Leaf spring insulators
Discussion in '2nd Gen. Tacomas (2005-2015)' started by I leak oil, May 23, 2019.
  1. May 23, 2019 at 11:50 AM
    I leak oil
    I leak oil [OP] Member
    2013 TRD
    Anyone know where I can get these insulator pads for the leaf springs? Mine are toast (gone) and squeaking like no tomorrow.
  2. May 23, 2019 at 3:08 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Toyota Dealer. 04001-28104
    Spacer Kit
    The kit includes the round discs.
    Check to make sure that it isn't the ones on the side inside the u shsped bracket. Opposite side of the leafspring where your hand is.
  3. May 25, 2019 at 5:01 AM
    I leak oil
    2013 TRD
    Thanks!
    That's a picture I got from the web. The insulator pads on mine are DEFINITELY gone!
    I've talked with two different Toyota parts places that couldn't offer a factory part. Not worth their time probably.
  4. Oct 5, 2019 at 8:16 AM
    eltaco
    eltaco Well-Known Member
    Littleton, CO
    '07 4x4 DC Offroad
    Sorry, I recognize this is an old thread.
    Can anyone tell me if this kit includes multiple spacers, and it so, if it services both sets of leaf springs?
    I just talked with a dealer that told me it’s for one spacer. I’m sure that can’t be correct, I’m pretty certain I could replace new leaf springs for less if that’s the case.
  5. Oct 5, 2019 at 9:14 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I'll have to check. But I'm pretty sure each kit contained 4 spacers .
  6. Oct 5, 2019 at 9:14 AM
    Brofessor
    Brofessor Well-Known Member
    A little squeak never hurt nobody
    gasgasman likes this.
  7. Oct 5, 2019 at 9:20 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    Each kit contains 4 spacers!!! :thumbsup:
    3 1/2 Stents likes this.
  8. Oct 5, 2019 at 11:36 PM
    eltaco
    Littleton, CO
    '07 4x4 DC Offroad
    Thanks Rick. Sounds like I need to grab a couple packs. My spacers are toast on both sides. I’ll accept that for 185k miles!
  9. Mar 11, 2021 at 10:12 AM
    jwags25
    jwags25 New Member
    2013 Toyota Tacoma TRD
    I apologize for hopping on an old thread but the service shop I took my 2013 to said that I'd have to replace the whole leaf spring and they don't do maintenance on the pads/insulators, dealership said the same. Were you able to get those spacer/insulators installed on your own or did you take it to a repair shop?
  10. Mar 11, 2021 at 10:45 AM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I did them on my own
    I jacked up the truck so that the rear wheels hung loose with the leafsprings uncompressed.
    I used a couple of pry bars to pry the springs apart and placed a 3/4 to 1 inch metal bar between the leaf springs to keep the springs apart while I removed the rubber spacer and to install the new ones. Don't want the leaf springs to come together on your fingers!!
    I did this at pad location. The pads have a tab in the centre of them that go into a corresponding hole in the springs.
    Took me in total about an hour.
    I had a couple that were worn right to nothing, and a few others that were paper thin. The others were worn to about 1/4 thickness of the new ones.
    My springs haven't squeaked at all since.
    3 1/2 Stents and jwags25[QUOTED] like this.
  11. Mar 11, 2021 at 10:56 AM
    jwags25
    jwags25 New Member
    Thanks! mine is gone where the above picture indicates, seems like a simple replacement as you described. I can't bring myself to spend $1k on a whole new leaf spring when i just need that spacer/insulator.
  12. Mar 11, 2021 at 12:48 PM
    Rick's 2012
    Rick
    Costa Rica
    Stock
    I don't blame you. I wouldn't want to spend $1k unless I absolutely had too either.
    Let me know how it works out :thumbsup:
    Its so screwy how they'll R & R the leafsprings, but not replace the spacers???
    jwags25[QUOTED] likes this.
