Ksp wheel spacers
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tim7902, Jul 4, 2019.
  1. Jul 4, 2019 at 6:37 PM
    Tim7902
    Tim7902 [OP] Well-Known Member
    Tim
    Maryville, TN
    2001 tacoma doublecab
    Anyone on here use ksp hubcentric wheel spacers? I've seen a bunch of people reccomend spidertrax and bora but I saw ksp spacers on Amazon with fairly good reviews for about half the price of other spacers. Any real world experiences with them?? Thanks
  2. Jul 4, 2019 at 6:54 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Check your lug stud length before making any spacer decision. Some of our Tacos have different lug stud length's between the front and rear. Due to the length difference, I went with 1" BORA spacers for the front and 1.25" Spidertrax in the rear for the type of wheel that I'm running. Also, make sure your front suspension (tie rod ends) are new or like new before you put on spacers. I had older tie rods that performed ok without spacers. Once I installed spacers, I could really tell the tie rods were weak. Spacers do add a level of stress to your suspension. Make sure the suspension can handle it.
  3. Jul 4, 2019 at 8:38 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Spacers arent something that you should stray away from the big names on. Im not a fan of them in the first place, but if you need them, get Bora or Spidertrax. If your worried about price when it comes to what holds your wheels on, maybe you should spend your money on other mods instead so you dont endanger other drivers when your wheel flies off.
    CS_AR likes this.
  4. Jul 4, 2019 at 9:39 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Never heard of the KSP. I'd stick with the known brands. I run Spidertrax with no issues and I've never been a fan of spacers.
    CS_AR likes this.
