Leaf spring options for towing.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Creepbam, Jul 30, 2021.
  1. Jul 30, 2021 at 4:09 AM
    Creepbam
    Creepbam [OP] New Member
    18 TRD
    I tow quite regularly with my Tacoma and was wondering if there is a good leaf spring kit that would improve the towing experience. I feel that the stock springs are too soft. Would I be better off with bags? Thanks.
    PS. My truck is stock height and I plan on keeping it that way. 18 TRD OR
  2. Jul 30, 2021 at 4:19 AM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
    What are you towing? Sure you aren't overloading the truck. Tacoma's have a pretty shitty payload capacity. Maybe you just need a WDH.
  3. Jul 30, 2021 at 4:40 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Absolutely put more leaf springs in. Keep in mind it will lift the rear. I put two more leafs in mine and had to lift the front to level it. After it was all done... now I can tow and haul a payload without sagging. No worries... you're not going to break the truck. Now with the extra suspension and 10 ply rated tires... it rides like a truck. lol
    Lt. Dangle likes this.
  4. Jul 30, 2021 at 4:44 AM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    I don't tow often enough to be a credible source, but my HD Dakars do me well when I do tow.
  5. Jul 30, 2021 at 5:15 AM
    corrado-correr
    corrado-correr Well-Known Member
    Royal Oak, MI
    2021 TRD Sport
    air bags are great.
    E.J., Mark77 and Chew like this.
  6. Jul 30, 2021 at 5:26 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I personally prefer the roadmaster active suspension.
    It does stiffen up the rear unloaded (both good and bad, it keeps those tires planted to the pavement :burnrubber:) and it keeps it from sagging when towing.
    I like them being not as labor intensive as bags - Install is easier, you don't adjust them nearly as frequently. Admittedly for that occasional adjustment it takes a floor jack and 20 minutes of your time.
    I have no complaints.
    eurowner likes this.
  7. Jul 30, 2021 at 7:29 AM
    Steadfast
    Thane
    S.W. Ontario Canada
    2013 Limited
    I wouldn't waste my money on any aftermarket-easy to install crap. If that was any good at all, trucks would come from the factory with them. I don't mean to insult anyone who has bought them but this is my view. None of these aftermarket gadgets offer any lateral stability and with more tongue load, more load support as well as lateral stiffness will be needed. The only way to achieve this is with more leaf springs.
  8. Jul 30, 2021 at 7:32 AM
    Creepbam
    18 TRD
    I tried summo springs but the normal ride quality was horrible. I'm towing a side by side with trailer around 2800lbs and a 22ft bay boat thag weighs roughly 3500lbs. It pulls fine like I said it's just the rear end is very soft and when you go over a bump the whole truck bounces up and down. No tongue weight issues. I know the offroads have a softer ride compared to normal sport shocks from what I've read. I do not have E rated tires just standard SL tires.
  9. Jul 30, 2021 at 7:39 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
  10. Jul 30, 2021 at 7:49 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    @Creepbam , check out Roadmaster active suspension or Hellwig helper springs. Either will do what you want. I use the Hellwigs on my 2018 OR, no problems.
    (Neither application is “crap” in my view but will do the job).
  11. Jul 30, 2021 at 7:56 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    I noticed a huge difference when I switched the rear shocks out to 5160s while towing. I also have airbags and daystar cradles. Rides like stock when it’s unloaded and handles the weight the truck can tow just fine. Leafs are probably the better option if you are towing multiple times a week but then you have to deal with lift and a stiffer ride when unloaded. I’ve hauled camp trailers, dump trailers, cargo trailers, and I’ve got a hitch mount motorcycle carrier that adds about 300 pounds of tongue weight.
    OnHartung'sRoad likes this.
  12. Jul 30, 2021 at 8:04 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Airbags if you don't want any lift otherwise. If you don't get a auto leveling inflator, don’t make the mistake of attaching the air hose from both sides on a T-valve, else the air will slosh back and forth between them on curves. They have to be separate or you need a valve to independently close the lines off from eachother after filling them. The bags are easy to inflate with just a small bike pump. I made a pressure equalizer by attaching two quick press inflator tips onto each end of a short hose, it lets the air pressure between both bags equalize while you hold it onto both valves at the same time.
    I lifted my truck 1.5” with 5100’s front (4th notch, stock coils) and rear, and put in a single Deaver AAL in back while keeping the original overload leaf. Have Firestone airbags and a Daystar cradle too. Towing and off roading works very well with this setup.
    buckmaster243 likes this.
  13. Jul 30, 2021 at 8:33 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If your truck is bouncing up and down and/or porpoising, then stiffer shocks is a better solution than stiffer springs. If your ride height is too low, then stiffer springs will help.
  14. Jul 30, 2021 at 9:27 AM
    Creepbam
    18 TRD
    Awesome replies. Thank you for all your input
  15. Jul 30, 2021 at 9:56 AM
    79CHKCHK
    79CHKCHK Padawan of Rock Lobster
    SoCal no mo
    2018 Super White TRD Pro AT
    I have tried many options over the past 3 years and I refused and resisted the recommendations to go air bags because I thought it would be complicated and expensive. The rear squatted horribly and was super soft towing my off-road trailer that weighs ~3000# fully loaded with my 2018 TRD Pro. I added 500# Sumo Springs, which did reduce the sag but not by much. Unloaded and without a trailer I only felt the Sumo Springs on the biggest of bumps. In hind sight, 1000# Sumo Springs would have probably been a better solution for me on those fully loaded family camping trips, but I don't think it would have eliminated the sag. I then added an extra leaf, which I made from a spare TRD Pro leaf pack I found cheap on OfferUp. This did give me ~1" lift and stiffened up the rear, but even with the Sumo Spring (which wasn't really doing much since the rear was now lifted), I still sagged a good amount. Finally, I found a used set of Firestone Ride Rites with an Air Ride wireless compressor and Daystar cradles. Night and day towing and hauling with the Tacoma! Finally the truck has no squat, less body roll, and drives like a truck should while towing. The best part, I can adjust pressure on the fly if I need a bit more or less support in the rear. Honestly, skip the cheap fixes if you can afford it. There's a reason why dump trucks, 18 wheelers, and other big trucks that haul/tow use air suspensions.
  16. Jul 30, 2021 at 10:37 AM
    gudujarlson
    Minnesota
    I’m curious why people seem to be so worried about a bit of “sag” when there is a load on the rear. It’s normal for springs to do that. I don’t see it as a big problem until you are hitting the bump stops when over bumps.
  17. Jul 30, 2021 at 10:41 AM
    gudujarlson
    Minnesota
    My personal experience is that upgrading my suspension made my truck porpoise less when towing the trailer and I associate that mostly to the king shocks. I have 600lb springs on the front (stock is 700) and the standard Dakar’s on the rear. My goal was not to make towing better, but it was a nice side effect.
    My boat and trailer are about 2300 lb
  18. Jul 30, 2021 at 10:59 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Bump stops are the major reason, but there are other benefits. My trailer is 3000 pounds wet, but its tongue heavy thanks to how it carries propane and batteries. Keeping the trailer level and keeping your headlights properly aimed are some of the other reasons. Bump stops are still the biggest concern with added weight because it affects dampening in addition to travel. Few things will put me in a bad mood like hitting a dip on the highway and feeling that ass-slam.
  19. Jul 30, 2021 at 10:59 AM
    abodyjoe
    joe
    because it tends to take weight off the front of the vehicle that is used to steer.
  20. Jul 30, 2021 at 11:00 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Suspension helpers wont put weight back on the front axle. Only a WDH will do that.
