Kill switch wired to auto trans neutral safety?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rustytoys, May 31, 2019.
  1. May 31, 2019 at 8:40 AM
    rustytoys
    rustytoys [OP] Active Member
    USA
    1999 Toyota Prerunner
    I want to install a hidden toggle kill switch, I have an auto transmission, so Im thinking a switch wired to mimic the truck being in gear, has anyone done this?
  2. May 31, 2019 at 8:47 AM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Just wire in a fuel cut-off switch if you're worried about it being stolen.
    Sam_Bam likes this.
  3. May 31, 2019 at 8:54 AM
    rustytoys
    USA
    The problem with fuel pump switches is that you have to design the whole toggle system to handle that constant power - from what I have read you should use a relay or the toggle will burn up (according to some stories Ive seen at least), once you add a relay then the whole setup gets really complicated.
    The neutral safety switch seems cleaner (in theory at least) as you dont have to deal with managing constant power through your toggle setup. Just not sure where to start in wiring a setup like that.
  4. May 31, 2019 at 9:31 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    This is from the 1996 FSM. It shows a wire from the switch to the starter relay. I'm no electrical expert, but you might try to locate this and interrupt it and see what happens.
  5. May 31, 2019 at 11:33 AM
    rustytoys
    USA
    Thanks. This is why I wanted to do this as a simple interruption would achieve the goal. I am horrible at wiring diagrams too, do you think the "B-R" means the wire is black/red color?
  6. May 31, 2019 at 11:41 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Why not just interrupt the ECU Signal to the circuit opening relay? That would prevent power from being sent to the fuel pump.
    Wyoming09 and Teke like this.
  7. May 31, 2019 at 12:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    All you need to do is break the ground side of the circuit opening relay coil done
  8. May 31, 2019 at 1:24 PM
    rustytoys
    USA
    Thanks, any idea what color wire that is?
  9. May 31, 2019 at 1:29 PM
    rustytoys
    USA
    So I assume the ECU signal is some kind of low voltage? Again, don't want to mess with any hot wires, what about ground as has been suggested? My main concern is that whatever is done does not hurt the relay over time, but I guess if were mimicking a stock process that would be fine.
  10. May 31, 2019 at 1:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I believe signal is a very low amperage 12v signal, just enough to keep the coil engaged.
  11. May 31, 2019 at 5:11 PM
    rustytoys
    USA
    Thanks, I saw online most of these fuel relays are a green box, but just looked under my dash and I dont see anything like that unfortunately, any idea what to look for?
  12. May 31, 2019 at 5:47 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The fuel relay is called the circuit opening relay. It is green. You might have to remove the driver’s side HVAC duct to find it.
