Knuckle replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyokntry, Aug 14, 2022.
  1. Aug 14, 2022 at 12:16 PM
    Toyokntry
    Toyokntry [OP] New Member
    Bart
    02 Tacoma extended cab 4WD
    Hi I’m new to the forum and need some input. I’m doing work on the front end of my 02 Tacoma 4wd, which includes bearings seals, ball joints and control arms and steering knuckle on the RH side. It appears to have been in some kind of collision by the previous owner because both the lower control arm and knuckle was tweaked. My question is the new control arm has a threaded hole and an open slot where the bearing goes through. My original does not. Does anyone know what this slot is for? Does it have some sort of cover? Have I got the wrong knuckle? The new one is OEM purchased on line from Larry Miller Toyota. Thanks in advance.
  2. Aug 14, 2022 at 12:17 PM
    Bishop84
    Bishop84 Well-Known Member
    ABS, you don't have it, so I'd make a small cover for it, use a 10mm bolt to hold the cover in place.
    Or return it if they can still source a non-abs knuckle.
    TnShooter and 3JOH22A like this.
  3. Aug 14, 2022 at 12:26 PM
    Toyokntry
    Bart
    I kinda thought it might be ABS. I’ll probably just fabricate a cover plate. Thanks so much!
  4. Aug 14, 2022 at 12:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Look on your receipt. Did you get 43201-35071 or 43201-35081?
    -35071 is the non-ABS version: https://www.ebay.com/itm/384547119344
    TnShooter likes this.
  5. Aug 14, 2022 at 3:06 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You had me confused when you said Control Arm then showed the Steering knuckle !
    Glad you figured it out.
  6. Aug 15, 2022 at 4:09 PM
    Toyokntry
    Bart
    Sorry? You’re right I meant steering knuckle, and it is P/N 43201-35081.
    Thanks!
  7. Aug 15, 2022 at 4:49 PM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
  8. Aug 15, 2022 at 5:56 PM
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
