Leaf pack recommendations
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Yodastacotruck, Jul 21, 2022.
  1. Jul 22, 2022 at 11:14 PM
    #41
    mauctopa
    mauctopa Well-Known Member
  2. Jul 22, 2022 at 11:19 PM
    #42
    mauctopa
    BTW I'm running mine on option 2 and its great. I don't have about of constant weight but when loaded for a camping trim its not sagging. Rides great when empty too.
    Yodastacotruck[OP] likes this.
  3. Jul 22, 2022 at 11:26 PM
    #43
    Yodastacotruck
    Yodastacotruck [OP] Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    Nice how much weight are you carrying when camping? Do you know if sliders get weight into the equation as only the back portion are being supported by the rear it seems
  4. Jul 23, 2022 at 12:22 AM
    #44
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    Stage 2 seems to be the sweet spot. I’m running stage 3 because i have a decked drawer system, canopy, rtt, gear that gets me easily to 500-600 lbs.
  5. Jul 23, 2022 at 8:42 AM
    #45
    Tucker-Taco
    Tucker-Taco Well-Known Member
    Tucker
    North Carolina
    2017 Tacoma SR5 4WD
    I'm going to pull the trigger on the RXT's today too man. Can't argue with the price.
  6. Jul 23, 2022 at 5:40 PM
    #46
    Yodastacotruck
    Stock
    yeah the money you save thinking of getting the hammer hangers from archive also
  7. Jul 25, 2022 at 6:47 AM
    #47
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Yeah, they've been fixed for a few years now. No cutting is needed.
    Nothing on the internet expires, such as pain in the ass.
    jkish17 and GrundleJuice[QUOTED] like this.
  8. Jul 25, 2022 at 6:54 AM
    #48
    Crikeymike
    Jax Beach, Florida
    skeletron[QUOTED] likes this.
  9. Jul 25, 2022 at 6:55 AM
    #49
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Custom built packs are the best thing you could do.
  10. Jul 25, 2022 at 9:37 AM
    #50
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    What # packs are those? The picture you just posted shows a rub on the shackle, and either you don't have long enough shocks or haven't articulated enough to let the 2nd leaf exit the shackle, at which point it would jam into the shackle rib
    Dobinson's took the 110 and 111 and made the 2nd leaf longer! The 110,111 were fine originally
    Please post or message me pics of the shackle ends of brand new stock of 110, 111, 112 springs you have.
    Thank you
  11. Jul 25, 2022 at 12:12 PM
    #51
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    Here is my Dobinsons 110 that I purchased in early 2020 for reference. The second leaf does look shorter.
    ARCHIVE[QUOTED] and skeletron like this.
  12. Jul 25, 2022 at 1:17 PM
    #52
    HammerHedCampTRD
    HammerHedCampTRD New Member
    Brad
    2022 TRD Off Road
    completely stock w/ K02's
    I'm using the icon RXT. has 3 options you can switch between depending on the load. I like mine so far.
  13. Jul 25, 2022 at 1:37 PM
    #53
    ARCHIVE
    Eric
    Thank you for the pic, no clearance issues with that, in fact the leaf could be extended just shy of the shackle ribs
  14. Jul 25, 2022 at 1:43 PM
    #54
    Supr4Lo
    Surprise, AZ
    I had my date wrong it was early 2020 I got the 110's. But Yes, no issues with shackle clearance. Has been a fantastic leaf pack so far.
    ARCHIVE[QUOTED] likes this.
  15. Jul 25, 2022 at 2:07 PM
    #55
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    +1 for Deaver.
    I had the RXT for a few months but switched to the J66. Rides significantly better and is a much better designed pack. Their u402 will be perfect for what you're looking for without being overly harsh like the RXT is. Deaver is also known for making leaf packs. Icon isn't.
    When you swap them out, if you aren't changing the hangers at least grab some upgraded greasable shackles to throw on at the same time. The articulation of the pack is much smoother with aftermarket ones with bushings that do not bind.
    airmax233 likes this.
  16. Jul 25, 2022 at 2:26 PM
    #56
    dylanbike1
    dylanbike1 Well-Known Member
    Dylan
    2017 Tacoma TRD off road
    I have been running the Dobinson 110 (2.10-Inch Rear Lift Leaf Spring; 0 to 220 lb. Load), with Rago shackle hangers for 10k miles with wheeling in CO and UT. Great experience so far, and no squeaking or clearance issues. I got closer to 3" of lift with the Rago hangers.
    Ride is great with an empty bed/hitch, and also feels good with my 125lb bike rack + a few 35lb mtn bikes + a few camping bins (50-100 lbs). Install on the hangers was time consuming to grind off the factory rivets holding the original hanger, but ride quality is excellent. Did not need extended the rear brake lines (only 1.25" spacer on the hard line axle mount). Lastly, a completely deflated 35" can be crammed in between them in the stock location (requires a bit of effort).
    https://www.extremeterrain.com/dobi...t-leaf-spring-0-to-220-lb-load-l59-110-r.html
    If these will fit your application, you can buy both of these for the price of the Deaver leaf pack.
  17. Jul 25, 2022 at 3:08 PM
    #57
    Tacodephilly
    Tacodephilly New Member
    2020 Cement DCLB TRD
    I have been running OMEs 111Rs for two years. A bit bouncy unloaded but great when the rack is loaded with kayaks or towing the teardrop.
    Albert
  18. Jul 26, 2022 at 11:12 AM
    #58
    Yodastacotruck
    Stock
    Just picked up a set of icon rxt anyone know if I need new ubolts or anything to make these work?
  19. Jul 26, 2022 at 11:16 AM
    #59
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Should always replace the u-bolts whenever they come off. They're torque-to-yield and are only good for one-time use.
    I actually have a BNIB set of Deaver U-bolts that would be long enough to work with any config of the RXT. Hit my DM if you're interested.
  20. Jul 26, 2022 at 11:21 AM
    #60
    Yodastacotruck
    Stock
    thank you for the information much needed
    drizzoh[QUOTED] likes this.
