KSP performance leveling kits.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoDelaroca, Oct 13, 2018.
  1. Oct 13, 2018 at 11:21 AM
    TacoDelaroca
    TacoDelaroca [OP] Well-Known Member
    Andrew
    2014 taco double cab short bed TRD Sport with 4x4
    Nothig yet
    What do you guys know about them?
    My co worker wants to give had one a kit he never installed.
    3" in the front 2" in the rear.
  2. Oct 13, 2018 at 11:56 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    They have good reviews on Amazon and spacer lifts are usually bashed on this site. I've had a spacer lift on my truck for about a year now (I think it's been about a year...) and it's been fine. If you're not hard off-road wheeling they will serve you fine.
    HOWEVER, I think 3" is too much lift for the Tacoma without changing upper control arms, etc. I went 2 1/2" on mine and my coil hits my UCA on full droop on the passenger side. I installed limit straps which took care of this problem but be aware of it.
    Also, going three inches will most likely produce the front axle vibration that necessitates the change of the front needle bearing to the ECGS bushing.
    In short, I think the kit is fine but 3" is too much. It's $40 on Amazon, if you want to lift it for cheap, buy the spacer that gives you 2" of lift (1" spacer).
    Others will be along shortly to tell you spacer lifts are crap.
    Your mileage may vary!!!
    Winkel
    TacoDelaroca[OP] likes this.
  3. Oct 13, 2018 at 1:32 PM
    TacoDelaroca
    Andrew
    Nothig yet
    Sweet! Thanks for that.
    I actually just ordered bilstein 5100 :bananadance::bananadance:
  4. Oct 13, 2018 at 2:08 PM
    winkel
    Corydon, IN
    From what most say here, that should be a good choice for you.
