Kicker Key Amp and Red Wolf Harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Biggidyslick, Oct 4, 2023.
  1. Oct 4, 2023 at 7:44 AM
    Biggidyslick
    Biggidyslick [OP] Active Member
    Considering installing one of these on my own. Currently 23 Stock Entune 8", non JBL. I have seen several threads, but no good videos of a Kicker Key Amp and Red Wolf harness setup and install. Any good instructions or videos out there? Can i just tap the power of the Head Unit or do I have to run a power to the battery? Thanks in advance
    https://www.amazon.com/dp/B09DTY8PMD?ref=ppx_yo2ov_dt_b_product_details
  2. Oct 4, 2023 at 8:37 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I used that harness but with an Alpine Power Pack. It's best to get power straight from the battery.
    Taco_mike73 and TRDRed like this.
  3. Oct 4, 2023 at 9:44 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    The manual itself recommends connecting power to the battery.
    TRDRed likes this.
  4. Oct 4, 2023 at 4:46 PM
    bbartol
    bbartol Well-Known Member
    Brandon
    Central Ohio
    2025 TRD Off-Road Premium in Terra
    I used the Red Wolf harness but I used this amp:
    Kenwood KACM1814 Compact 4-Channel Amplifier https://a.co/d/aYb6mgO
    That amp can be tapped into the constant 12 volt from the back of the stock head unit that's part of the grey plug. Because it uses speaker signal to turn on the amp itself, it's fine.
    Since the amp has RCA speaker level inputs, it comes with two sets in the box. So I grabbed one set, cut it in half, and spliced it into half of the Red Wolf harness that goes into the back of the radio. Then used the other half of the Red Wolfe harness for the output harness of the amp (all soldered connections) and all done.
    That was 2 weeks ago and has been fine ever since. Cheaper and, in my opinion, easier than the Kicker Key amp. The harder part is that you have to tune the amp sensitivity/gain yourself as opposed to having the microphone do it. Worth saving the money though, to me anyway.
  5. Oct 4, 2023 at 5:47 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I just tapped the rear speaker wires behind the deck to run to my 8" underseat powered Sub. Easy peasy, and have pretty decent bass. Not great bass, but pretty decent bass.
    NickAdams2112 likes this.
  6. Oct 5, 2023 at 8:49 AM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    He's wanting to install a 4 channel amp.
  7. Oct 13, 2023 at 1:41 PM
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Did the head unit speaker connector change from 2018 to 2020?
    I just ordered this Red Wolf harness so I can splice into it instead of the factory wiring when I add my Kicker Key amp. I am now thinking it's not going to work with my 2018 non-JBL head unit. I bought it because the item description says "Compatible with Toyota 2018-2022 Camry RAV4 Tacoma Corolla Non-JBL System". Then after I ordered, I read further and it says "2020-2022 Tacoma non-JBL".
    EDIT:
    Disregard. I have confirmed 2016-2019 uses a different connector. This Red Wolf harness is for 2020+. For 2016-2019 see below.
    https://www.tacomaworld.com/threads/add-an-amp.792429/#post-28380809
  8. Jan 12, 2024 at 5:58 AM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    I have a sub and amp with the harness from Amazon already installed in my 22. Would I be able to add this harness and amp? I fear they tap into the same harness
  9. Jan 12, 2024 at 6:50 PM
    ricco333
    ricco333 Active Member
    Erik
    2021 White SR5/4x4
    Ditto on the harness, same one I used for the kicker key amp install, just solder or crimp and shrink wrap and you should be ok.
  10. Mar 15, 2024 at 7:03 AM
    tacoman123
    tacoman123 New Member
    2022 black tacoma
    Hello I just got the red wolf connector for the key amp since I have no experience in tuning . Since I'm a total noob, can someone please provide a wiring diagram to the key so I don't mess up? Thank you so much! I'm using factory hu.
    on another note, would it be easy to put in a sub somewhere down the road or would I need to rewire everything again?
  11. Mar 15, 2024 at 7:10 AM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
  12. Mar 15, 2024 at 7:14 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  13. Mar 15, 2024 at 7:20 AM
    Rednecktacoma22
    Logan, UT
    22 TRD OR 6MT
    There is really fantastic documentation and discussion going on there. I read that entire thread last week and @destin_meeks helped me out immediately. It's things like this that keep me coming back to this amazing community!
  14. Mar 15, 2024 at 8:01 AM
    tacoman123
    2022 black tacoma
    Thanks guys!
    Rednecktacoma22 likes this.
  15. Mar 23, 2024 at 7:18 PM
    tacoman123
    2022 black tacoma
    Hi Guys! one more question, what do do with the blue wire for my setup? do i need to hook it up for the radio to work with hu? and found a ton of info on bi-amp setup, but what should the dip switch positions be for non-jbl with only door speakers? sorry I'm trying to get it done tomorrow and getting more confused... I wired the red wolf female to small end of key, the male end to the large end where the power is. Not sure if this is correct? found a pic in the forum but description is opposite ...
    Thank you all for your help again!!
