Kingpin Equipped lights
Discussion in 'Lighting' started by Burroma, May 8, 2024.
  1. May 8, 2024 at 1:42 PM
    Burroma
    Burroma [OP] Member
    2014 regular cab
    Does anyone have any experience with the lights from this company? From what I can tell, they seem relatively new to the market, so I haven't been able to find any genuine reviews about the lights outside of their own website.
    They look well-built and straightforward to use. However, they seem a bit overpriced for what they are. I'm bouncing back and forth between trying these out and doing some DIY LED strips with diffusers.
    BrashBrusier likes this.
  2. May 12, 2024 at 7:02 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i agree, they do look overpriced. the mounting solution for the light units does appear novel/different though.
    the dimmers, appear to be roughly $15 more than the same option most other places are going to have.
    https://www.amazon.com/Dimmer-Single-Dimming-Controller-12V-24V/dp/B08YFFY682/
    this, and a few other copy-cat designs are what i know of that come as close to the same mounting/rotating solution as those.
    https://www.amazon.com/LED-Bar-Light-resistant-convenience/dp/B0051BSFY6
    https://www.amazon.com/LED-Bar-Light-resistant-convenience/dp/B0052GJC9W
    but none of those will come in anything less than a 6000k light.
    i guess the question becomes, how much do you require the rotating/waterproof assembly in your install location. personally, i like as much light as i can get anywhere--waterproof is easy, rotating isn't. i would recommend this $20 waterproof COB strip with those $5/ea dimmers for general campsite lighting far faster than $70 into one 12" single light and dimmer setup...
    the biggest thing is to look for a 4000k color temp for more natural-appearing lighting
    https://www.amazon.com/GOMING-COB-Waterproof-1560LEDs-Flexible/dp/B0C4PCSYJF
  3. May 30, 2024 at 11:02 AM
    Burroma
    Burroma [OP] Member
    2014 regular cab
    This seems like a much better option. Thank you for posting this
    soundman98 likes this.
