annoying squeak on the driver side. While taking it apart, would there be any negative effects of adding a small spacer to bring that side up a bit? See pic.
    Maybe a 1/4” piece of flat stock cut to fit between axle and spring pack.
  2. Oct 8, 2019 at 11:49 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Should be fine. Wheelers sells a 1/2" leaf shim kit specifically for this purpose.
  3. Oct 8, 2019 at 11:55 AM
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    I think the 1/2 would be too much.
  4. Oct 8, 2019 at 11:56 AM
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    I notice it! You’re correct tho
  5. Oct 8, 2019 at 11:56 AM
    Comb
    Comb Known Member
    Yeah, then you'd be 1/4" the other way. I was just making the case that if they're selling kits for this purpose, you should be safe in doing it.
    Crikeymike likes this.
  6. Oct 8, 2019 at 11:58 AM
    whitepony04
    Tanner B
    Oklahoma
    19 trdordcsbxyz
    Are u saying I’m fat?!? You’re right but u don’t have to point it out.
  7. Oct 8, 2019 at 11:59 AM
    Comb
    Comb Known Member
    Also test it with an empty tank and then again with a full tank of gas.
