king 3" lift kit
Discussion in 'Suspension' started by TenFortythree, May 21, 2017.
  1. May 21, 2017 at 12:01 PM
    TenFortythree
    TenFortythree [OP] Well-Known Member
    K
  2. May 21, 2017 at 5:36 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    The king's are going to give a rough ride set at 3 inches. 2.5"s is suggested as the max by King.
    agunday21 and TenFortythree[OP] like this.
  3. May 21, 2017 at 5:38 PM
    TenFortythree
    i shouldnt have any problem fitting 285/75/16 at 2.5"?
  4. May 21, 2017 at 5:46 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    :bananadead:
    tetten likes this.
  5. May 21, 2017 at 5:49 PM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    There are 10,000 threads on this topic. Those tires require trimming and chopping regardless of lift.
  6. May 21, 2017 at 5:52 PM
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    :deadhorse: that's a lot of money
  7. May 21, 2017 at 5:54 PM
    TenFortythree
    what are you running and the end cost?
    90yota[QUOTED] likes this.
  8. May 21, 2017 at 5:54 PM
    3coma
    rob
    You're gonna have to trim if you want to run 285's, and probably chop the cab mount. The other thing is are you set on going with a 3" lift or will 2.5" be ok? The higher you go the more stress you put on CV's and more drive shaft vibration possibilities. Both kits you linked are very good, but be prepared to have to troubleshoot those problems after installation.
    90yota likes this.
  9. May 21, 2017 at 5:56 PM
    90yota
    88 T4R / 15 F350
    Stock....ish
    @JT@Bajakits UCA with king's w/adjusters up front
    rear is OME dakars with bilstien 5125's
    I'm at about $4k for the lift. I really don't remember
  10. May 21, 2017 at 6:01 PM
    bullaculla
    Da big big island!
    Kings are worth it.
    trdtacomahi likes this.
