Knock sensors and harness question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Partychief67, May 30, 2022.
  1. May 30, 2022 at 10:43 PM
    Partychief67
    Partychief67 [OP] Well-Known Member
    Adam
    '08 crew cab, 4x4, TRD
    None yet
    I'm doing a knock sensor and harness replacement and have questions about the thermostat housing or whatever that cast aluminum piece is at the front end of the coolant pipe that you have to remove to pull the coolant pipe out. Does anyone have a picture of that piece removed so I can see the bolt pattern? Also does it have a gasket that needs replacing or do you use some kind of form-a-gasket compound for it? I've searched the forum high and low and can't find any specific info for removing and replacing that piece.20220526_224813.jpg
  2. May 30, 2022 at 10:48 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Looks like it just uses O-Rings, you might run into it having some gray FIPG on it, replace it with FIPG-103 if so.
  3. May 31, 2022 at 10:52 AM
    Partychief67
    Adam
    None yet
    Thank you very much! Excellent information right here!
    Key-Rei likes this.
  4. May 31, 2022 at 3:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The 4.0 is also used on the FJ.
    A little Google-fu turned up This
    Hope it helps.
    TOMB and Partychief67[OP] like this.
  5. May 31, 2022 at 4:02 PM
    Key-Rei
    Key
    Florida
    Careful I know some years (if not all) of the FJ use the dual VVT-i motor not everything is the same or even compatible.
    tacoman45 likes this.
  6. May 31, 2022 at 5:35 PM
    TnShooter
    Deogee
    STOCK
    That is true. But I doubt there is a difference in the water by pass.
    I believe the 09+ FJ was Dual VVTI
    Partychief67[OP] likes this.
  7. May 31, 2022 at 5:49 PM
    TnShooter
    Deogee
    STOCK
    I just check my manual.
    The only difference is that the Tacoma manual says connect the the hoses to the oil cooler is applicable.
    Where as the FJ manual doesn’t say anything about it.
    Key-Rei and Partychief67[OP] like this.
  8. May 31, 2022 at 5:58 PM
    Partychief67
    Adam
    None yet
    Oh man this is exactly what I needed! Much appreciated! Shows that there are 3 more bolts underneath that I can't even see from up top
    TOMB, Key-Rei and TnShooter[QUOTED] like this.
  9. May 31, 2022 at 10:54 PM
    Longtech
    Longtech Well-Known Member
    Long
    SoCal
    15' OR converted 4WD
    That bypass pipe between the heads is not coming out unless a cylinder head is removed. Looks simple on the parts diagram there but it is bolted down in the rear passenger side cylinder head.
    Key-Rei likes this.
  10. Jun 1, 2022 at 7:40 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    This is correct. The FSM and corresponding service pricing has the head(s) come off to do this service, hence the reason the dealer quotes between $2300-4000 for this service.
    I just successfully replaced the harness on my buddy's 2006. The driver side connector wires were chewed completely through. I bear-hugged the top of the motor for the better part of an afternoon playing Pick Up Sticks with an assortment of pointy things including picks, screw drivers and bamboo chopsticks (no joke) but was able to successfully remove the entire harness and replace with a new one. Not a fun process but better than removing the heads!
    Good luck!
    Longtech[QUOTED] likes this.
  11. Jun 1, 2022 at 7:10 PM
    Partychief67
    Adam
    None yet
    I've got it broke down to this point but had to quit tonight because my work lamp burned out. The larger pipe will definitely come out. It has some play in it and it moves around enough to know that it will slide out of that rear casting. Going to get some curved jaw vice grips tomorrow to get a better hold on it.
  12. Jun 2, 2022 at 4:24 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I'm super interested to see what you come up with, so please keep us posted.
    After working on Toyota trucks my whole adult life and usually always being impressed with the thoughtful engineering towards ease of maintenance, I couldn't believe Toyota would design the crossover pipe not more easily removed. The crossover pipe in my 5VZ-FE needed resealing as it aged, which was a common problem, so figured they did away with the coolant pipe unions there forgoing ease of maintenance for long-term reliability. Definitely interested to see what you come up with.
  13. Jun 2, 2022 at 4:28 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Just revisiting the diagram. How easy are these three bolts to remove? I don't remember having easy access to them.
  14. Jun 2, 2022 at 6:45 AM
    Partychief67
    Adam
    None yet
    You have to saw cut the front one and I believe the rear two are attached only to the smaller diameter pipe. I am following a YouTube tutorial video and I believe that's correct. I'll post the vid later today.
  15. Jun 2, 2022 at 8:39 AM
    Partychief67
    Adam
    None yet
    Here is the video. The pertinent part starts around 14 minutes in.
    Watch "How to replace Knock Sensor 2003-2009 Toyota 4Runner" on YouTube
    https://youtu.be/hwVcU7mkap4
    DesertRatliff[QUOTED] likes this.
  16. Jun 3, 2022 at 6:03 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    ^^^^Man. Wish I had found this video before taking this on. That would have saved some time, although I don't think my buddy would have approved of the bracket cut method. Thanks for posting, though, Partychief.
    Regarding the video, and for posterity, I didn't bother unbolting and moving the fuel rails or even disconnecting the fuel lines from the manifold. Plenty of slack in the fuel lines to just swing it all out of the way.
    On another note, anyone else pucker before he stuffed towels into the intake ports while unbolting those 10mm crossover pipe bolts?
  17. Jun 3, 2022 at 4:13 PM
    Partychief67
    Adam
    None yet
    I finally got it out. The hardest part was pulling the cab end of the pipe out of that cast housing in the back of the block. I had to rig up a homemade puller out of a twisted rope and a couple of pieces of stiff rebar braced against the frame.
    Leomania likes this.
  18. Jun 4, 2022 at 11:16 AM
    Partychief67
    Adam
    None yet
  19. Jun 4, 2022 at 11:26 AM
    Partychief67
    Adam
    None yet
    Bumping to ask for additional info. The knock sensor harness runs down the valley and bends down into the gap between the firewall and back of the block. I'm looking for the connector to unclip the old harness and attach the new one. I've looked from above, through the fender well and crawled underneath and looked up looking for that clip and can't see it. Does it go through a hole in the firewall?
  20. Jun 4, 2022 at 11:31 AM
    Partychief67
    Adam
    None yet
    In that diagram are those Toyota part numbers? I've tried googling a few of them and also searching Amazon to order some new ones and coming up empty handed.
