KO2 265/75/16 psi?
Discussion in 'Wheels & Tires' started by Tacomajeff02, Mar 9, 2020.
  1. Mar 9, 2020 at 4:06 PM
    Tacomajeff02
    Tacomajeff02 [OP] Member
    2002 Tacoma pre-runner
    Stock
    i have some ko2 bfgoodrich 265 75 16 on stock rims and stock height. what psi do i run?
    using for daily commute
    GQ7227 likes this.
  2. Mar 9, 2020 at 4:26 PM
    badone
    badone Well-Known Member
    Jim
    NH
    03 Silver Tacoma TRD
    None at the moment
    I run 35 cold.
    Kolter45 and Tacomajeff02[OP] like this.
  3. Mar 9, 2020 at 4:27 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
  4. Mar 9, 2020 at 4:28 PM
    D-Rose
    D-Rose Well-Known Member
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    I run 42 in mine. Got 70k miles with even wear and maybe close to an extra mpg over 30 psi.
    Tacomajeff02[OP] likes this.
  5. Mar 11, 2020 at 8:40 PM
    eurowner
    eurowner Duke Sky
    Scoty
    What load rating? 10ply?
    SR-71A likes this.
  6. Mar 13, 2020 at 2:09 AM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    That must be brutally stiff. I ran my C load Duratracs up to 42 once and it was pretty uncomfortable. They did track a little straighter on the highway though. Wasn’t worth it to me in the end.
    04Pre_Runner likes this.
  7. Mar 13, 2020 at 2:15 AM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    Depends on ply. Chalk test it
    Kolter45 likes this.
  8. Mar 13, 2020 at 2:42 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    I run mine at 35.
  9. Mar 13, 2020 at 9:16 AM
    D-Rose
    Devon
    Las Vegas, NV
    2011 dcsb tx pro
    Mine are E load. It is a little stiff on the concrete freeways but not terrible. I’ve had them like that for 3 years and don’t notice anymore. What’s crazy is I have a tx pro and the door sticker says 46psi. 40-42 is my sweet spot with these tires.
    Navigator1[QUOTED] likes this.
  10. Mar 13, 2020 at 9:48 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What is the recommended psi on the door sticker?
    What number load rating was the OEM tire?
  11. Mar 13, 2020 at 6:10 PM
    splitbolt
    NW Arkansas
    26/29 psi in a P265/70/16/111 is equal to 36/38 psi in a LT265/75/16.
  12. Mar 13, 2020 at 6:19 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    265/65/r17 @35. decent tires on the truck when i got it. can't wait for my next set~
  13. Mar 13, 2020 at 6:23 PM
    Kolter45
    Denver, CO
    This is the best way!
  14. Mar 13, 2020 at 11:16 PM
    Jasonstacoma
    Stock
    265 75 16 sl wildpeaks at 37psi, chalked it, way over inflated, 31 front 29 rear chalked out great
  15. Mar 14, 2020 at 3:43 AM
    MattiveAmerican
    MattiveAmerican Well-Known Member
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    Need some info about how heavy the truck is and load range of the tires to give you a better idea of psi. But as others have stated, you don’t need us to guess what PSI you should run if you just chalk test the tires
  16. Mar 14, 2020 at 10:33 AM
    Kolter45
    Denver, CO
    What’s the general rule of thumb when you add weight? When I go camping I only take my tires up to 38 for extra weight. I’m @ 35 with the shell & with my gear (300/400 lbs) 38
  17. Mar 14, 2020 at 12:33 PM
    MattiveAmerican
    2006 White ACLB
    BuiLt 4 OveRLanDiNg
    I wouldn’t even mess with PSI over throwing just 300lbs in the truck. My question was more aimed at the OP. He’s asking what PSI to run daily. The answer to that question depends on whether or not his truck is stock weight, driving everyday with an extra 1000lbs, running stock load rated tires or load range E. I have complete skids, sliders, hybrid bumper with winch, full size spare, bed rack and tent. I daily LRE tires at 35 PSI have a very comfortable ride. Even fully loaded for a trip, which probably adds another 500 lbs, I don’t change the PSI I run. The only time I’d suggest messing with PSI for added weight is if you were running well below normal, and then added a significant amount of weight and were now pushing the max capability of the vehicle and tires
    Kolter45[QUOTED] likes this.
  18. Mar 14, 2020 at 12:40 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    I usually run 35 in the front and 33 rear (cold) when on the pavement commuting.
    Mine are the E-range
  19. Mar 14, 2020 at 12:42 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    i run 31 freezing warms up to 34? [​IMG]
