Leaf spring bushing recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 03f5sp, Jul 31, 2015.
  1. Jul 31, 2015 at 9:20 PM
    03f5sp
    03f5sp [OP] Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    My leaf spring bushings are starting to squeak so it's time to replace them. It sounds like polyurethane is the way to go. Do you have any recommendations as to who has the best ones or where to buy for the best price? How much of a difference will there be between polyurethane and worn out stock units?
  2. Aug 1, 2015 at 4:28 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Are you sure its the bushings that are squeaking? It could just be your leaf springs need some cleaning.... Spray them out good with a power washer - especially at the ends.
    I don't know what the tacomas have currently, but most vehicles I've experienced (1st gen & jeeps), the bushings have a metal sleeves in them. The sleeve & bolt often become rusty and an fuse together over time. Taking them apart and lubricating with grease would be good. You have a 2011....too soon for your bushings to need replacing.
    If the bolts are separate from the shackles - I would highly recommend getting greasable shackle bolts. These bolts have a grease zerk on the end and allow you to lubricate the bushings without taking them apart. I would recommend getting a KIT that includes the greasable shackle bolts & Poly bushings together. Many options /brands out there. I've had these on my Jeep....
    Do some google searching....
  3. Aug 1, 2015 at 7:43 AM
    Clearwater Bill
    Billy
    Largo Florida
    can't speak to Tacoma specifics on this topic, but poly bushings in other applications do at least 2 things...........
    Make the ride firm (or sometimes harsh) as they can be a lot stiffer than a new OE part
    Make a lot of noise once the assembly lube dries. Unless you get fancy ones with zerks
    But unless your vehicle has a lot of miles/load hauling/rough roads or weathered deterioration, I'd guess the squeak may well have another source.
  4. Aug 1, 2015 at 7:53 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Energy suspension makes great bushing kits.
  5. Aug 1, 2015 at 8:26 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Energry Suspension bushings. The black colored ones. As they are graphite infused.
    Try cleaning between your leaf packs first. I pulled mine apart and applied antiseize to them. Really helped.
    DoorDing likes this.
  6. Aug 7, 2015 at 5:58 AM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I just got new Alcon springs with polyurethane bushings and they started squeaking right off the bat. If I had to do it again I would go with the OEM bushings. Just my 2 cents. Anyone know what is the best grease to use on the polyurethane bushings?
  7. Aug 7, 2015 at 6:07 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I have found that a die grinder and a 4" wheel may be the fastest and easiest way to remove old, stuck bushing bolts, and them remove the bushings on a big press...and when reassembling, use PLENTY of grease on the inside of the metal sleeves.
    Howard
    Torspd likes this.
  8. Oct 7, 2015 at 6:26 PM
    tyfoon11
    tyfoon11 Raguel
    J
    Where bald eagles roam, Ca
    garden shed
    i'm going with Allpro std leafs, anyone know off hand part numbers or info for greasable bolts that would fit?
  9. Oct 7, 2015 at 9:23 PM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    The bushings they come with will accept an 18mm greasable bolt, which All-Pro carries, but you'll have to drill your hangers out slightly since the stock ones are 14mm I think.
  10. Oct 8, 2015 at 7:56 AM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    hmmm... so I just need to order bolts, or new sleeves as well? (or maybe could drill some holes in the sleeves that came with it?) thanks for the info!
  11. Oct 8, 2015 at 8:30 AM
    LikeABoss4x4
    Sarah
    So Cal
    The sleeves are meant to reduce the inner diameter to the stock bolt size, so they aren't needed with the 18mm greasable bolts that All-Pro offers, but the stock mounts won't accept that large of a bolt, so you'll have to drill them out slightly. Adding a lube system to the 14mm bolts may compromise the strength. I'd call All-Pro for more info.
  12. Oct 8, 2015 at 8:31 AM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    interesting. thanks!
  13. Oct 9, 2015 at 10:02 AM
    Mad Man Marty
    Marty
    PA
    I also would not drill.
    I would worry about compromising the strength.
    Contact All Pro.
  14. Oct 9, 2015 at 10:08 AM
    LikeABoss4x4
    Sarah
    So Cal
    Drilling the hangers would only be 2mm on the radius... very minimal. Drilling a 14mm bolt to make it greasable is questionable, which is why they use 18mm.
  15. Oct 9, 2015 at 12:25 PM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    hmmm this one is interesting, anyone tried this stuff? I was thinking of something similar but that one with the lip looks better and easier than buying sheets of plastic and cutting it up
  16. Oct 9, 2015 at 12:32 PM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    I have a new set of AP STD's I'm waiting to put on... I figured I should do it now and never worry about the squeaks again. how many rolls you buy?
  17. Oct 9, 2015 at 12:39 PM
    Mad Man Marty
    Marty
    PA
    Ding,those liners look perfect for building your own spring pack.
    Any plans on adding a Chevy spring to your pack like Old Man Doug recommends?
  18. Oct 9, 2015 at 12:46 PM
    tyfoon11
    tyfoon11 Raguel
    J
    garden shed
    AP STD's are 11 leaf with no overloads so I think i'll have to do all the layers. might end up being 3 rolls :confused:
  19. Jul 6, 2023 at 10:49 AM
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    Did you ever use those and did they eliminate the squeaking
