Kobalt torque wrench issues
Discussion in 'Technical Chat' started by AviateGW, Aug 30, 2012.
  1. Aug 30, 2012 at 1:14 PM
    AviateGW
    AviateGW [OP] Well-Known Member
    Glenn
    Atlanta area
    Black '99 3.4 SR5 4x4. OME/Dakar
    16x8 KONIG Countersteer Offroads from FN, OME/881s in front, OME shocks/Dakar leafs in back. K&N CAI, and last, but not least, TRD Shift knob.
    Gents,
    This is not necessarily a Taco issue, but I need some advice/help with my Kobalt torque wrench.
    The damn thing doesn't 'click'.
    I've broken off two separate bolts now, at different torque settings, because I never heard a 'click' out of the wrench. I bought it new from Lowe's about a year ago and have had no luck with it. What, if anything, am I doing wrong here?
  2. Aug 30, 2012 at 1:16 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    did you turn it on?
  3. Aug 31, 2012 at 6:44 AM
    AviateGW
    Glenn
    Atlanta area
    It's mechanical...no on switch.
    I did however create several new 'expressions' after I broke the last bolt. I was damned near breaking the thing into a million pieces.
    G
  4. Aug 31, 2012 at 11:07 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Double check your torque wrench to make sure your applying the proper load. I work with a lot of tools (both literally and figuratively). Its a simple mistake to grab a ft lb torque wrench when your looking for in lbs. There are two types of torque wrenches that I know of, the breaking type (the 'click' as you call it) and the constant type (will have a gauge and a needle on it). It is also a possiblity that your torque wrench has been dropped and has lost its calibration. Which is why most companies do not warranty their wrenches. Just as a test, set the torque wrench at 10% above its lowest setting and torque a bolt into a peice of wood. If the wrench doesnt 'break', then your wrench is broken and needs to be recalibrated.
    -J
  5. Aug 31, 2012 at 11:15 AM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    Might be obvious, but remember that the 'click' is not always very load. I am not familiar with the Kobalt wrench, but I have two different torque wrenches and both of them are very subtle. It would be easy to miss it - almost just feel like the handle slips a little.
    I have heard one at a tire store the other day when I had my tires balanced that sounded like a .22 gun shot when it click - I guess it is necessary in a noisy environment like that, but mine are very quiet. Maybe you are just missing the click.
  6. Aug 31, 2012 at 11:26 AM
    jandrews
    '09 FourDubDee TRD OR
    Take it back. Kobalt is lifetime guaranteed.
  7. Aug 31, 2012 at 12:38 PM
    shemp
    shemp Well-Known Member
    A torque wrench is for finely tuned torque. It doesn't mean that you no longer have to pay attention and "feel" the bolt -- that is what should always prevent you from breaking bolts. Not the torque wrench.
  8. Aug 31, 2012 at 12:43 PM
    chrisman8995
    chrisman8995 Well-Known Member
    Newnan, GA
    05 PreRunner Double Cab
    ^this, I had a cheap air compressor that just went out. It was $250 from lowes and came with a small bs tool kit, walked in talked to the manager. He told me b/c its a kobalt and they dont have that exact one anymore they would give me whats comparable. It happened to be a $500 compressor alone. you shouldn't have any issues.
    BTW do you set it back to zero when you are done with it?
  9. Aug 31, 2012 at 3:49 PM
    AviateGW
    Glenn
    Atlanta area
    I don't set it to zero when i'm finished with it... pardon my ignorance, but what does that accomplish?
    As of now, I basically have a really shiny breaker bar. I'll try taking it back to Lowe's this weekend. The worst they can say is 'No, you can't get your money back/get a replacement.'
  10. Aug 31, 2012 at 3:55 PM
    AviateGW
    Glenn
    Atlanta area
    True enough. However, in the heat of the moment, I was, frankly, not realizing how much stress I was putting on the bolt. I'd been under the truck, solo, all day replacing the leafs and rear shocks (quick, appreciative recognition of Wheeler's - good people and good customer service) and was just about finished. I had a bad case of get-there-itis.
    Also, I am on a bulk cycle, and, experiencing some acne and mood swings. :violent: LOL...
  11. Aug 31, 2012 at 4:01 PM
    phantomblackgto
    phantomblackgto Well-Known Member
    Martin
    Parkville, MO
    2012 MGM TRD Sport 4x4 DCSB
    TRD exhaust, Debadged, Tacoma door sill protectors, Weathertech DFL's, Twoplankers center console organizer, Escort S2 cordless radar detector, AFE Pro Dry S air filter, Ultra Type 62 wheels 17x8 et +10 w/ 108mm - 106.1mm hubcentric rings, 265/70/17 Goodyear Wrangler Duratracs, Bilstein 5100's - front set to .85, Nfab 2" step bars w/ LineX coating
    I had a Kobalt torque wrench and the dial cracked. I took it back and Lowe's said I needed to send it in to Kobalt, they didn't handle warranty issues on Kobalt tools at the stores. I said the hell with it and went and bought a Craftsman. Never had an issue with the Craftsman. I won't waste my money on Kobalt tools again.
  12. Aug 31, 2012 at 4:03 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Take it back--I do believe it is warranted forever.
  13. Aug 31, 2012 at 4:21 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The TW will not always "click", but it will give a movement that you can feel.
    Most of my newer wrenches don't seen to give an audible click, but I can feel them in my hand.
    Since you don't know that you should back of a TW to it's minimum setting between uses, I'm going to gamble that you don't have a lot of experience with them.
    Set a TW to 10ft/lbs, and you can STILL crank them to 100 and break a bolt. The head of the wrench will "pop" a bit and you'll feel it, but it won't release like a ratchet. You still have to stop turning when the wrench informs you that you are at the proper torque.
    You re-zero the wrench to release tension from the spring and help the wrench hold it's calibration longer. Keeping the spring compressed 24/7 will lead to it gradually weakening and your "75" will only apply 50 to the bolt before the pop.
  14. Sep 1, 2012 at 7:12 AM
    AviateGW
    Glenn
    Atlanta area
    Correct- I don't have a lot of experience with torque wrenches. Thus, my hopefully, obviously humble, question to the forum.
    Nothing in the instructions said anything about resetting the wrench to zero after each use. As well, the instructions clearly stated that there should be an audible 'click'. I do clearly understand that the amount of torque that I apply can be enough to damage/break off a bolt. Ask me how I know this... :D
    All: thanks all for the kind input. I have learned more about my truck in the last 6 months or so of seriously reading this forum than from the prior 12 years of owning it.
  15. Sep 1, 2012 at 7:17 AM
    AviateGW
    Glenn
    Atlanta area
    Hey man, I'm down in Luthersville, just south of Newnan.
