Kill Switch Mod Write Up.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SurfInferno, Apr 20, 2010.
  1. Apr 20, 2010 at 3:14 PM
    SurfInferno
    SurfInferno [OP] Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    Well i found out how to make a kill switch for out trucks. I have a 2nd gen so i dont know if it will work on a 1st gen. I found it by complete accident but has turned out pretty cool. In case you park in sketchy areas, well heres one more thing to secure your truck.
    First Buy a 2nd gen tacoma of your choice.
    Step one.
    If you have a non working dealer alarm system....remove it. its annoying anyways.
    There are lots of wire splices that just pop off if they are pulled. And there are two wires you have to cut. THIS is your ignition wire (sorry i didnt get a pic) so make sure you leave extra.
    With it removed
    Step two
    Freak out and think your starter is gone, push it pop the clutch and drive it to a dealer. Then pay $105 to have them tell you that the ignition wire is cut and that it will be another 100 to fix :eek:
    OR Follow step 3 (this is where you would start if you dont have the stupid alarm thing)
    Locate and remove the change holder, gun holder, knife holder, whatever you want to call it
    Step 4
    In the cluster of wires there is a green wire with a black stripe. This is your ignition wire. To to this mod you have to cut it, if you dont feel comfortable, then dont. (for those with the alarm that was removed you had to cut two orange wires. these are attached to your ignition wires,by a butt splice.
    Step 5
    Attach a butt splice to the wire if it is two short, adding exra wire in order to get a female crimp connector to it. The ones without the alarm might have enough slack you can skip this step.
    Step 6, repeat step 5 for the other wire.
    Step 7, Attach a switch to the two wires. I used one i just had laying around, so i have to push the button in order to start the truck. I will change it later. You can use just and regular switch and turn it off and on when you want.
    If you are using a regular switch then congrats your done! Just put everything back together.But if your like me and you use the push button switch then there are two more steps.
    Step 8
    Drill a hole in the back of the change holder.
    Step 9
    Put the switch in the hole, Test it, put everything back together
    Im going to get comments on how bad my blue switches are haha. I know, i was in a hurry, and ill but new ones some day
    I should probably add that I'm not responsible if you screw up your truck. So please do not screw up your truck! Do it at your own risk
  2. Apr 20, 2010 at 3:28 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    [​IMG] Good write-up, thanks.
  3. Apr 20, 2010 at 3:35 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    Good one. Similar to how we wire up our police cars. They have a button in the area of the pedals that needs to be depressed before you can shift gears and get the car going. Speaking of those switches, what did you wire them to?
    Gunshot-6A likes this.
  4. Apr 20, 2010 at 3:35 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    If I read the wiring diagram for the starting circuit correctly, you have interrupted the signal that goes from the ignition switch (ST2) to the starter relay (Pin 5). This would definitely server as a kill switch. Nice!
    :proposetoast:
  5. Apr 20, 2010 at 3:37 PM
    jandrews
    '09 FourDubDee TRD OR
    :rofl:
    RA77 likes this.
  6. Apr 20, 2010 at 3:48 PM
    Crom
    Nick
    San Diego, CA
    Millions
    haha butt spice. two short should also be too short. Where is jigzor?
    blairrad likes this.
  7. Apr 20, 2010 at 3:58 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    I just put the switch in the circuit. Not sure on the question.
    And tioTaco No Problem!
  8. Apr 20, 2010 at 4:57 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    hmmm...maybe you should keep the switch location secret?
    hahaahh..great write up.
  9. Apr 20, 2010 at 5:01 PM
    Timber
    Timber Crankey Old Yacht Jockey
    Tim
    San Pedro Bay Ports
    just a couple comfort items.
    I like it! Nice job.
  10. Apr 20, 2010 at 5:29 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    FUN another cheap mod. i'll do it for shits and giggles
  11. Apr 20, 2010 at 7:26 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    hahah sounds good. maybe itll save your truck one day
  12. Apr 20, 2010 at 7:42 PM
    jefferson
    Sex Panther
    05 PreRunner SR5
    Yup. unless all you jackasses know where the switch is..
    Btw.. where do you live? :cool:
    RA77 likes this.
  13. Apr 20, 2010 at 7:46 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :lalala:
    ...I love this idea, btw.
    RA77 likes this.
  14. Apr 20, 2010 at 7:48 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    somewhere secret....and far away :p
  15. Apr 20, 2010 at 8:53 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Holy hell, did the dealer install that little box by your hood lever? And what is up with those rocker switches!?
  16. Apr 20, 2010 at 9:03 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    yea....they did a really bad job, it pissed me off. haha
    HAHA i knew someone was going to comment on how bad they are hahah. They are for my grill lights, and my fogs.
    I even put a small disclaimer :p
    "Im going to get comments on how bad my blue switches are haha. I know, i was in a hurry, and ill but new ones some day"
  17. Apr 20, 2010 at 9:09 PM
    Baadboy11
    Baadboy11 Well-Known Member
    Lee's Summit, MO
    07 DC SB Offroad 4x4, 6spd
    I nominate this for a sticky in the cheap/free mods section!! Mainly so i can find it again!!:bananadance:
    RA77 likes this.
  18. Apr 20, 2010 at 9:12 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You guys that have an automatic trans should seriously consider putting your switch inline with the brake pedal interlock.
    That way the truck will start, but won't go into gear.
    My boss blew the brake light fuse on his 05 4cyl auto due to bad wiring job for his camper shell brake light. He was stranded. He called me for ideas on how to get the trans out of park. Had he been a thief he probably would have just given up.
    Plus, if you hear your truck start up, then you can run outside with weapon of your choice. :laser: The dumbass thief will be a sitting duck. With a starter kill there is less noise and therefore more time for a thief to look for your switch.
    RA77 and Manfred like this.
  19. Apr 20, 2010 at 10:02 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    nice...now everyone knows how to re-enable your truck...!!
  20. Apr 20, 2010 at 10:14 PM
    SurfInferno
    Dylan
    Littleton, CO
    2001 DC
    Haha yea...but not everyone can drive manual :p
