King Shocks pics and any stories
Discussion in 'Suspension' started by bigb0078, Jul 27, 2014.
  1. Jul 27, 2014 at 3:03 PM
    bigb0078
    bigb0078 [OP] Active Member
    VA Beach
    14 Toyota Tacoma TRD Offroad
    6" Fabtech Suspension King Shocks front coil overs Atlas Rear Springs Fuel Lethal wheels 20x12 Nitto Tires 33x12.50 Pro Comp Traction Bar Step Bars
    I decided to go with Kings over Icons. The ride is so much better.
    0210 likes this.
  2. Jul 27, 2014 at 3:05 PM
    bigb0078
    VA Beach
  3. Jul 27, 2014 at 3:06 PM
    bigb0078
    VA Beach
  4. Jul 29, 2014 at 7:44 PM
    sodoscott
    sodoscott Well-Known Member
    south california
    2006 tacoma trd off road mid-travel
    kingshocks, total chaos
    Hi Looks clean! How much lift did you get ?
  5. Jul 29, 2014 at 11:15 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    You had Icons previously?
  6. Jul 30, 2014 at 4:51 AM
    bigb0078
    VA Beach
    It's a 6" Suspension Lift.
    I had Icons on a previous model Tacoma that why I changed over to Kings. They are a smoother ride all around. Don't get wrong Icons are good but Kings are better.
  7. Jul 30, 2014 at 4:57 AM
    Mad T
    Mad T Well-Known Member
    Thomas
    Georgia
    Good looking truck! 4wd?
  8. Jul 30, 2014 at 6:33 AM
    bigb0078
    VA Beach
    Thanks, and yes it is 4WD. Built more for street use but ready for offroad when needed. Im not a big offroader but fully capable of it.
    snox31 likes this.
  9. Jul 30, 2014 at 7:15 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    Did the previous Tacoma with Icons also have a 6" lift?
  10. Jul 30, 2014 at 8:07 AM
    drop4205
    drop4205 Well-Known Member
    Windham, Maine
    14 TX Baja
    Pioneer 8201 nex Id cxs 6.5 component front Id cs 6.5 rear Jl audio hd 600/4 Jl audio 10” micro sub+ Ram mat Tinted windows Debaged Plasti dip front emble
    that is nice. Which lift did you get. Basic or performance. It sucks to buy a lift and then have to change the shocks to better ones. I wish you could just buy the parts for the lift then buy your own leaf pack, coils and shocks. I was on fabtech site and it says the 6"lift does not fit the Baja version which is what I have. Any idea? thought it have the same leaf and front end as a regular TRD?? any input would be appreciated
    TidtheKid likes this.
  11. Jul 30, 2014 at 8:46 AM
    bigb0078
    VA Beach
    You can buy just the suspension lifts. Just order the box 1 and box 2 packages from Fabtech. Order your rear springs and shocks seperate from whoever you want. Just make sure when you order your new springs and shocks that they are "made to order" for the size lift your are getting.
    Watchout for some companies giving you the go around on getting the shocks "made to the order" you want. Some will say we need demensions and all kinds of other stuff. I made a quick call to King and took all but 5 minutes to get mine ordered. No hassel at all.
    Also keep in mind that these made to order parts will take 3 to 4 weeks. Dont expect any sooner. You can plan out and order everything to show up within the same week and get started without having to wait.
  12. Jul 30, 2014 at 8:54 AM
    bigb0078
    VA Beach
    I little bit better explination on the valving for shocks. Just have to determine which setup is best for your style of driving is all.
    Valving Characteristics
    A shock absorber uses different valves and springs to adjust the dampening force of that particular shock. There are three types of valving characteristics that dictate how the shock will perform. They are progressive, linear, and digressive. Progressive shocks start out soft and get stiffer quickly as the shaft speed increases. Linear shocks uniformly increase stiffness as the piston speed increases. It is similar to the progressive valving but does not make dramatic changes at higher speeds. Digressive is just the opposite of progressive. It starts out stiff, then it tapers off.
    Tacoma14DCLB likes this.
  13. Nov 9, 2015 at 11:21 AM
    Tacoma14DCLB
    Tacoma14DCLB Member
    2014 White Tacoma TRD Sport DCLB
    Leveling kit Leer camper top
    I LOVE your set up. Clearly, you have done your homework. Would you be so kind and post the links to the "box 1 and 2" you got From fabtech and which springs and shocks you got :) trying to price a few things out..
  14. Oct 21, 2016 at 5:00 PM
    Misterglass27
    Misterglass27 Well-Known Member
    Cape Cod, MA
    13 Tacoma TRD Sport
    4"BDS drop bracket, Custom length King coilover remote reservoirs in front and custom length king remote reservoir Shocks out back, 6" total lift. Mickey Thompson Wheels and Tires, Procomp Traction Bars, Flowmaster Catback exhaust and firestone air bags in rear. EBC drilled/slotted rotors, pro comp skid plate, DirtKing UCA's with a double shear kit, and DirtKing LCA's with Kartek limit straps. VIAIR on board air, undercover swing cases, and truxedo toneau cover. Grillecraft Billet, Switchback LED's and HID Projector headlights, and LED tails. Volant/Donaldson intake, redline hood struts, and HPS silicone hoses.
    I have the same rear shocks, do they oxidize (or stain) immediately after you drive in the rain or go in mud? Mine do, I have to polish them every couple weeks or they get real bad with spots that are hard to get out
  15. Oct 22, 2016 at 11:12 PM
    agunday21
    agunday21 Well-Known Member
    Michael
    Flagstaff
    2015 White DCSB TRD OR 6spd MT
    •Total Chaos Uniball UCA's •2.5" King Coilovers •Deaver custom U402 leaf springs •2.5" Rear King Smoothbodies •16x8 Method Standard's •LT285/75-16 Goodyear Duratrac's •Wilco Offroad PreRunner Tiregate •Stewart's Race Works floorjack mount - mounted in bed •3 ton HF floor jack - mounted in bed •Cab Mount Chop - Relentless Fab Plate •Flattened pinch weld •BAMF Sliders (bolt on + no kickout) •Spintech 6000 muffler •Relentless Fab Bed Bars •CVT Mt. Shasta
    Have run kings on our racecar (jeepspeed) since I was a kid and have had them on all of our trucks. They also have great customer service if you give me a call or get a chance to stop by their shop in Garden Grove. I'll never run another brand of shock
  16. Oct 28, 2016 at 11:51 AM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Good to hear. ICON's custom service is worse than shit. If I ever get different suspension down the line, it'll be Kings.
    agunday21[QUOTED] likes this.
  17. Nov 2, 2016 at 1:03 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    This lift is tempting.....
  18. Nov 25, 2016 at 1:14 AM
    Dbmann80
    Dbmann80 Well-Known Member
    Michael
    Agoura hills, CA / Grants Pass, OR
    04 LT 4x4 DMZ,CAMBURG ,13 cummins,13gtr,15gtpp
    Front camburg longtravel w/fox shox, tundra front cv's/axles, custom front bumper made by camburg w/hella 4000s,rear bed cage with 16 inch triple bypass fox shox,under sprung f67 deaver , fox bumps all corners, glassworks all corners, kar-tek limit straps all corners,DMZ fabrications, meathod race wheels, general red labels, Too much to list, and more to come.
    Have you given Fox a consideration ?
