Leaf spring replacement. Gen 1 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by UserGoose, Sep 5, 2023.
  1. Sep 5, 2023 at 11:37 AM
    UserGoose
    UserGoose [OP] New Member
    2000 Tacoma TRD
    Hey y’all, I have a busted leaf spring on the rear passenger side of the truck (2.7l xtracab). I’m wondering where is the best place to source a new set of leaf springs from. I assume I should do both sides as well? I don’t want any extra lift, and the rear shocks are new bilsteins.
  2. Sep 5, 2023 at 11:45 AM
    amocatyot
    amocatyot Chronic Over Researcher
    Bill
    1999 Tacoma 4x4
  3. Sep 5, 2023 at 11:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I recommend General Spring, along with new hardware.
    Easy fix.
    Bivouac likes this.
  4. Sep 5, 2023 at 11:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Andy01DblCabTacoma should be coming in shortly to chime in what other 'names' the General Spring leaf pack goes by in case you can find it cheaper elsewhere otherwise they're cheap enough as is from GS
    amocatyot likes this.
  5. Sep 5, 2023 at 11:49 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Yes, do both springs. Suggest new bushings.
  6. Sep 5, 2023 at 11:57 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Looks like you got it all taken care of :rofl:
    Kwikvette[QUOTED] and Bivouac like this.
  7. Sep 5, 2023 at 12:20 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the Forum!!
    General Springs again.
    They under sold all the local spring shops in the area with shipping.
    Check the shipping before buying.
    It is lots of grunt work but the first time can be time consuming depending where the truck lives.
    Best of Luck !
  8. Sep 5, 2023 at 1:43 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here are several options depending on how you use the truck:
    Replacing Leaf Springs on a 1st gen Tacoma - (And as others have mentioned, General spring is a good option if you're looking for a simple stock replacement.) Don't forget to replace the u-bolts as well; those are a single-use item.
  9. Sep 6, 2023 at 12:05 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Like others have said it's a lot of grunt work but man it's worth it in the end. I went with the OME Dakars and nitro chargers and some other extra bits. The one thing I notice on my older Tacoma is that all the hardware they used is actually really good. Not a single thing broke or stripped out.
  10. Sep 6, 2023 at 6:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Only if it's rusted together, otherwise super easy.
  11. Sep 12, 2023 at 8:33 AM
    UserGoose
    2000 Tacoma TRD
    Thanks for all the help everyone
