King or Fox shocks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BcTacoma96, Apr 28, 2020.
  1. Apr 28, 2020 at 3:46 PM
    BcTacoma96
    BcTacoma96 [OP] New Member
    Cory
    2011 Off Road Tacoma
    3 inch lift kit on 33’s, RTT
    Im getting a new Tacoma soon and i dont know whether to get King or Fox shocks. Ive done some research but figured id see what the news is in TacomaWorld... could someone explain the key differences?
    thanks in advance!
  2. Apr 28, 2020 at 3:50 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I am a complete Mall Crawler and had 5100's etc and finally just went with KING even though I don't need them. Figure out your budget, uses etc.
    NWTacoTime and BcTacoma96[OP] like this.
  3. Apr 28, 2020 at 3:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    HeadStrong Off-Road likes this.
  4. Apr 28, 2020 at 3:52 PM
    mud
    mud Djentleman
    SoCal
    2019 TRD OR DCSB LMNOP QRS TUVWXYZ
    Kings don’t look good when they’re dirty. So if you hate cleaning, go with Fox.
    NWTacoTime likes this.
  5. Apr 28, 2020 at 3:52 PM
    HeritageTRD
    HeritageTRD Well-Known Member
    Washington
    98 4runner 3.4 V6 5spd MT Anthracite Metallic
    265/75/R16 BFG KO2's on Akuza 359 wheels - Sport Hood Conversion - Trail Gear 60" Rock Sliders - Rola Roof Rack - Custom Front Recovery Points - Hella 500 fogs - Flowmaster 50 series - Smoked Tails - Clear Corner & Turn Lenses - 5% Tint - GT Exact Seat Covers - Kenwood DVD & Alpine Speakers.
  6. Apr 28, 2020 at 3:53 PM
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    From Headstrong:
    Fox has stock replacement 2.0” and 2.5” diameter coilovers. Their 2.0 coilover is standard travel and a 13” 600lb coil spring. Their 2.0 performance series shocks have an aluminum body which is nice for areas with heavy salts. The 2.0” coilovers come preset to provide around 2” of lift on a 05-15 4x4 and around 1” of lift on a 2016+ 4x4. Due to the nature of their 2.0 coilover adjustments are not easily made and tend to affect the ride quality quite a bit. As far as their 2.5” coilover goes that comes in standard travel or extended travel (requiring uca's). The standard travel does not require upper control arms however they can be needed if the coilover is adjusted up for lift and proper alignment cannot be achieved. The Fox 2.5’s come in an IFP version as well as with reservoirs and optional dual speed compression adjusters. They come standard with a 13” 600lb spring rate coil. Fox does not offer coil changes so if you wanted a higher spring rate they would have to be sourced separately. We do offer this service for our clients. We carry a 14" 600lb, 14" 650lb, and a 14" 700lb and it is an additional $250 total for the coils and the labor to switch them out. Their 2.5” shocks have a zinc plated steel body. They have a progressive valving which some feel can provide a plusher on-road ride quality, depending on terrain and speed but still performs well on a variety of off-road terrain. Fox specs out the 2.5” standard travel coilovers to provide around 0-2” of lift and the extended travel 0-3” of lift. They come preset to provide around 2" of lift on the 05-15 4x4’s and around 1" on the 2016+ 4x4 models. They can be adjusted to provide more or less lift depending on what suits your needs. Keep in mind, whenever adjusting a coilover you need to make sure that they are not adjusted to a point that will cause coil bind on compression. As a side note, due to the weight of the 3rd gen 4x4’s I have seen coil bind issues when people try to preload the stock Fox 13” 600lb coils up to gain 3” of lift so a coil swap would be something to consider if this pertains to you. For the rear Fox has their rear 2.0 rear shocks in either an IFP version as well as with a reservoir and optional dual speed compression. They do have very conservative travel numbers so we do not recommend their 2.0 IFP if you plan on running a rear lift. They also have a 2.5" rear shock available as well and that can come with remote reservoir and also has the option for dual speed compression. Again, Fox has a very conservative extended length for their shocks so we do make pairings based on the rear lift chosen and actual specifications of the rear shock instead of going off of Fox's lift guide.
