Kill Switch/ Fuse Bypass Switch Help/Input
Discussion in '1st Gen. Tacomas (1995-2004)' started by TWhitcher, Mar 31, 2019.
  1. Mar 31, 2019 at 8:46 PM
    TWhitcher
    TWhitcher [OP] Member
    Tom
    RC 5 lug
    After a recent theft in my building and noticing that most Tacomas in my neighborhood have steering clubs. I've decided to take some basic steps to try to prevent the theft of my 2003 Tacoma.
    My truck doesn't seem to have a chip in the key so it might be easy to steal. (like honda easy)
    While there are a few posts on here about fuel pump kill switches I want to go in a slightly different direction.
    I just want to do a simple fuse bypass switch. Im thinking of pulling the ECU or IGN fuse then adding the switch with an inline fuse, So it cranks but wont start. Its essenitally the same thing as pulling the fuse everyday, without the inconvenience.
    Has anyone else done this or something similar?
    If the theif sticks around and looks under the dash and figures it out, so be it. I have insurance.
    If your tacoma has been stolen and you learned something about how they did it, please chime in.
    So I picked one of these up:
    Blue Ox Fuse ByPass Switch for Towed Vehicles - ATM Mini-Fuse - 10" Long
    https://www.etrailer.com/Tow-Bar-Wi...CWpeODqHeFjNGKAQUTCgYc7v-rTVGm0waAvBQEALw_wcB
    Yes, it is way overpriced, and yes I could make something similar for $10 from oreillys... But... I don't want my home solder job failing and killing my ECU at the worst possible time, like at 70mph.
    I also want it to be easy for me to troubleshoot or put back to stock.
    Also If you have good things to say about alarms or steering locks or other tricks let me know.
    Questions:
    Which circuit should I tap into?
    What's up with the 30A power fuse (Top Right)? Can you add a toggle switch there and kill all power?
    Why do I have a 4WD fuse? WTF! hah
    Can anyone see any major flaws in this mod?
    Thanks
  2. Mar 31, 2019 at 9:50 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    There is a 10-12 guage wire from battery negative to frame ground nearby. When removed/disconnected the truck won't start, but other electrical functions will still work. FYI
    rogerman likes this.
  3. Mar 31, 2019 at 9:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Following
    Considered a Viper alarm myself, just for the added convenience of remote lock/unlock.
  4. Apr 1, 2019 at 1:14 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If a real thief wants your truck it is gone.
    this will keep people looking for a ride from using your truck .
    get the EWD for your truck decide just what you want to do always remember it can fail at anytime .
    The more connections the more places for poor connections
    Thank the Gods I live in a place the keys can stay in the truck
  5. Apr 1, 2019 at 1:16 AM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    sub'd I'm in the same boat
  6. Apr 1, 2019 at 2:24 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I put a switch in-line with the ECU signal on the circuit opening relay system. When the Relay does not receive the proper signal from the ECU, it doesn't pass 12vDC along to the fuel pump. Therefore the truck will turn over, but never start.
  7. Mar 10, 2020 at 12:28 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Would you show a picture of which wire this is? I'm wanting to do this to my 2001 5vz-fe prerunner. Any help would be appreciated. I like your low amperage approach very much. I just can't find a reliable source for wiring diagrams or I should be able to answer my own question. Thanks!!!
  8. Mar 10, 2020 at 12:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    @mechanicjon gave me the idea.
  9. Mar 10, 2020 at 3:30 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Good to know! :boink:
    tacoma_ca likes this.
  10. Mar 10, 2020 at 3:33 PM
    tacoma_ca
    tacoma_ca Well-Known Member
    23 Taco OR; ̶0̶4̶ ̶4̶X̶4̶ ̶T̶a̶c̶o̶ ̶S̶R̶5̶; ̶9̶4̶ ̶4̶X̶4̶ ̶P̶i̶c̶k̶u̶p̶; ̶9̶3̶ ̶4̶-̶R̶u̶n̶n̶e̶r̶ ̶S̶R̶5̶
    You can remove the EFI relay then find which of the contacts gets +12V when the key is turned on. That is the wire you want to interrupt with a switch since it is on the low-current side of the EFI relay. The EFI relay gives +12V to feed the fuel pump via the circuit opening relay. The green/white wire above gives the ground to the COR coil. In my 04 3RZ, the green/white wire is actually white/blue.
    This is what I did while using this same lead to get a signal for 'key on' for my 2nd fuse box.
  11. Mar 10, 2020 at 11:12 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Green and yellow wire also at the circuit open relay.
    RELAY SIGNAL.jpg .
    MalinoisDad and Empty_Lord like this.
  12. Mar 11, 2020 at 1:30 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Best was when I pulled the truck outside on a cold morning below zero I decided to let it run and warm up forgot all about it for at least 3 or 4 hours.
    Another time the overhead door got stuck in the up position that might have been open for months
    Dalandser and Seagull233[QUOTED] like this.
  13. Oct 2, 2020 at 3:58 PM
    GregC
    GregC 00Tacoma
    Southern California
    2000 Tacoma PreRunner
    Hey Bart, would you mind posting a picture of the wire you're talking about and it's location? Or point me in the right direction to find it.
  14. Oct 2, 2020 at 4:35 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Following
  15. Oct 3, 2020 at 3:57 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    For a more cave man approach I rerouted the fuel pump power wire from the main harness under the driver’s seat to go through the cab (it’s already in the cab for anyone going to argue it’s not safe to have a power wire in the cab) to a switch under the extra cab jumper seat and made a new hole right over the front of the gas tank in the cab. I still plan on doing the relay trigger wire switch to a stock button on the dash I don’t use so I can leave the power wire switch on during short periods of time when I’m going to be jumping in and out of the truck.
    Another idea I think @BartMaster1234 gave me was to have one or two of these wired to receive power when the fuel pump power wire is switched off. One inside the cab and one outside would be perfect. You’d just have to weld a little lockable box and wire them in a way the thieves can’t see where the wires come out and then all around throughout the cab (maybe inside and out like a maze) so they couldn’t trace the wires.
    https://www.amazon.com/Maxmoral-1-P...eywords=12v+mini+siren&qid=1601722529&sr=8-16
    BartMaster1234 and Wyoming09 like this.
