Kill Switch Installation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Smoothoperator, Sep 14, 2021.
  1. Sep 14, 2021 at 6:21 PM
    Smoothoperator
    Smoothoperator [OP] Member
    Austin
    2005 Access Cab Prerunner
    Hey guys,
    Has anyone here installed a kill switch on their 2nd gen Tacomas? From what I’ve read elsewhere it’s best to go off of the fuel pump relay but I’m not quite sure where that’s at?
    Any tips on doing this would be helpful. Maybe there’s another wire I can cut into and install it from there?
  2. Sep 15, 2021 at 6:25 AM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
  3. Sep 15, 2021 at 11:30 AM
    Smoothoperator
    Austin
    More of a stealthy security feature. I want to just add a toggle switch in my console or something but I can’t seem to find the fuel pump power wire
  4. Sep 15, 2021 at 12:13 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    There is a thread (link below) that most other kill switch inquiries refer to. That thread is about an ignition kill switch, but stiill a good read and replies. If you do a google search, "Tacoma kill switch or fuel pump kill switch" you'll come up quite a few hits, some on TW and some on another Taco forums. In some of the posts they describe a blue wire to the fuel pump located under the DS door sill plate that goes under the carpet, under the DS seat and out through a grommet which then to fuel pump. Some say not to tap into the FP power wire, but FP ground wire instead.
    https://www.tacomaworld.com/threads/kill-switch-mod-write-up.88252/
    I've been wanting to do a kill switch myself and most likely will when the weather cools down a little more. Until then I've been pulling the FP relay.
    If you do the FP kill switch mod please post your procedure with pictures. TIA!
    Smoothoperator[OP] likes this.
  5. Sep 16, 2021 at 7:58 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    I've done fuel pump switches on a couple of my past vehicles. They'd crank and go a short distance depending on how much fuel was in the system but they weren't going far. Pretty simple to just cut the wire and splice in a switch. Hide the switch wherever you like.