    King has a 2.5” diameter coilover that comes in standard travel and extended travel (requiring uca's) with a hose reservoir and optional compression adjusters. The standard travel does not require upper control arms however they can be needed if the coilover is adjusted up for lift and proper alignment cannot be achieved. Typically the King coilovers come built with a 600 lb spring rate but we also offer a 650lb and 700lb spring option at no additional charge. King shocks feature a steel body and aluminum components. They also feature a vehicle specific progressive valving which means that they provide an excellent compromise between on-road ride comfort and off-road performance. They come preset to provide around 2.5" of lift on the 05-15 4x4’s and around 1.5" on the 2016+ 4x4 models. They can be adjusted to provide more or less lift depending on what suits your needs. Keep in mind, whenever adjusting a coilover you need to make sure that they are not adjusted to a point that will cause coil bind on compression. As a side note, due to the weight of the 3rd gen 4x4’s I have seen coil bind issues when people try to preload the 600lb coils up to gain 3” of lift so a 650lb coil may be a better option if this pertains to you. For the rear King has a 2.5" with hose reservoir with optional compression adjusters.
    Surfinjoe, Kel2427, old55guy and 3 others like this.
  7. Apr 28, 2020 at 3:56 PM
    calebc
    calebc Well-Known Member
    Why not ADS or Elka? (FWIW, I went with Kings, love em and would do them again in a second)
    HeritageTRD and NWTacoTime like this.
  8. Apr 28, 2020 at 3:59 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Lol, was on the same boat as you when I was looking at my second pair of suspension (didn't like the Bilstein). Went with Radflo because I knew a shop that makes rock bouncers/hill assault buggies that uses Radflos and Radflo the company themselves are a built to order suspension. Meaning valving, spring rate, length, etc are all custom-tuned to your vehicle free of charge.
    See if you can ride in kings or fox and which one you like better if you are sensitive to suspension. If you can't tell the difference, price and quality will be your determining factor.
  9. Apr 28, 2020 at 4:03 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    So do you just want to have what everyone else has and be one of the cool kids and get some istagram clicks? If that's the case, Fox all day long.
    Or do you want to try and get what suits you the best based on your budget, driving style, terrain, etc...?
    For a daily driver with an occasional jaunt on some dirt roads, I see no reason to spend $2000 on shocks. That money is much better spent on beer and tacos.
    I'm going to assume you're a novice off-road driver. If that is indeed the case, honestly don't worry about which shocks you "need". Go out and drive your truck and have fun with it. Get it dirty. Later on down the road (trail) and you end up wearing them out, or need some other modification, like bigger tires and better traction, or you want more wheel travel, then it's smart to start thinking about the type of shock you "need".
  10. Apr 28, 2020 at 4:07 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nice, I wonder if my 2.5's came w 1"of lift. It certainly doesn't seem like it. Seemed stock height.
    OP I went with fox 2.5's cause I got a stupid good deal, get whatever suits you.
  11. Apr 28, 2020 at 4:16 PM
    Dc2tacoma
    Dc2tacoma Well-Known Member
    I would get what everyone got.
    Skydvrr likes this.
  12. Apr 28, 2020 at 4:27 PM
    jbrandt
    Justin
    OMG DIRT!!!
    :rofl:
    mud[QUOTED] likes this.
  13. Apr 28, 2020 at 4:37 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  14. Apr 28, 2020 at 4:41 PM
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    ADS FTMFW. Best on the market.
    jeremy5000 likes this.
  15. Apr 28, 2020 at 4:46 PM
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    King and Fox are not the only ones I would look at. You should consider Bilstein 8112’s and ADS also.
  16. Apr 28, 2020 at 5:15 PM
    BcTacoma96
    Cory
  17. Apr 28, 2020 at 6:37 PM
    firebert
    firebert Member
    CA
    2001 SR5 DC & 2017 TRD Sport DC
    I went with King just because they're 5 minutes from my house
    In&out likes this.
  18. May 28, 2020 at 8:54 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you @Unchained 5150 for your recommendation we greatly appreciate it!
