Lag in Back-up Camera displaying on Pioneer AVH-1300
Discussion in 'Audio & Video' started by coreseller, Feb 24, 2018.
  1. Feb 24, 2018 at 12:47 PM
    coreseller
    coreseller [OP] Well-Known Member
    Hey Guys, just installed a Boyo VTL420 back-up camera in my son's 2006 Tacoma. We hooked it up to his also new Pioneer AVH-1300 Head Unit. Our problem is sometimes there is a 3 to 5 second delay from when the truck is put into reverse and the display comes on with the rear view, sometimes it does not come on at all. Does this sound like a ground issue? Also, I did use a heavier gauge wire (it's all I had on hand) to jump from the head unit down to the drivers side kick panel to wire into the reverse lights, could this be an issue? Thanks......Mark.
    FastEddy59 likes this.
  2. Feb 24, 2018 at 12:49 PM
    medic2230
    Murph
    Bama! Roll Tide
    The one in my Kenwood just switched over when there is a signal from the camera. No reverse signal needed.
  3. Feb 24, 2018 at 12:52 PM
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Mine just started doing the same thing but it's a Pioneer AVH4200NEX. Thought it was just the cold.
  4. Feb 24, 2018 at 2:19 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
    Did you tap for reverse signal in the cab? If you did, test to make sure you're getting close to 12v.
    I always tap at the reverse light, to assure that I'm getting a 12v signal.
  5. Feb 24, 2018 at 2:32 PM
    coreseller
    Yes, I pulled from the red wire behind driver's kick panel.
  6. Feb 24, 2018 at 5:47 PM
    Purpleman
    Anaheim
    15 PreRunner
    Test the voltage with a multimeter.
  7. Feb 24, 2018 at 8:33 PM
    coreseller
    Will do, Thanks.
  8. Mar 18, 2018 at 8:49 PM
    coreseller
    Long over due update, had son take it to a stereo shop and 30 minutes and $35 later it works. Best money i ever spent, we screwed around for several hours chasing that issue. Sorry but no clue what they did. Learned my lesson though, stick with what I know lol.
  9. Dec 6, 2018 at 7:10 PM
    will e
    will e Well-Known Member
    World Wide
    04 pre-runner
    Dominic Toretto Tuned with Extra Blinker Fluid
    Old post I know I know...But I figured others might be having this issue as well
    Anyways..I installed an ESKY Hd back up camera 170 degree into my 2004 with a Pioneer Avhp3200dvd head unit and in having a Delay when throw I beg it into reverse and I’m also getting the “Caution Screen image may appear reversed” screen popping up at random
    I tapped into the Red & Black wire in my Driver side tail Light. Heard another member mentioned that’s the Reverse Positive Wire. I also grounded the negative wire onto the body behind the tail light. I have the Yellow RCA video cable with the red wire pigtail, I tied that red wire in with the others with the Red & black Positives and ran the other end to the Head unit & Plus goes it in and tied the red pigtail wire with the Violet/white “labeled Reverse Wire in the back of my Pioneeer HU
    Any ideas Guys ?!?!? Maybe cold whether or my Ground and or I tapped into the wrong Reverse wire ?
    Thank in advance
