Large leak?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Trey3, Apr 6, 2022.
  1. Apr 6, 2022 at 1:44 PM
    Trey3
    Trey3 [OP] Member
    2010 tacoma trd spord 2x4
    None
    Says system to lean. And evaporative leak i can upload more pics of codes. It threw 5. Any one able to pin point it..trucks running ok
  2. Apr 6, 2022 at 4:30 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Is your Gas cap tight?
  3. Apr 6, 2022 at 4:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Check the evap purge valve at the intake manifold. It should hold vacuum at all times until commanded open by the pcm. Right at the valve, remove the evap hose going to the canister and attach a vacuum gauge. Unplug the electrical connector and run the engine. With the valve unplugged there should be no vacuum at all registering on the vacuum gauge. Any vacuum at all is a leaking purge valve
    Dm93 likes this.
  4. Apr 6, 2022 at 4:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    What are the other code numbers?
    A lean code and a incorrect purge flow code my first suspect would be that the purge valve is leaking.
    Easy to check, unhook the hose and electrical connector from the valve (shown below) and start the engine if there's vacuum present at the valve port it's bad.
    TnShooter and b_r_o like this.
  5. Apr 6, 2022 at 5:18 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
