Laptop stand / office for front seat?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jim727386, Jan 16, 2024.
  1. Jan 16, 2024 at 5:58 PM
    Jim727386
    Jim727386 [OP] Well-Known Member
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Plain Jane - Bare bones
    Hey all, has anyone used or built a laptop stand for use in passenger seat of their 3rd gen?
    As a “road warrior” sales person. I’m looking for something that can be quickly set-up to work from the road and also for web meetings.
    This may be a solution from Amazon. Thoughts, suggestions, input?
    AutoExec AUE20000 Efficiency FileMaster Car Desk Grey Finish
  2. Jan 16, 2024 at 6:16 PM
    caribe makaira
    Caribbean, Puerto Rico
  3. Jan 16, 2024 at 6:23 PM
    wazepd
    wazepd Waze Map Editor
    NJ / NY
    2022 Tacoma TRD Off Road
    Commercial Pilot
    RAM makes ones that bolt to passenger seats with a laptop tray, A lot of 3rd party manufactures do 1 inch ball mount accessories etc
    Probably can find a lower priced adjustable arm and tray
    Jim727386[OP] likes this.
  4. Jan 17, 2024 at 4:36 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    That is fantastic....but a tad too permanent.. I suppose I should make one or buy something pre-made that sits on passenger seat.
  5. Jan 17, 2024 at 5:01 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I have a "Mountguys" flexible one. Simple 1" ball on top for my RAM mount which holds my Microsoft Surface.
    Uses the seat mount bolts. No extra drilling or hardware needed. With the tablet holder removed (off of the ball) the passenger is not intruded upon much at all.
    Just did a 500+ mile round trip with my Bride and she never once said anything about the vertical mount bar being in the way. She did complain about the seat not going back far enough to recline in. (I have a wood top platform behind the seat which limits rearward movement from full travel.)
    Amazon.com: Heavy Duty Flexible 22“ Aluminum gooseneck ELD compliant car truck fleet floor seat bolt tablet mount for Apple iPad Air Pro Mini Microsoft Surface Pro/Book Lenovo Verizon 7 8 10 12 tablets : Electronics
    Jim727386[QUOTED][OP] likes this.
  6. Jan 17, 2024 at 5:11 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    Havis is the brand that most law enforcement use, but sounds like you are looking for something slightly better than a seat organizer.
  7. Jan 17, 2024 at 5:28 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Wow! That looks great...but i don't use a tablet. If I did, though that would work well.
    I just watched a review of the Autoexec "Reach" on YT. Whatever I do, I will post the results and review.
    https://www.youtube.com/embed/SbLKgYtS1Ko?si=BNugQbLRs7vtniGj
  8. Jul 13, 2024 at 4:21 PM
    Danzer
    Danzer Well-Known Member
    Derek
    Peoria
    22 SR5 4x4 AT
    Stock for now
    Did you ever find anything. I work from my truck 4 days a week and I really need something for my laptop and mouse on the passenger seat.
  9. Jul 14, 2024 at 7:24 AM
    Pinchaser
    Pinchaser Flipper Crazy
    Alan
    2020 Tacoma ECU 04B82 AT
    I cannot find the purchase info, but I bought a stand, I think from Amz, but must have been gifted, because not in my history. Anyhow, was pretty highly rated arm, that bolts a small bracket to one of the bolts of the passenger seat, then the arm comes up to a nuckle, then outreach arm to a shoe (quick release latch bed) then has a laptop mount, which doubles as a small lunch table with 2x cup holders (completely hidden when the laptop is mounted. I have had this on two separate trucks, works great for my PM work in construction; but no mouse surface, use the laptop touchpad.
    My laptop is HEAVY (gaming computed for heavy use of autocad), and the arm, though very nicely made, moved around too much, so I put a 1/4in hole in the bezel of the truck, and the lower vertical arm has a pin that enters the hole; making it very stable. the hole is in the plastic about the center nook, and the hole is not visible because it is under the bezel.
    The tray removes in a flash of ease, and I rarely remove the arm. It does not interfere with the passenger at all, so I just leave it. Though it takes less and a minute to remove the whole arm too, no tools, so that the only part remaining is the small mount at the seat bolt. Probably had this close to 10 years now.
    if you are interested, hope this is enough info to help.
  10. Jul 15, 2024 at 4:09 AM
    Jim727386
    Jim
    Enjoying Floridays
    2023 SR 4x4 V6 DCSB
    Unfortunately, no. I just set it on my back pack when I need to do something from the truck. Not comfortable but I haven’t found a solution that doesn’t have a drawback. Not spending until I do.
