Largest Spare in Stock Location
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Freeheelbillie, Nov 18, 2020.
  1. Nov 18, 2020 at 5:28 PM
    Freeheelbillie
    Freeheelbillie [OP] Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    What are the chances a 315/75/R16 will fit in the stock spare location :anonymous:
    pop.tremuloides likes this.
  2. Nov 18, 2020 at 5:41 PM
    Josh-L
    Josh-L Well-Known Member
    2021 Silver SR DCSB V6 4x4
    I’m wondering if a 255/70R17 will fit too
    Freeheelbillie[OP] likes this.
  3. Nov 18, 2020 at 6:31 PM
    KanPanic
    KanPanic Rock Stacker
    State of Jefferson
    2018 OR
    285/75/17 will fit if you move hoist and bend the tire holder horns out. 315’s will not.
    drizzoh and DanishTaco like this.
  4. Nov 18, 2020 at 6:33 PM
    Freeheelbillie
    Billie
    Saint Clair, MI
    Figured, thanks.
  5. Nov 18, 2020 at 7:26 PM
    BRFab
    BRFab Well-Known Member
    BC
    '19 Alien Grey TRD OR
    Yes, it'll fit.
    255/85R16 mostly fit without bending the tabs. Tons of room after a little hammer time
    That's alot of lost ground clearance in a spot you'd want it
    hilighter, MJTH and t0nyvalenzuela like this.
  6. Nov 19, 2020 at 4:25 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    I had zero luck getting my 255/80r17 to fit.
    Im about to stuff it in there with about 10psi and keep an air compressor in the truck:anonymous:
  7. Nov 19, 2020 at 11:38 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    33" seems to be the limit. Mine is snug on the sides. Can't imagine anything larger fitting
  8. Nov 20, 2020 at 3:06 AM
    Freeheelbillie
    Billie
    Saint Clair, MI
  9. Nov 20, 2020 at 5:57 AM
    BRFab
    BC
    My understanding is the truck only holds 4 sensors at once, so there should be no light as long as the tires on the truck have sensors in them
  10. Nov 20, 2020 at 5:59 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    285/75/17 is a 34".
    It'll be nice if i can fit my 34" up there, I haven't tried yet though
  11. Nov 20, 2020 at 7:09 AM
    The_Devil
    E
    According to the Tire size calculator, 285/70/R17 are supposed to be 32.7" tires. My measuring tape says 32". I have Mud terrain.
    As you can see very little room left.
  12. Nov 20, 2020 at 7:13 AM
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I just barely got a 285/75/16 in there.
  13. Nov 20, 2020 at 8:22 AM
    Blueberry.Taco
    Ryo
    SE MI
    285 75 17 is not the same as 285 70 17
    SassySquatch69 likes this.
  14. Nov 20, 2020 at 8:26 AM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    So just confirming, you have a 285/70/17 spare and it fits with no modifications, hammering, cutting, etc.?
    I'm running on 285/75/17's but still have the OEM spare (265/65/17) and want to replace it with something bigger. I know the 285/75/17 wont fit in the spare well.
  15. Nov 20, 2020 at 9:21 AM
    The_Devil
    E
    I included the photo, because I never remember. 285/70R17
  16. Nov 20, 2020 at 9:25 AM
    The_Devil
    E
    I think he said 285/75/R16 which is almost the same as 285/70/R17
    32.7" vs. 32.8"
    The one you mentioned 285/75/R17 is larger
  17. Nov 20, 2020 at 9:27 AM
    mlr69
    South Carolina
    Sorry if my question was not clear, let me ask a different way...
    Did your 285/70/17 spare fit with no modifications, hammering, cutting, etc.?
  18. Nov 20, 2020 at 9:34 AM
    Law950
    Law950 Well-Known Member
    Ed
    2017 White Tacoma TRD Off Road
    Leveled with Icon Stage-3 suspension Toyo Open Country MT's, (LT265/75/R16) TRD Performance Exhaust TRD performance Air Intake
    I run 265/75/16 Toyo Open Country M/T's and have this same tire and size as a spare under the bed of my 2017 TRD O/R. The spare fits perfectly with no need to bend or remove anything under the bed...
    BC Hunter likes this.
  19. Nov 20, 2020 at 9:47 AM
    DeeKay20
    DeeKay20 Well-Known Member
    Danny
    Columbia MO
    2020 Tacoma DCSB TRD OR 6MT
    Dobinsons 2" lift, 33s....other stuff
    Keep in mind tire sizes change a bit from manufacturer to manufacturer too. I had Goodyear Ultra terrain AT that were a 1/2" narrower and about a 1/4" shorter than the same size Cooper ST Maxx.
  20. Nov 20, 2020 at 11:09 AM
    The_Devil
    E
    Yes, but I did have to push. It is snug enough that it stays in place on its own. (not while driving of course.)
